Old 01-07-2003, 01:52 PM   #26
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
awsome, it will be alot cheaper than $899.00 for 6 lug disc brakes evenafter the drop spindles.
GMC JUNKIE TOO is offline   Reply With Quote
Old 01-07-2003, 02:40 PM   #27
JJR
JJR's Avatar
dream68 can you elaborate on the 88 truck you got the parts off of. Was it a 1/2 ton or 6 lug 3/4 ton? I have Hollanders on my laptop and would be able to post some info for folks. Hollanders does show the 67-70 vs 71-87 3/4 ton lower control arms being different. Which did you use? I have heard you could use the 88-91 3/4 ton 2wd 6-lug rotors on 71-up spindles using 71-up calipers. I went to Autozone and had them pull a 71 1/2 ton 5-lug rotor and a 88 3/4 ton six lug rotor and they were basically the same and appeared to use the same bearing.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 01-07-2003, 03:24 PM   #28
dream68
JJR: it was a 88 1/2 ton chev 2wd that all these parts came from. everything was ripped off the same truck, even the gearbox, but the gearbox will not fit...
'68 Chev C-10
'91 Western Star (workin wheels)
Just an ole time truckin idiot!
Jim G.
dream68 is offline   Reply With Quote
Old 01-07-2003, 04:42 PM   #29
JJR
JJR's Avatar
Hollanders shows two spindles used on an 88 c1500 2wd. One for a 1" rotor and one for a 1 1/4" rotor. The spindle for the 1" rotor came on 88-91 c1500 and had a 1 1/4" inner bearing surface diameter. The spindle for the 1 1/4" rotor(which is probably what you have) came on the following:
CHEVROLET PICKUP TRUCK 88 2500 Series; 4x2
CHEVROLET PICKUP TRUCK 88-91 1500 Series; 4x2, 1-1/4" thick rotor
CHEVROLET PICKUP TRUCK 89-91 2500 Series; VIN models "C/K", 4x2, 6 bolt wheel
CHEVROLET PICKUP TRUCK 92-98 1500 Series; 4x2
CHEVROLET PICKUP TRUCK 92-98 2500 Series; 4x2, 6 bolt wheel
CHEVROLET PICKUP TRUCK 99 1500 Series; exc. Silverado; 4x2
CHEVROLET VAN 96-99 1500 Series
CHEVROLET VAN 96-99 2500 Series; 7300 lb. GVW
GMC PICKUP TRUCK 88 2500 Series; VIN models "C/K", 4x2
GMC PICKUP TRUCK 88-91 1500 Series; 4x2, 1-1/4" thick rotor
GMC PICKUP TRUCK 89-91 2500 Series; VIN models "C/K", 4x2, 6 bolt wheel
GMC PICKUP TRUCK 92-98 1500 Series; 4x2
GMC PICKUP TRUCK 92-98 2500 Series; 4x2, 6 bolt wheel
GMC PICKUP TRUCK 99 1500 Series; old style (flat, pull-up outside door handle), 4x2
GMC VAN 96-99 1500 Series
GMC VAN 96-99 2500 Series; 7300 lb. GVW
SUBURBAN 92 1500 Series; 4x2
SUBURBAN 93-96 1500 Series; 4x2, vacuum brake booster
SUBURBAN 97-99 1500 Series; 4x2, gas
TAHOE/YUKON 95-99 4x2
'95 up have ABS sensors on the brake shield.
1-3/8" inner bearing surface dia.
Inner bearing consists of #LM48548 cone & #LM48510 cup.
Heavy duty chassis option code is F44..
15981299 R.
15981298 L.
For lower control arm: the 67-70 3/4 lower arm can come from the following:
CHEVROLET FORWARD CONTROL 68-70 20 Series
CHEVROLET FORWARD CONTROL 68-70 30 Series; 7200 lb. rear axle
CHEVROLET PICKUP TRUCK 67-70 20 Series
CHEVROLET PICKUP TRUCK 67-70 30 Series; 7200 lb. rear axle
CHEVROLET VAN 71 30 Series; drum brake
GMC FORWARD CONTROL 68-70 2500 Series
GMC FORWARD CONTROL 68-70 3500 Series; 7200 lb. rear axle
GMC PICKUP TRUCK 67-70 2500 Series
GMC PICKUP TRUCK 67-70 3500 Series; 7200 lb. rear axle
GMC VAN 71 3500 Series; drum brake
SUBURBAN 67-70 20 Series
SUBURBAN 67-70 2500 Series
If the 71-up 3/4 ton lower control arm can work they can come from the following:
CHEVROLET FORWARD CONTROL 71-72 30 Series; 7200 lb. rear axle
CHEVROLET FORWARD CONTROL 71-89 20 Series
CHEVROLET FORWARD CONTROL 73-78 30 Series; non-removable carrier
CHEVROLET FORWARD CONTROL 79-84 30 Series; drum rear brakes, sgl. rear wheels
CHEVROLET FORWARD CONTROL 85-92 30 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels
CHEVROLET FORWARD CONTROL 93 30 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels, w/o 9L6 brakes
CHEVROLET PICKUP TRUCK 71-72 30 Series; 7200 lb. rear axle
CHEVROLET PICKUP TRUCK 71-88 20 Series
CHEVROLET PICKUP TRUCK 73-80 30 Series
CHEVROLET PICKUP TRUCK 81-88 30 Series; std. duty susp.
