Old 01-26-2010, 01:58 PM   #1
structures
structures's Avatar
4.8 5.3 ls engine bolts, fasteners, hardware
I have a 5.3 engine and 4l60e transmission out of a 2006 Silverado. Problem is I need some hardware and I really don't know where to buy except from the dealer. Does anybody have information on the bolts which fasten the tranny bell housing to the block, starter bolts to the block and A/C compressor mount bolts.
I don't mind buying from the dealer but was hoping there was a parts diagram or fiche available, just so I could do a little checking on my own.
structures is offline   Reply With Quote
Old 01-26-2010, 02:26 PM   #2
Thealien
Thealien's Avatar
Re: 4.8 5.3 ls engine bolts, fasteners, hardware
These LS series engines are pretty uniform. Most everything is 10mm X 1.5 I think there is a couple of 12mm X 1.5
I am pretty sure bothe the bellhousing to engine and starter and even the AC brackets are all 10mm X 1.5. If you have one of those cheap digital calipers you can easily figure out the lengths you need.
At least 1 of the bellhousing bolts has some smaller diameter thread sticking out for an additional nut to hold the dipstick tube. (in a bind you might be able to capture it with just the bolt). They use another one or two of those to bolt the fuel line and wiring harness to.
You may want to call a couple of local parts yards and they may sell you everything you need cheap? When I bought my engine from Spaulding auto they included a bag with all the bolts needed.
Old 01-26-2010, 02:31 PM   #3
Thealien
Thealien's Avatar
I have some other information but I can't find it right now?
Old 01-26-2010, 03:16 PM   #4
structures
structures's Avatar
Thanks for the info. Like you are saying it's uniform and I know the lengths and threads I need, such as M10 X 1.5 X certain lengths. It's the material and style that I'm at a loss for. Also like you're saying the threaded stud for the trans dipstick mount.
I was browsing through ls1tech and seen a few post from guys talking about problems with bolt heads being too big for the tranny mounts. Also I would like to install aluminum fasteners like the factory's for the A/C.
I might call some parts yards before heading to the dealer. I'm under the impression these things can cost upwards to $5 a piece.
Old 01-26-2010, 03:34 PM   #5
Thealien
Thealien's Avatar
None of my bolts were aluminum. They are an aluminum looking bolt but all mine are steel. Metric bolts have a different grading than US I think something like 10.9 or?
Old 01-28-2010, 01:26 AM   #6
LEEVON
Moderator
LEEVON's Avatar
There's a thread on LS1 tech somewhere that has fastener information.
I'm in the same boat, purchased a complete accessory setup from a dude and told him if he did nothing else to make sure he included all the fasteners. Guess what? He "forgot". What a pain to chase these down, and the factory bolts have the splayed heads, something you don't get at the hardware store. They just look right, grade 8 bolts don't in my opinion.
Off to find that thread...
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-28-2010, 01:40 AM   #7
LEEVON
Moderator
LEEVON's Avatar
Found it:
http://www.ls1tech.com/forums/conver...-hardware.html
Old 01-28-2010, 03:54 AM   #8
Thealien
Thealien's Avatar
I thought I had that saved somewhere and couldn't find it. Too bad it doesn't say what most of the bolts are for?
Old 03-09-2010, 08:18 PM   #9
structures
structures's Avatar
I did go ahead and pick up starter bolts from the dealer, GM P/N 11610787. Price wasn't too bad... less than $2. He did print me off some specs on the studs for the transmission. Item 6, GM P/N 11519797 is almost $8 a piece and GM uses 6 around the top side. The two on the bottom, GM P/N 11515768, is less than a $1. I don't know I may just just pick up the bolts and use those in place of the studs. I can't find a reasonable price on these fasteners anywhere.
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
Old 12-17-2012, 10:31 AM   #10
1970 C10 MJW
1970 C10 MJW's Avatar
subd
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 12-17-2012, 04:49 PM   #11
68Stepbed
68Stepbed's Avatar
I got most of mine from the dealer. I'mwishing I'd went with ARP head bolts, though, just in case the heads ever have to come off.
As for starter bolts, they are specific for the starter. DO NOT USE regular bolts in a starter. They WILL back out. Starter bolts have knurls on the edges to keep them from backing out and to hold the starter in place.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-19-2012, 12:07 PM   #12
mooseknuckles
mooseknuckles's Avatar
for the tranny bolts I used reg grade 8 metric bolts....you do not want to buy these from the dealer!! ......starter bolts i bought from gm$$......torque converter bolts are arp....you can find some bolts on e-bay as well.
mooseknuckles is offline   Reply With Quote
Old 12-19-2012, 12:40 PM   #13
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I ordered some bolts, like starter bolts, from Rock Auto. The sell for a fraction of the cost at the dealer and the shipping is FAST! I also needed the lower bellhousing bolts I used the specs, like the ones above, to buy them from my local Ace hardware.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 12-26-2012, 12:34 PM   #14
68Stepbed
68Stepbed's Avatar
Maybe the local dealer here isn't marking up the price on stuff because I bought ALOT of stuff from my local dealership because their prices beat everyone else.
The only regret I have is not going with ARP head bolts. Stock head bolts aren't re-useable, and I think I may have to put new lifters in mine, which means new head bolts and head gaskets again.
Matt
Old 12-27-2012, 02:19 AM   #15
mcmlxix
Collector of Projects
mcmlxix's Avatar
I just ordered some stuff from www.GMPartsDirect.com ... transmission studs becasue I wanted to bolt the dipstick tube in place.... P/N: 15724226 for $2.63 ea
Rich
1972 K5 Blazer CST Click HERE
Old 12-27-2012, 11:55 AM   #16
JNJchev77
Registered Cruiser
JNJchev77's Avatar
That's where I got my schtuff... Ordered the studs, left & right covers for the 4l60e, all bolts for under $50.
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
