01-25-2010, 12:20 AM | #151 |
Member of the longbed union.
Re: I wana drive 65.
Heck I would ride this short bus.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
01-25-2010, 12:24 AM | #152 |
Rods
im sure you would.....
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
01-26-2010, 09:53 AM | #153 |
Rods
picked up my motor plates.... local shop cut them for me cheap I hope they work with factory a/c braket if not then ill make somthin happen. If its not to cold I will start on the engine swap. However i did look at the dash and I think i can use the 64-66. I kinda like the way it looks when the stuff is test fit.
02-10-2010, 03:59 PM | #154 |
Subscribed!!!!
02-10-2010, 05:54 PM | #155 |
Rods
So the engine is in the frame. Started the wiring. I will be using all factory wiring (08) i want to use the auto dimming lights and daytime runnginlights ect. I also am installing the 08 colomn in there too. Looks and feels great. Only problem i have is with the brake pedal in the way. I think i can shift the colomn just off center to compinsate for it and still look good. If not the i will do somthin to the pedal shaft. I am using the 72 booster mount for now untill i can see what else will work.. Btw the stock booster and brackets are for sale.
02-11-2010, 12:29 AM | #156 |
How can you set the colum off center? Takes lots of pics as you go!
02-11-2010, 12:38 AM | #157 |
Rods
I have the cross brace from the 08 I am goin to cut off the colomn mount and build a bracket.
02-11-2010, 01:06 PM | #158 |
Under Construction
sounds like your making some good progress. keep at it.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
02-11-2010, 01:09 PM | #159 |
Rods
Its slow. I want to get the frame streeeetched soon.
02-11-2010, 08:50 PM | #160 |
Me too! Let's git-r-done!
02-11-2010, 09:01 PM | #161 |
Rods
i will be looking at using another frame that I have. if so then I will be starting on this asap. line next weekend I will be stretching it if not then I will have to just get the drive shaft made up and start driving it
02-11-2010, 09:57 PM | #162 |
Rods
here is a small update.. engine in. wiring started. colomn simi mounted. dash kinda in place
02-11-2010, 10:14 PM | #163 |
One foot in front of the other
Looks good- how much firewall clearance you gonna have?
02-11-2010, 10:17 PM | #164 |
Rods
lots. about 4+ inches
02-11-2010, 10:24 PM | #165 |
Rods
there is alot to use on the original harness. like the headlight switch dash switch. not sure how the brake lites know when to come on yet. I found out that the fuep pumpharness goes into the abs/roll over control to turn the pump off.. well i cut all that out so I will have to rewire some stuff...im not so sure i want to use the a/c now because it so damn big. but i like the factory dual climate option... any ideas.
02-11-2010, 10:39 PM | #166 |
Maybe it won't be as noticeable once everything is in place and buttoned up??
02-11-2010, 10:42 PM | #167 |
Rods
true i was thinkin of moving my whole dash forward
02-12-2010, 01:11 AM | #168 |
1 thing at a time is progress.
I can't help with electronics, but I can set back and watch this come together. Thinking out of the box. Awesome job!!
Alan
Philippians 2:14-16 |
02-12-2010, 08:46 AM | #169 |
Rods
Thanks alan your build has been an insperation for ideas here..
02-12-2010, 10:10 AM | #170 |
nice build!!!!
283 the mighty small block |
02-12-2010, 10:41 AM | #171 |
Rods
thanks I hope to have some real progress for yall
02-12-2010, 10:58 AM | #172 |
I had an 88 Suburban that I cut up and scrapped. I noticed that the frame is straight and lonnnnnng. Maybe if you come across one you can use that frame instead of making yours longer. Just a thought. Looks like you might have to much time into the one you have going anyway.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
02-12-2010, 11:03 AM | #173 |
Rods
i have a 91 sub but I think it would take more little modifing then it would be just to use my extra frame and just reattatch the back half. I want to use the factory cab mounts for the extended cab.
02-13-2010, 02:56 AM | #174 |
60-66 Nut
I would stay with the older frames.......it would be easier IMO.
02-13-2010, 08:55 PM | #175 |
Agree
