Old 04-30-2003, 01:00 PM   #1
TC70C10
TC70C10's Avatar
Valve Clatter - Timing ?
I hear some valve clatter when it hit 2nd and third gear on a slight incline on my 305 K5 Blazer. I've bumped the timing from 4 to 8 to 12 without major improvement although 12 does sound better than 8 degrees. Yesterday I filled up with 89 octane to give it a try. Again some improvement. This is a newly rebuilt motor with about 2500 miles on it.
Ideas.
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch
1995 T10 Blazer 4.3L 4x4 (Son's)
2004 GMC Envoy 4.2L 2WD
2005 GMC Sierra Crew Cab Z71 4x4 5.3L
240 Fun Finder Travel Trailer
Harvest, AL 35749
TC70C10 is offline   Reply With Quote
Old 04-30-2003, 02:30 PM   #2
rockman20
"The dude abides"
rockman20's Avatar
Just to rule out the obvious, you have adjusted the valves correct?
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
Old 04-30-2003, 03:31 PM   #3
TC70C10
TC70C10's Avatar
To be honest, the valve adjustment crossed my mind but I haven't done it yet. I really thought it was the timing. Thought I'd hear valve clatter all the time if they needed adjusted.
I can't remember adjusting the valves after installing the 350 in the 70 C-10.
Also, this was a motor swap not a motor I rebuilt.
Harvest, AL 35749
Old 04-30-2003, 05:24 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
Is it valve clatter or spark knock you are hearing? By your description, sounds like spark knock to me. Try lowering your timing to 6 BTDC and check it. 305's are the worst engines ever built by GM for this. The 305 combustion chamber was the cause. This is the very reason GM used the ESC distributors with knock sensors in LE9 trucks.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
