Old 01-27-2010, 11:18 PM   #1
fla wildman
fla wildman's Avatar
best tires for 4:56 gears
Did not know what would be the best over tire size for 4:56 gears.
Try to ask this before with out much luck thought better title would help
83 Chevy 4x4 stepside was a 6.2 stick now 350 auto
86 Cutlass with built 350 street/strip car
85 K5 all stock
2006 F250 6.0 the puller
69 c10 soon to be k30 too far gone to fix
fla wildman is offline   Reply With Quote
Old 01-27-2010, 11:27 PM   #2
Musclerodz
Re: best tires for 4:56 gears
what engine, what trans?
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 01-27-2010, 11:29 PM   #3
fla wildman
350 motor little more power than stock 400 turbo trans 203 trans. case in a 83 stepside
85 K5 all stock
Old 01-28-2010, 12:12 AM   #4
Yukon Jack
Yukon Jack's Avatar
What is your intended use of the truck?
I've got 4.56 gears in my 69 K20 with 35" tires - good combination for keeping in the power band but you're not going to go to fast on the highway.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-28-2010, 02:39 AM   #5
vectorit
What?
vectorit's Avatar
Runnin 327, 4spd, T221, 4.57's and 33" tall tires.
I like how it drives on the street and highways, not too rev happy but just right for me.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 01-28-2010, 05:16 AM   #6
blazinzuk
blazinzuk's Avatar
i say 37s but what do I know I ran 38s with 4.10s and am now running 44s with 4.56s
blazinzuk is offline   Reply With Quote
Old 01-28-2010, 06:25 AM   #7
This looks all backwards.I usually select the gear to suit what I`ve done with tires,motor,auto or manual,and what my goals with the truck are.In the 35" tire range you basically drop a notch in your gearing.So,if that`s what you have you`ll be a about 4.10.
Old 01-28-2010, 09:35 PM   #8
fla wildman
Ya I know; but thats the gears that were in the rear end and Its got a locker in it. Plus the truck was a Gov. truck and the front in is a 4:10 or 4:11 for got witch one and the rear is 4:56's factory so I'm kind of stuck with 4:56's. Do not know of another combo that would work with the trans. case .
85 K5 all stock
Old 01-28-2010, 10:32 PM   #9
Yeah,we always have the ratio in it when we start it off.You can run pretty tall rubber with that ratio.The taller the tire the more hiway friendly,too.
Old 01-29-2010, 01:39 AM   #10
bigbadchev72
People know me
bigbadchev72's Avatar
Ive ran 38s and 35s with mine, I am very happy with the 38s now, great power throughout, and i got 14mpg the last time I took it out on a roadtrip
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 01-29-2010, 08:29 PM   #11
fla wildman
Thanks.
38x15.50 Ground Hawgs are what I want to put on it but did not know if I should run 15" rims or 16.5". I know the 16.5's were the odd ball ones for years plus the 15's only come in 6 ply and 16.5s come in 10 ply.And if your going to run 1ton running gear I would thank go for the 10 ply.
85 K5 all stock
Old 01-30-2010, 10:10 AM   #12
I`d run the 16.5s.Good off road tires are made in that diameter and haven`t fallen prey to the silly dozen different diameters trend that plagues the automotive world these days.
Old 01-30-2010, 10:49 AM   #13
eric67m
eric67m's Avatar
Not to hyjack...
Will 15" wheels clear the brake calipers on 3/4 or 1 ton axles or is grinding required? I chose 16" wheels for clearance and tire availability. Just curious.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 01-30-2010, 07:51 PM   #14
fla wildman
Originally Posted by eric67m View Post
Not to hyjack...
I thought the same thang about the 15" rims my self. But they do list 15" rims for 8lug on 6.5 space. I thanking 16" my self seams like there tires are cheaper
85 K5 all stock
Old 01-31-2010, 12:44 PM   #15
orneryolbiker
orneryolbiker's Avatar
Check this page here:
http://www.4wheelparts.com/aux_incl/gear_ratio.html
It will tell you all you need to know....
And 15's will not fit on stock full floater rearend
orneryolbiker is offline   Reply With Quote
Old 01-31-2010, 02:07 PM   #16
edge
edge's Avatar
Might count ring gear teeth & pinion teeth...front and rear. 4:10 front and 4:56 rear?????? that dont sound right. they need to be the same ratio.
edge is offline   Reply With Quote
Old 01-31-2010, 07:56 PM   #17
fla wildman
I know, I have counted them more time than I can count and it still come out the same. Plus the rear end has a tab on it that has the ring gear number and pinion and 4:56 gears and the front has the same that sed it is 4:10 I thank, not 4:11.But still there not the same gears and they have been in the truck for years and have had the truck on hard ground in 4wd and it works. The truck did come off of the cape so being an old military truck who know why its this way. Plus I have the tranny and t-case in my 1/2 ton now and its gears are the same and if your not in soft dirt the front and rear end fights each other.
85 K5 all stock
Old 01-31-2010, 08:01 PM   #18
fla wildman
Thanks,
I have there chart at home but on papers one thing and what real people have or have had I trust more.
85 K5 all stock
Old 02-05-2010, 01:24 PM   #19
silver7
silver7's Avatar
I agree with special K. Since the tire size will change your 'actual gear ratio' figure out what rpms you want to be pushing when you are driving down the road and select your tire size from that. Orneryolbikers link will give you that information.
Good luck.
Shawn
1971 C10 4x4
silver7 is offline   Reply With Quote
Old 02-05-2010, 02:11 PM   #20
LONGHAIR
Something fishy is going on here. There is NO WAY that a NP203 transfer case is "built" to be able to handle different gears on the opposite ends of the truck. The internal differential "may" be able to handle it on loose ground for a short time, but it will bind up eventually.....and it certainly wouldn't prefer it. It should never be "locked" on hard pavement anyway.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-05-2010, 03:20 PM   #21
orneryolbiker
I agree 410:1 in one end and 456:1 in the other, Something is going to break
I see a catastrophic failure coming soon..............
The early napco's and jeeps were like that, for example 411:1 in the front and 410:1 in the rear to help in steering, but even that proved undesireable in the long run.....
Old 02-05-2010, 04:38 PM   #22
72chevyk10
I built it
72chevyk10's Avatar
we had a ford that was like that from the factory (lemon truck) one day we were pullin out of the field and broke the transfer case. at that time we didnt realize it had a 4.10 rear and 3.73 front. before that we hadnt drivin it on the pavement in 4wd. that thing snaped on seconds last ford we ever had
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 02-05-2010, 06:20 PM   #23
fla wildman
Could it be this way because of were it came from
85 K5 all stock
Old 02-05-2010, 06:35 PM   #24
orneryolbiker
Nope, somebody put that front in it to just get it rolling, that much ratio difference would never be done from the factory, even military mechinics know better... sorry
Old 02-05-2010, 06:56 PM   #25
fla wildman
Well I know we did not change it and I know the 4wd work fine. My father used the truck for his work truck for over 15 years. And put in 4wd on and off road. When I start the build I'll have to take some pics of the front and gear end gears.
But the thing that makes me thank it is factory or a military special order is the tranny and t-case are in my k10 now and it has the same gears front and rear it does not like hard ground in 4wd.
85 K5 all stock
