01-28-2010, 07:18 PM | #226 |
Re: How about some pics of '73-'91 Crew Cab Short beds?
cool man, Thanks!
I look forward to seeing yours also
CHEVY ONLY |
01-28-2010, 07:19 PM | #227 |
Joe, did you get to bring it home yet?
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
01-28-2010, 07:20 PM | #228 |
Crew Cut
you can reuse the same mounts, it will bolt thru both frames all of the holes will line up. also this way when you put short bed on the front 2 bed bolts will go in the one ton part of frame and the rest will go into the 1/2 ton frame. good luck joe
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
01-28-2010, 07:20 PM | #229 |
youre welcome, i will be starting on it in a month, i will get alot of pics and post up a build..
be a site supporter |
01-28-2010, 07:20 PM | #230 | |
yes sir!
I started a build thread, link in my sig Quote:
CHEVY ONLY Last edited by joe231; 01-28-2010 at 07:22 PM. |
01-28-2010, 07:21 PM | #231 |
thanks ojoe! sweet truck man!
01-28-2010, 08:56 PM | #232 | |
What I mean is, if you shortened the crew frame closer to the cab and conversley trimmed the lip of the swb frame closer to the cab (saving the bed bolt hole) would it make a difference?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
01-28-2010, 09:06 PM | #233 |
I'm not 100% sure I'm following you, the front bed holes on both frames will line up, so you will want to cut the 1 ton frame just behind the front bed mounting hole, and the 1/2 ton frame just to the front of the rear cab mount bracket, once you remove the cab mount brackets from each frame you can just bolt them back on through both frames practicably lining up both frames perfectly. as you can see in the pic, those gold-ish bolt heads are the bolts on the cab mount brackets that sandwich it all together. I personally would weld it all together after bolting it together, I believe OJOE did, not sure about toomanytoyz, but I would assume so. I would also angle the bottom of the 1 ton frame up and weld it for aesthetics.
CHEVY ONLY Last edited by joe231; 01-28-2010 at 09:09 PM. |
01-30-2010, 10:42 AM | #234 | |
Crew Cut
01-31-2010, 07:27 PM | #235 |
If I understand correctly, you need to trim off the top of the 1/2 ton frame for clearance when inserting it into the 1-ton frame?
Do you start trimming after the bed mount holes? So the front-most bed mount holes will overlap between the two frame sections. When mounting the bed the bolt will pass through both frames?
01-31-2010, 07:39 PM | #236 |
No
the 1/2 ton frame is much shorter, look at the pic. No trimming required. The front bed bolt holes will line up on both frames, as well as the rear cab mount bracket holes.
CHEVY ONLY Last edited by joe231; 01-31-2010 at 07:43 PM. |
02-04-2010, 01:48 AM | #237 | |
That was in response to this. Which got this response. Please don't take this as arguning. I just don't want to miss anything important, no matter how trivial it might seem.
02-04-2010, 10:02 AM | #238 |
Ok
now I see what you are talking about. By toomanytoyz pics it does appear that the top of both frames are in line. Makes sense to me if you want all the holes to line up.
CHEVY ONLY |
04-13-2010, 04:21 PM | #239 |
Here is my progress.
Due to time restraints and having to get the parts truck out of my hair I had the work done. By a member here incidently. He is going to send me some pictures of the work in progress and I will create a build thread at that time with all the pictures I have to date. Which isn't a lot... The truck is sitting on jack stands that are 6” lower than with the wheels on. That is roughly how low it will sit after I do the flip kit on the rear axle. BUT…. I made that measurement with the roller wheels (31x10.50) on there; I will be running 275/60-15 tires which are roughly 28” tall. So it should be around 1-1/2” lower than that. Also, the rollers on the front now are 235/75-15. I will be running 255/60-15 tires on the front. That is about 1-3/4” difference, so about 7/8” lower in the front too. I think the 3” coils in the front are too much (with the 3" spindles) and will have to go and either cut one coil off the stock springs (1” lower) or buy 1” lowering springs. The front suspension was pretty beat-up/warn-out so it might be best to just buy new springs. Everything else is new in the front so why try to cut cost now? I saw Bigarmz post about lowering his truck 5/7 and it doesn't look too ridicuously low so maybe 2" springs in the front? I will have to see just how it sits when the rear is done. Right now, I might not even be able to get it out of my driveway… PS; frame is done I just don’t want to put the short-bed on until I see if I need to c-notch the frame. I am going to clean up the gas tanks a bit, get the driveline shortened, alignment and it should be road ready.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 04-13-2010 at 04:22 PM. |
04-13-2010, 09:37 PM | #240 |
Looks nice Kevin!!!
What wheels are you planning on running?
CHEVY ONLY |
04-13-2010, 11:17 PM | #241 |
Actually, 15 x 8 chrome rally's.
With brand new OEM GMC centers. I understand that with the 3" spindles I am going to need to trim the LCA's, but I rally like the rally's. Ultimately this won't be a show winner, but a cool driver. A stock-but-not look using GM (looking/mostly) parts but in not so stock applications.
04-28-2010, 07:57 PM | #242 |
well, its official, i finally pickud up the sawzall and joined the ccsb clan! last weekend my crew cab dually met its fate and started down the path to its new life. and i am psyched, i have to say these trucks look even better in person than the pictures! ill get pics of mine up soon! but heres a couple b4 pics for a teaser
the fleet..... 57' shortbed stepside 4x4 72' longbed cheyenne super 4x4 78' blazer lil lift w/ chalet 84' shortbed lowrider aka "troubletruck" 84' 1 ton crew cab dually lifted 8" on 38.5 boggers 87' burb shes my daily 89' blazer, wheelin/plow rig 8?' blazer chassised super short stepside |
04-28-2010, 08:05 PM | #243 |
One day...
Very cool truck!
04-28-2010, 09:02 PM | #244 |
Nice!
I can't wait to see that as a short bed!
CHEVY ONLY |
04-28-2010, 09:06 PM | #245 |
Very nice wish you were closer I would buy the dually bed.
04-28-2010, 09:06 PM | #246 |
One day...
Road trip!
04-28-2010, 09:30 PM | #247 |
I was hoping he was gonna keep it a dually
CHEVY ONLY |
04-29-2010, 01:06 AM | #248 |
Glen
That truck is a BAMF! I'd hate to buy new tires.
Glen Simpson Severed Ties - Oregon Roseburg, Oregon
Past Trucks
04-29-2010, 05:18 PM | #249 |
thanks guys, yeah it always was a pretty badass rig, but it was time for change, this truck has had many transformations. when i bought it it was 2wd but that didnt last long. up here in the northeast we like them big trucks lol
04-29-2010, 07:41 PM | #250 |
Tags |
ccsb crew cab short |
