Old 01-25-2010, 09:15 PM   #1
GMC Guy
GMC Guy's Avatar
how do i know which crate i have?
before i bought my truck the previous owner had installed a GM crate motor. now which one exactly is what i don't know....
it looked most like this one when i first got the truck, but i think there are a couple variations that look alike.
http://www.summitracing.com/parts/NA...7353/?rtype=10
then there's this one...
http://www.jegs.com/p/GM-Performance...52506/10002/-1
basically i would just like to know, how do i figure out which GM crate motor i'm working with?
the PO didn't buy the motor through summit or jegs, but i think through Groth Bros.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 01-25-2010, 09:46 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: how do i know which crate i have?
Get the casting numbers off the back of the block just behind the driver side cylinder head. You can look up GM casting numbers at mortec.com
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-26-2010, 11:36 AM   #3
Damien
Damien's Avatar
That is the same engine. This is from Summit's website. Click on the "show all" link and it will give you the specs. The hp depends on if you are using the stock intake and exhaust or aftermarket intake and headers.
"These GM Performance Goodwrench 5.7L/350 c.i.d. engines have approximately 8.5:1 compression with an base horsepower rating of 195 hp and capable of up to 260 hp depending on intake and injection setup."
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 01-26-2010, 12:31 PM   #4
joe231
joe231's Avatar
First off I'm going to assume it is a 2 piece seal engine with the perimeter bolt valve covers......they are all the same basic engine but with different cams. I don't know how you would know what cam you have unless you pull it out. My crew cab I just bought has the 250HP 10067353 crate engine (luckily the PO kept the receipt for the engine)
http://www.jegs.com/i/GM+Performance...67353/10002/-1
then there is the 290HP 12499529
http://www.sdpc2000.com/details/gm-p...parts/12499529
and a 300HP 10067353
http://paceperformance.com/index.asp...&ProdID=264227
if you notice in the specs they all have the same basic specs (block, heads, ect), but with different cams.
can you tell I have recently been researching this for my engine
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-26-2010, 01:07 PM   #5
Damien
Damien's Avatar
Everything Joe posted is correct. The two engines posted by GMC Guy have the same cam specs.
Old 01-26-2010, 03:32 PM   #6
GMC Guy
GMC Guy's Avatar
so basically there is no way to determine which one it is unless pull the cam? lol
i understand better now though, thanks for setting me straight.
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 01-26-2010, 09:20 PM   #7
MR .T
MR .T's Avatar
you could check cam lift with a dial indicator. that will give you a good idea of what cam it is. stock is 390 lift L79 is 447 those are common.
MR .T is offline   Reply With Quote
