Old 01-22-2010, 09:38 PM   #26
fpjr0
fpjr0's Avatar
Re: Another LSx/4L60e Swap
I am not sure but in the pic, it looks like if those mounts would had allow to use the original compressor... they almost look like the plate had the "fred" cut on them,, what you guys think?
fpjr0 is offline   Reply With Quote
Old 01-22-2010, 10:50 PM   #27
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
It would allow the 5.3L compressor to fit, but at the expense of not being able to re-use the stock driveshaft (i would have to be shortened), and the need to move the shift linkage frame bracket.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-23-2010, 08:22 PM   #28
fpjr0
fpjr0's Avatar
thats probably what I have to do,, since I have a welder to "fred" mod the stand as you guys showed,, but since my time off is limited, It will be easier I guess,,, still thinking about it... thanks for the info,, you guys are great....
how can you guys tell the transmission you have,,, I saw somewhere that
the some have the "4l60e" staped on the.. but my have nothing but a # 58 also has the GMPP staped on it.. came from a state trooper tahoe? any one..?
Old 01-23-2010, 08:29 PM   #29
Thealien
Thealien's Avatar
the some have the "4l60e" staped on the.. but my have nothing but a # 58 .. came from a state trooper tahoe? any one..?
Here is a site that gives tranmission measurements.
The 4L80 is about 4 inches longer to the bolt flange (measurement B). Should be able to figure it out with these measurements
Old 01-23-2010, 08:33 PM   #30
menace121978
menace121978's Avatar
if i'm not mistaken, the 60's and 65's have a round cap with a clip on the passenger side where the shift servos are. someone please correct me if im wrong.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 01-23-2010, 08:55 PM   #31
glock35ipsc
I would correct you.....
but you are right!
Bob
Old 01-23-2010, 10:13 PM   #32
menace121978
got 1 right!!
"Dennis the Menace"
Old 01-23-2010, 11:23 PM   #33
fpjr0
fpjr0's Avatar
thanks... It does have the round clip.. so I guess a 60 it is.... thank you.....
Old 01-24-2010, 05:46 AM   #34
atopper
box junkie !!
atopper's Avatar
awesome build !! lots of good info . subscribing
- 500mg of crazy a day ...... will keep the straight jacket away !!! :burno
atopper is offline   Reply With Quote
Old 01-25-2010, 02:04 PM   #35
soule64
soule64's Avatar
The truck had the usual rust areas, so I welded in pillars, kick panels, cab corners, outer floors and rocker panels on each side.
soule64 is offline   Reply With Quote
Old 01-25-2010, 02:08 PM   #36
soule64
soule64's Avatar
The original harness was shot, so I replaced it with a Painless direct-fit. Many of the circuits aren't going to be used, so I have them tied uo for now. Also mounted the engine harness fuse block in the same area.
Old 01-25-2010, 02:15 PM   #37
soule64
soule64's Avatar
I found a '91 Blazer cluster with electronic speedometer and got it tied into the chasis harness. All of the guages and lights work (not sure about the speedometer because I haven't tested it). I tapped the t-fitting near the oil filter and mounted a sender. Works great!
Old 01-25-2010, 08:23 PM   #38
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
That T-fitting, is that where my oil cooler lines are? If so do I change that to this T-fitting or tap the oil cooler lines block?
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline   Reply With Quote
Old 01-25-2010, 09:40 PM   #39
glock35ipsc
Street and Performance sells that bypass block, their are fairly reasonable on the price too (surprise surprise!!). I bet you could get a part number from a dealer too, then check at gmpartsdirect.com to see if they are cheaper.
Bob
Old 01-25-2010, 09:41 PM   #40
mrjs80
This is what i did, it was for my 97 tahoe so it's a different sender but you should be able to fit the older sender in there.
mrjs80 is offline   Reply With Quote
Old 01-25-2010, 09:52 PM   #41
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
My engine is from a van and just has a block off plate there. I guess I need to go look and see where my oil sender is on the 6.0 NOOK and TRANNY on ebay sells a oil sender and a one wire connector (from a 2002 F-Body) so you can hook the wire directly to your factory wiring for your pressure gauge.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-25-2010, 10:30 PM   #42
menace121978
Josh i just seen your sig!!
btw, i need one of those oil sender t's also.
"Dennis the Menace"
Old 01-26-2010, 11:16 AM   #43
Chevyman350
I just though I would post an FYI that the "electronic" speedos actually still need a cable drive from the transmission and the speedo it self has a signal generator for the computer (engine only during these years).
I hope that this saves you some time.
Just look at the back of the speedo yand you will see the cable fitting.
Chevyman350 is offline   Reply With Quote
Old 01-26-2010, 11:22 AM   #44
glock35ipsc
Ummm sorry, but you are wrong.
The electric speedo we use for these swaps come from a 90-91 Blazer, Suburban or dually. They are true electric speedometers, and only require the one signal output from the PCM ran to the cluster. You must re-pin the cluster connector, but there is NO speedo cable.
Look at the back of my cluster and you will see no cable fitting
Edit - Corrected the date.
Bob
Old 01-26-2010, 11:25 AM   #45
Thealien
Thealien's Avatar
This is another oil pressure sender option I posted in the other thread.
Some people remove the oil pressure sending unit from the back of the engine and use a 16mm X 1.5 to 1/8NPT adapter and use that for their oil pressure line/sender. The PCM doesn't need the oil pressure sender (from what everyone tells me). I am having a T made for that location so I can have both (I believe a scanner, Tuner and things like an aeroforce gauge can read the stock sender)
This is the adapter fitting
Aeroforce gauge
Old 01-26-2010, 11:29 AM   #46
joe231
joe231's Avatar
The electric speedo we use for these swaps come from a 89-91 Blazer, Suburban or dually. They are true electric speedometers, and only require the one signal output from the PCM ran to the cluster. You must re-pin the cluster connector, but there is NO speedo cable.
I believe that is a 90-91 cluster.
I have a 1989 sub that i'm parting and it has a speedo cable with an optical sensor for the computer.....I will look and see what the exact date is on the sub, maybe it was a mid year change?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-26-2010, 11:29 AM   #47
glock35ipsc
I left the 5.3's sending unit in it's original location, and drilled and tapped the bypass block and put the sender there. Why? Hell, I don't know. Cause it was funner to drill and tap something I guess?
Bob
Old 01-26-2010, 11:30 AM   #48
glock35ipsc
DOH!!! I still have GMC grills on my mind!! Yep, 90-91 clusters. I fixed my post.
Bob
Old 01-26-2010, 11:36 AM   #49
glock35ipsc
soule64 - Is that a tach in the bottom left hole in your cluster? If so, what kind is it? Things are looking good!
Bob
Old 01-26-2010, 11:45 AM   #50
STOCKISH
STOCKISH's Avatar
May be a dumb question, but couldnt you have used the F-body (2002) sender and your factory wiring or was the location of the 5.3s sender an issue?
--Josh
