#26 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: The 6.0 Silverado Build
OK, engine mount adapters showed up today. FINALLY. I will be taking the day off tomorrow and plan to remove the accessories, paint the block, and transmission, and get it all installed in the chassis. Then I can take some time to paint the accessories and brackets this weekend. Pics tomorrow after some cleaning and painting. Cant wait to see it in the chassis.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#27 |
me too buddy!!!
and i cant wait for your test drive video!! ![]()
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#28 |
Test drive video? You mean see how long it'll boil the right rear tire video.
![]() I cant wait either. I found out today that Goodmark dropped the ball on my fuel tanks and wont have any until mid to late March after they told me they were in stock. So, now I get to wait for a refund from that so I can order them from RockAuto.com I wonder if I could just run a inline pump after the switching valve and just re-do my fuel system later? If so, I will just do that for now and spend the cash from the tanks on some headers or something else. Anyone see any issues with running an inline pump after the switching valve???
#29 |
the only downside that ive read is the noise.
i'd just keep on as planned and just use your stock tanks. The only time Bob noticed feul starvation on Fred was at an 1/8th to 1/4 tank. i'm keeping my org. ones for now.(spent a lot of time on them already!) i figure theres 2 so what the heck switch it over at a 1/4.
#30 |
Next project: 1970 K10
Biggest problem with an external pump after the valve is that those pumps are designed to push, not pull. That's a long pull when it's placed after the valve. Do it right the first time.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#31 |
I know I know. I figure if I'm going to remove the bed to do the fuel senders and everything else, I'm going to replace tha tanks with the 87 ones. No big deal, I can wait. Truck wont see the road again until spring anyway.
#32 |
Under Construction
subscribed.... nice progress.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#33 |
Slots go on anything!
My truck was rigged with an external pump. I just have one tank, so no switching valve, but it is really loud. No problem listening to see if the pump is working. Luckily the exhaust drowns it out, though.
Looks like this will be a cool build. Maybe you can sell off some of the factory crate your engine was sent in to offset the cost.
1974 Jimmy- 5.3/4L80e/NP241 |
#34 |
OK, took the day off today to mess with the truck. It's amazing how much work you can get done if you're not at work.
#35 |
Just found out my van 6.0 manifolds wont work. Too much interferance with the frame on the drivers side. So, looks like I get to spend way too much on a set of headers. Does anyone know if F-body or maybe GTO headers or manifolds will work with the 4l80?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. Last edited by STOCKISH; 01-22-2010 at 11:13 PM. |
#36 |
Truck manifolds should work OK too with that trans, I can't imagine where they would interfere. Plus you could probably pick a set up for < $50. Probably closer to $25.
#37 |
Yeah, I'd like to keep the manifolds but if not I'll just pick up a set of headers. I'm just glad to see it sitting in there. Need to clean and paint my accessory brackets and reinstall everything and it may start looking like a truck again.
#38 |
![]() I need to make a list and hang it somewhere....... My brain is 40 going on 97! ![]()
#39 |
I'll send you a PM in the spring to remind you.
#40 |
LOL, thank you!!!!
#41 |
Josh... the gto manifolds wont work. they hit the engine mount stand.
so what is the deal with the crossmember? does it have to slide too far back or what? Bob i think i may need to hear your idea on the trans crossmember now! ![]()
#42 |
The stock crossmember would work if modified like PCMcobra's. I just figure if I have to modify the crossmember, I might as well make one that looks nice and will make my dual exhaust easier for my exhaust guy. No real issues other than that.
#43 |
damn! dont kill me Bob but that BRP kit is looking better and better
#44 |
The BRP kit is nice but rediculously pricey in my opinion. making a trans crossmember would be super easy for you because you have the cab off. Just a straight piece if 1x3 square tube from frame rail to frame rail. Nothing fancy.
#45 |
Good point man. i'm just trying to get a rise outta Bob since we ended up commiting to the "FRED" way. figures the 80e would give us heartburn!
#46 |
Yeah, but I'd rather deal with modifying a crossmember and use a 80 than blowing up a 4l60e every couple months.
#47 |
this is true...
#48 |
You bunch of wussies! Live dangerously!!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 01-22-2010 at 06:58 PM. |
#49 |
Come to think of it, my old 96 ECSB and my 00 Tahoe both had 60's in them. Boy did I ever abuse those things! That's back when I volunteered with the sheriff's dept emergency services section. Running lights and siren at 100+ mph for up to 30 minutes straight sometimes, depending where we were going. Stop & go in town.... red light, BRAKES!!!, intersection clear, HIT IT!!! Crap, grandma can't hear OR see me, BRAKES, SWERVE, HIT IT AGAIN!!!
#50 |
Looking good Josh! Keep it up!
