Old 01-28-2010, 01:15 PM   #1
bratten82
Which rear end is everybody using?
Im building a 53 5 window and have pretty much everything i need except the rear end. was just wondering what other people were using.
bratten82 is offline   Reply With Quote
Old 01-28-2010, 01:16 PM   #2
Kateaux
Kateaux's Avatar
Re: Which rear end is everybody using?
9" Ford
1958 3100 w/55 frontend and 55 Cameo Bed (in progress)
Kateaux is offline   Reply With Quote
Old 01-28-2010, 01:24 PM   #3
youngrodder
youngrodder's Avatar
10 bolt Chevy w/posi out of a Grand National...
youngrodder is offline   Reply With Quote
Old 01-28-2010, 02:47 PM   #4
blackdiesel
blackdiesel's Avatar
The guy's on trucks (tv show) put a 8.8 ford out of a explorer under there AD truck. I've put one under two 57's and my 38. You can get a low milage rearend with disc brakes and posi track that don't need to be rebuilt for 200 bucks. Do they make stonger rearends? YES, but not for that price.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 01-28-2010, 02:49 PM   #5
CAL 58 GMC
CAL 58 GMC's Avatar
10 Bolt with disc brakes out of a S-10 Blazer.
CAL 58 GMC is offline   Reply With Quote
Old 01-28-2010, 03:45 PM   #6
rjs53
94-01 I believe is the years for the explorer, claim to be as strong as a 12 bolt and their cheap
rjs53 is offline   Reply With Quote
Old 01-28-2010, 06:36 PM   #7
Kabwe
Certified Car Nut
Kabwe's Avatar
I would not worry about breaking a Chevy 8.5, 12 bolt or a Ford 8.8 with most applications. A 9 inch is over kill for most people ( I have one in my 55 210 454 and its over kill). Unless you have a serious motor and putting your foot in it all the time you don't have to have a 9 inch. Ring gears on a Chevy 10 bolt is 8.2, Chevy big 10 bolt is 8.5, 12 bolt is 8.875, Ford 8.8 is exactly that, and then you have the most teasured with bragging rights 9 inch. The rearend you chose should depend on the car's use. If your building a monster than you may want a 12 bolt or 9 inch, if you build a cruiser with a little pop to it you will be fine with a 10 bolt or Ford 8.8. I'm concerned with gear ratio and I love posi. for the kind of stuff I build.
Here is the rear thats in my truck. Its a Chevy 8.5 with posi 3.42 gears.
Kabwe is offline   Reply With Quote
Old 01-29-2010, 10:10 AM   #8
1952ssr
1952ssr's Avatar
I plan to use the rear from the '94 Z28 my engine and tranny came from, when I obtain 350 bucks. It is a 3:23 posi with disc brakes.
1952ssr is offline   Reply With Quote
Old 01-29-2010, 01:55 PM   #9
mylow53
mylow53's Avatar
ford 9" with 3:50 gears and limited slip.
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 01-29-2010, 02:04 PM   #10
1950 GMC
1950 GMC's Avatar
youngrodder, Is that rearend out of a coil car? What kind of set up are you running for your rearend, Leaf spring, 4 link, coil, etc?
Thanks,
Garrett
My 1950 GMC Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=351867
My 1950 GMC Photobucket Account:
http://s565.photobucket.com/albums/ss95/1950GMC/
1950 GMC is offline   Reply With Quote
Old 01-29-2010, 02:19 PM   #11
bjcaldwe
bjcaldwe's Avatar
I believe youngrodder has his truck built on the car frame that rearend came out of.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 01-29-2010, 02:56 PM   #12
youngrodder
Yes, you are correct. It was a modified G-body (Monte Carlo, Grand Prix, Grand national) 4 link frame set up by the PO. I bought it with a single track 10 bolt. I later upgraded to posi 10 bolt with disc brakes. I also changed the coil spring set up to air bags.
I still have the other rear end. I am looking to get rid of it cheap!!!!
Marc
Old 01-29-2010, 10:41 PM   #13
robgrin
robgrin's Avatar
I just picked up a 98 camaro rear end with 3:23 gears, posi, and disc brakes for $150.The only thing is it's kind of wide.
robgrin is offline   Reply With Quote
Old 01-29-2010, 11:11 PM   #14
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
67-72 Ford pick up fits nice. mine has a 68 12 bolt truck in it.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-30-2010, 12:17 AM   #15
NONHOG
NONHOG's Avatar
I read on Stovebolt which rears are what width and just happened on a 69 F100 9" 3.50 gear for 50$ off craigslist.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 01-30-2010, 12:54 AM   #16
pro1955
pro1955's Avatar
68 Camaro 10 bolt. 8.2 273 gears I want a freeway flyer.
Truck's just for the fun of it.
pro1955 is offline   Reply With Quote
Old 01-30-2010, 01:07 AM   #17
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
10-bolt Chevy from under a '73 Chevelle wagon. 3.08 gears.
Steve@OldSub.com is offline   Reply With Quote
Old 01-30-2010, 01:27 AM   #18
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Narrowed 9" from a 85 Bronco, came with 3.50 but now 4:11 Track Lock or Posi. I cut it down to 58".
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 01-30-2010, 03:31 AM   #19
mike16
every body's using a ford 9 inch. everybody else .......
mike16 is offline   Reply With Quote
Old 01-30-2010, 03:46 AM   #20
lonelywanderer
got a 12 bolt chevy in my 59
lonelywanderer is offline   Reply With Quote
Old 01-30-2010, 04:13 AM   #21
hotrodrookie
hotrodrookie's Avatar
im putting a '98 explorer 8.8 in my 59. 3.73 gears, lim slip, disk brakes, 59 1/2" flange to flange, $150.
hotrodrookie is offline   Reply With Quote
Old 01-30-2010, 01:37 PM   #22
rjs53
I was thinking of a 9" but have had a 8.2 in my chevelle for 10yrs with eaton and superior axles, have 150 1/4 mile passes on it started out running mid 12's now 11.30 yes it will break someday but if one can hold up this long with that kind of abuse then i know it will hold up to a street rod. I'm thinking of putting it under my 53 now that ive broken the 11.50 barrier NHRA rules no c clip. the 9" is as stated earlier in the topic over kill for the street but if thats what you want more power to you, it will be the last thing that will ever need to be replaced on you truck
Old 02-01-2010, 07:41 PM   #23
Lil'Debbie57
Lil'Debbie57's Avatar
does any one know which rear ends are 62"?
Lil'Debbie57 is offline   Reply With Quote
Old 02-02-2010, 09:40 AM   #24
tbrown5079
Late 60's early 70's chevelles are 62"
tbrown5079 is offline   Reply With Quote
Old 02-02-2010, 12:24 PM   #25
Steve@OldSub.com
The '73 Chevelle rear under mine is almost exactly 62 inches wide.
