Old 01-23-2010, 09:28 PM   #1
yellow70GMC
yellow70GMC's Avatar
Frame question (how to fix)
So here's what the front of my frame looks like, and i'm wondering what the best way to fix it is. Thoughts?
yellow70GMC is offline   Reply With Quote
Old 01-23-2010, 10:03 PM   #2
project 67 sub
project 67 sub's Avatar
Re: Frame question (how to fix)
hammer it back together and weld it up
project 67 sub is offline   Reply With Quote
Old 01-23-2010, 10:06 PM   #3
yellow70GMC
That was my first thought too. I'm just afraid i could end up cracking the whole piece off since i'm dealing with 40 year old steel that's potentially really brittle. Anyone dealt with this before?
Old 01-23-2010, 10:07 PM   #4
glider_6969
If you do hammer it back and weld it, I would recommend you reinforce it with another backing plate the same shape. It may be a bit of work but it will be stronger.
glider_6969 is offline   Reply With Quote
Old 01-23-2010, 10:42 PM   #5
tcb-1
Nothing to see here.....
tcb-1's Avatar
I'm with everyone else, bend it back slowly, reweld, and grind smooth..... viola!
I'd also hit the bending point with some heat so the likelyhood of it "breaking off" would be less.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 01-24-2010, 06:58 AM   #6
yellow70GMC
I had the same thought. Sold my oxy/acetylene setup a few months ago, the hottest torch i have in my garage right now is a mapp setup. think that's hot enough? thanks for all the input guys!
Old 01-24-2010, 09:47 AM   #7
glider_6969
Mapp gas is hot but I don't think it will be hot enough and would take alot longer . I would borrow some torches.
Old 01-24-2010, 10:12 AM   #8
ERASER5
ERASER5's Avatar
Drill a small hole at the end of the crack or it will likely crack again. Every machine shop manual will agree.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-24-2010, 10:39 AM   #9
Kenbo-Slice
Kenbo-Slice's Avatar
A mapp setup will not get hot enough to make a difference. As said before, rent or borrow an oxy acetylene torch heat up the one side. I would suggest getting a pickle fork with a helper bar on one side and slowly bending it back with some muscle and then heat it up a bit more and hammer a little to get it to fit tight. Then weld it, grind it and plate it (if you desire. I would, just to be safe).
It's a Jeep towing machine! (at least it will be)
Kenbo-Slice is offline   Reply With Quote
Old 01-24-2010, 02:45 PM   #10
johndawelder
johndawelder's Avatar
It's not brittle or it would be broken off.Just hammer it back and V it out a little and weld inside and outside.Should be fine.Looks to me like someone has yanked on it with a chain.
johndawelder is offline   Reply With Quote
Old 01-24-2010, 03:51 PM   #11
tim21391
tim21391's Avatar
maybe one tack before u bend just to give it a little resistance.. you catch my drift?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 01-26-2010, 06:22 AM   #12
yellow70GMC
Alright so i'm gonna screw with it tomorrow. i'm gonna heat it up and bend it back, make a v-cut in the cracks, weld it, weld a plate on the inside, and box the outer 1 1/2 or so of the rail, i just gotta leave enough room so i can get a socket in there for the bumper bolt. big thanks to everyone who replied, all your suggestions are really helpful. i'll post some pics of what i come up with, tomorrow night as long as i don't get distracted tomorrow.
1970 GMC 4x4 swb fleetside
custom 4 inch lift with rear shackle flip, mild sbc, tci trans, rebuilt np205 w/twin shifters
Old 01-26-2010, 10:29 PM   #13
yellow70GMC
So believe it or not, mapp gas was plenty hot enough. I didn't think it would be but i figured i'd give it a shot. I ended up being too lazy to box the end of the frame rail, but i welded it inside and out, and put a piece of 1/8th inch strap on the inside to reinforce it. My 120v mig didn't have the juice to weld the frame, so i had to borrow my buddy's arc welder. I'm pretty good with mig, but it was like my 4th attempt at arc welding of all time and it's harder than i thought. Here's some pics if anyones interested.
All cleaned up and ready to bend back
Bent back, notched out the cracks
First bead-came out alright considering i don't know what i'm doing
After i cleaned everything up
Painted-good as new!