CHEVROLET PICKUP TRUCK 89-91 2500 Series; VIN models "R/V"
CHEVROLET PICKUP TRUCK 89-91 3500 Series; VIN models "R/V", std. duty susp.
CHEVROLET VAN 72-78 30 Series
GMC FORWARD CONTROL 71-72 3500 Series; 7200 lb. rear axle
GMC FORWARD CONTROL 71-89 2500 Series
GMC FORWARD CONTROL 73-78 3500 Series; non-removable carrier
GMC FORWARD CONTROL 79-84 3500 Series; drum rear brakes, sgl. rear wheels
GMC FORWARD CONTROL 85-92 3500 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels
GMC FORWARD CONTROL 93 3500 Series; exc. hvy. duty front susp.; drum rear brakes, sgl. rear wheels, w/o 9L6 brakes
GMC PICKUP TRUCK 71-72 3500 Series; 7200 lb. rear axle
GMC PICKUP TRUCK 71-87 2500 Series
GMC PICKUP TRUCK 73-80 3500 Series
GMC PICKUP TRUCK 81-87 3500 Series; std. duty susp.
GMC PICKUP TRUCK 88-91 3500 Series; VIN models "R/V", std. duty susp.
GMC VAN 72-78 3500 Series
SUBURBAN 71-88 20 Series
SUBURBAN 71-91 2500 Series
This statement makes for some confusion: This arm (71-up) may have two different ball joints one being light duty, the other being heavy duty. I am assumming they would be different diameters.
I hope this info helps.
Old 01-08-2003, 01:15 AM   #30
ChopTop
Thumbs up COWABUNGA!!!
WHOA!
Member of the "Old Farts Club"
ChopTop is offline   Reply With Quote
Old 01-08-2003, 01:48 AM   #31
crazy longhorn
Fabricate till you "puke"
JJR,the info given to me on the 3/4 tons(from local napa) is the ball joints interchange from 71-86 or 87 on the pickups. I didnt see his book, so it was just info given to me. I do know from experience that the 71 3/4 ton lower ball joint will press into the 67-70 3/4 ton lower arms, but the steer stops are different on the older arms(same deal as the 1/2 tons, it will shorten the turning radius), & will require a little grinding on the stops on the spindles to straighten it up.......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-08-2003, 08:23 AM   #32
JJR
JJR's Avatar
That is good to know Crazy Longhorn. The local pull-a-part tends to have a good selection of 3/4 ton trucks and occationally an 88-up. The get $15 for control arms and spindles. I have also seen several sets of 88-up spindles on e-bay go dirt cheap. People put drop spindles on and basically give away the old ones. Since a already have a set of 71 1/2 ton control arms and spindles and new ball joints for them, I will probably end up buying a set of 6-lug rotors and use what I have.
Old 01-08-2003, 08:45 AM   #33
70c10
67-72 Addict!
70c10's Avatar
Cool!, This sounds like the next topic on the FAQ board, hopefully with a few pics!. Thanks guys.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-08-2003, 01:04 PM   #34
sixnine
Longtime Member
sixnine's Avatar
Man, this is the reason I just love this site! This changeover will definetly be on my list of improvements I plan to make over the next 2 years. I'll be enrolling in the Auto-Body program at the local Community College and the instructor said I could use the school shop and tools after hours. Do any of you see any interference issues if I were to use an '88-'95 dropped spindle with this swap? Dream 68.............keep us informed and post any pictures. Great job!
Rokcrln - "I'm a major car addict so trying to go as low buck as possible is like asking a coke head to use flower to save money."
1972 C10 Short Step -http://67-72chevytrucks.com/vboard/s...d.php?t=261405
sixnine is offline   Reply With Quote
Old 01-08-2003, 04:22 PM   #35
dream68
OK GUYS: the steering linkage is a tad sloppy in the spindle, so this is what you do. use the 68 intermediate shaft with the 88 tie rods. the inside tie rod end is changed to PART# : MOOG ES2020RL.(tie rod end). This setup fits and looks like a dream with no binding anywhere. the 88 tie rods are also bulkier than the 68 original setup..... I will be in touch with more updates as i go... KEEP ON TRUCKIN MAMA!!!!
'68 Chev C-10
Jim G.
Old 01-08-2003, 05:04 PM   #36
dream68
ALL PARTS NEEDED FOR BRAKE CONVERSION ON 68:::1968 1/2 ton top a-arm, 1970 3/4 ton bottom a-arm, 1988 1/2 ton ball joints(both), 1988 1/2 ton spindles, calipers, and rotors, 1968 1/2 ton intermediate shaft, 1988 1/2 ton tie rods, with the inner tie rod end changed to part#: MOOG ES2020. Brake lines can be changed if need be!!! GET TO WORK!!!
'68 Chev C-10
Jim G.
Old 01-08-2003, 05:25 PM   #37
wnc mountain
More hobbies than money!
wnc mountain's Avatar
This is great info...but...anyone know if this will work for a 70
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
Old 01-08-2003, 05:49 PM   #38
dream68
wnc mountain: i believe it should work because the boneyard told me the a-arms were the same from 68-70.
'68 Chev C-10
Jim G.
Old 01-08-2003, 08:42 PM   #39
wnc mountain
Thanks, I will have to give that a look. This may actually sway me to go with disks.
'72 Blazer project
