Serpentine Belt System
Trying to decide on what low budget (junkyard) way to go for serpentine system on 350 build and after searching internet have decided that chevy S-10 might work. Was wondering if anyone has done this and if so was there any problem with alternator or a/c clearing TALL valve covers? Any help/suggestions appreciated.
Re: Serpentine Belt System
Can't help you on the S10 system. But I am running a serpentine set up off an 89 up Camaro. No clearance issues with tall valve covers. All the accessories are in front of the cylinder head. Be sure to use the correct reverse rotation water pump.
A 4.3 s-10 should work they are just a sawed off 350 grab the water pump too
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
One foot in front of the other
![]() Join Date: Aug 2008
88-95 truck I believe.
![]() Join Date: Sep 2006
i will say they do look sweet and I had fun putting this one together.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Thanks Guys - Exactly what I was hoping to hear! That sure is a sweet looking 454 Fleetside!
I was fortunate enuff to pick up a complete system from an 84 corvette almost free, including all access and wiring. It has the seperate reservoir on top, and looks great except for the smog pump which I will likely just get a idler pulley kit for, or eliminate it. Sort of like the pics. I like the A/C on the passenger side so the hoses are short and out of the way.
#8 | |
Easiest solution is to swap out the heads. Anything else will be much more difficult. I did hear of someone taking 1/2" plate and making adaptor plates, but then you have to space everything out 1/2" including the water pump and crankshaft pullies.
60-66 Nut
I would just drill and tap the head. There should be enough material there, just try an not go any deeper than you have to. Even if you did get into the water passage, it will still seal up with a little thread sealant on the bolt. Wouldn't be much different than the water pump bolts being into the water passage.
We drilled and tapped the camel backs on my son's race truck with no problems I drilled the top right one out to 1/2 and then drilled the 1/2 bolt for 3/8 to get the right spacing on the front , The late heads with bosses cast in just drill and tap
Thanks fellows Got new drill bit and tap to be safe and will take it slow and easy.
88-95 will work and 4.3 v-6 s-10s trucks or blazers no problem.not done learning new things might be others its just a small block chevrolet.
triple d |
