Old 01-21-2010, 05:30 PM   #1
CPPJEFF
Having the shocks relocated is the only way to fly!!CPP shock relocation kit!
Hey guys i was reading on another thread about how to modify stock tracbars and make home made shock relocators. We mass produce the perfect solution to both these issues and they work like a charm. The shock relocators come 2 lowers and 2 uppers powder coated with the mounting hardware. Before we try to reinvent the wheel e-mail me and i will give you a deal on a rear kit and get you down the road. Remeber guys just ask me for anything and if i have it , i want it on your truck!
CPPJEFF is offline   Reply With Quote
Old 01-22-2010, 12:45 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Having the shocks relocated is the only way to fly!!CPP shock relocation kit!
Cool pictures...
Hart_Rod is offline   Reply With Quote
Old 01-22-2010, 11:46 AM   #3
CPPJEFF
Originally Posted by Hart_Rod View Post
Cool pictures...
I rob post this picture to show you the correct shock angle and the ease of installing this kit. Its really a simple bolt on and very cost friendly.
Old 02-04-2010, 09:11 PM   #4
OJ1988
Just a car guy
OJ1988's Avatar
Can you explain to me the benifit of this?
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 02-04-2010, 10:01 PM   #5
suville
suville's Avatar
In a nut shell the less angle on your shocks the more efficient they are
suville is offline   Reply With Quote
Old 02-04-2010, 10:02 PM   #6
DKN
Active Member
After you lower the rear suspension the shocks will be mounted at a large angle, kind of like there laying down. The shock looses its abality to work when it is like that. The relocation brackets remount the shocks so they are more upright. This makes the shock work better at controlling the suspension movment.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 02-04-2010, 10:17 PM   #7
OJ1988
Just a car guy
OJ1988's Avatar
I see. Do you still use the same length shock?
1973 Vega Drag Car
1970 C20 tow rig
Old 02-04-2010, 10:50 PM   #8
kev2809
low n' slo
kev2809's Avatar
whats the price on these jeff? and where would you mount the top one if your using a step notch?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-05-2010, 11:31 AM   #9
CPPJEFF
$50.00 a set for members and with a step notch on the uppers you would need to fab up some type of mount. Thanks Jeff.
Old 02-14-2010, 06:15 AM   #10
Hard Luck
I've got grease on my mind.
Hard Luck's Avatar
Do you have some pics of the kit installed? I am using your 4" drop springs and the shocks are just about laying flat. What about new U-bolts? Are those in the kit? Do you recommend using degree shims as well?
Hard Luck is offline   Reply With Quote
Old 02-15-2010, 11:48 AM   #11
CPPJEFF
I posted a pic of them installed above, they do not come with the u-bolts as you can use your originals with this kit. We do sell the pinion shims also if you need them. Thanks
Old 02-15-2010, 12:43 PM   #12
Mike J
vw guy & now c-10 guy
Mike J's Avatar
Hey Jeff, I have a problem- I had to cut my old track bar mount (on frame) to get the old track bar off (bolt was seized in bushing) - do you guys happen to sell the frame mount bracket? If so, let me know, I need to order one up! thanks brother!
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 02-15-2010, 02:48 PM   #13
CPPJEFF
I might have one let me ask danny and see what we have. Thanks bro!
Old 02-15-2010, 05:32 PM   #14
Mike J
Mike J's Avatar
thanks man, just let me know...
'68 long fleet
My Build Thread
Old 02-15-2010, 05:55 PM   #15
CPPJEFF
Ok its a go! Danny does make them give me a call at 888-522-8303 to order one. Thanks
Old 02-15-2010, 06:13 PM   #16
Hard Luck
Hard Luck's Avatar
I saw that pic but the lower bracket is not the same as your kit. It looks like a block where the shock mounts. I thought is was mounted to the trailing arms because they look aftermarket as well.
Old 02-15-2010, 06:36 PM   #17
CPPJEFF
Hey do you have a pic of what you are describing? I would like to look at it. Thanks
Old 02-15-2010, 06:42 PM   #18
Hard Luck
Hard Luck's Avatar
OK. Can you see the block? What much are the U-bolts and shims? Is there something like a 1/2" to 1" block with shim built in?
Old 02-15-2010, 06:46 PM   #19
CPPJEFF
Yes i see what you have circled and thats not a block that is the lower shock mount. The shock stud bolts onto that. Thanks
Old 02-15-2010, 08:08 PM   #20
Mike J
Mike J's Avatar
Cool!!! I'll give you a call tomorrow
'68 long fleet
My Build Thread
Old 02-15-2010, 08:56 PM   #21
CPPJEFF
Right on bro!
Old 02-15-2010, 11:08 PM   #22
tcb-1
Nothing to see here.....
tcb-1's Avatar
got mine!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-16-2010, 04:38 PM   #23
Ont67shortbox
Hart Rod's are almost straight up and down,mine are still laid over like tcb-1's. Is this because I am using the stock trailing arms?.Ideally I would like my shocks behind the housing,but still trying to figure out how to do that.
Ont67shortbox is offline   Reply With Quote
Old 02-16-2010, 06:28 PM   #24
CPPJEFF
TCB-1S and mine are correct, they will lay slightly over but not on there side.
Old 02-24-2010, 04:04 PM   #25
dwhitley167
dwhitley167's Avatar
does anyone actually have a before and after pic of the set up, and possibly a pic of the bottom side of the bracket? would be great to see, thanks
67 chevy 402 BB w/ TH400
Learning as much as i can before i dig in!!
dwhitley167 is offline   Reply With Quote
