01-30-2010, 02:46 PM | #1 |
Engine n00b
Removing brake drum rivets..
before I pull out the grinder, I want to confirm these are the three brake drum rivets I need to grind off..
If anyone can answer quickly - I have the thing up on jackstands and really want to get this done today. I am kind of shocked to see intact rivets.. the truck is 40 years old. Also, I have already adjusted the brakes all the way up and down, so I know the shoes are not holding it on Last edited by chrislehr; 01-30-2010 at 02:49 PM. |
01-30-2010, 02:49 PM | #2 |
member #16
Re: Removing brake drum rivets..
Yes that would be them.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-30-2010, 02:50 PM | #3 |
their the ones, you may have to grind them off and knock the hub out of the drum and then grind some more to knock them out the hub
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
01-30-2010, 02:50 PM | #4 |
Eliminating those rivets will allow you to separate the drum from the hub. They are a little harder to handle/reinstall, when separated, but you have to start somewhere!
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! |
01-30-2010, 02:51 PM | #5 |
Engine n00b
Wait... reinstall?
I thought they were throw aways and not needed really.. educate me if not, cause I dont have a riveter! |
01-30-2010, 03:08 PM | #6 |
Hollister Road Co.
You don't have to rivet them back on. I drill them out with a 1/4" bit almost all the way through and chisel the head off and punch out the rivet.
01-30-2010, 03:26 PM | #7 | |
Engine n00b
Its making me wonder if my odo is 49k or 149k. |
01-30-2010, 06:13 PM | #8 |
its all about the +6 inches
the stock trums were made properly when men were men and steel was steel. They have been known to last well over 100k.
If your originals are still good, then put them back on. The replacement ones are junk IMO. |
01-30-2010, 06:29 PM | #9 |
Engine n00b
I guess I should have made post #1 clearer - I was trying to check the pads. Luckily, didnt get the rivets all out before I was told to remove the axle bolt/dust cover. Doh.
01-31-2010, 01:44 AM | #10 |
Engine n00b
while I have a thread going - whats the purpose of the spring coil wrapped around the drums?
01-31-2010, 02:10 AM | #11 |
Junior Member
my guess is the springs were used to keep tention on the drum from warping when getting hot or overheated. But not shure!! some one can chime in and educate me
also when hammering the rivets out, Be careful!! i kind of got crazy with the hammer and bent the wheel hub in three places where the rivet sat and i was really shock i actualy bent the hub!! I would prefer to drill the rivet out completely
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts?? |
01-31-2010, 02:18 AM | #12 |
Self Made Hundredaire
The spring was used to quiet the harmonics. That's the only use I know for them.
'79 corvette - all original 49k car! '03 Z71 ECSB - gas hog '57 Belair 2 door hardtop. Love of my life! |
01-31-2010, 02:30 AM | #13 |
I agree with the harmonics... a slight ringing can be heard if the spring is missing, some will tell you it is for cooling though.
01-31-2010, 03:28 AM | #14 |
yup the spring around the circumference is there to dampen harmonics that could cause unwanted noises during brake application.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
01-31-2010, 03:43 AM | #15 |
Some guys have to knock the rivets off so alloy wheels will seat flat on the drum but the only other reason to cut them off would be to replace the drums. By the way, drum brakes don't have "pads" they have "shoes".
01-31-2010, 05:13 AM | #16 |
My 68 still had the darn rivets in place and I'm sure my truck has a billion miles on it. Shocking that they last so long.
01-31-2010, 04:00 PM | #17 |
Junior Member
As you can see the bend in the hub from hammering on the rivet after the head was grounded off, it was bent all the way around where the rivet sat!
I didn't realize it was bent after 5,000 to 10,000 miles driving on the new shoes and drums. I didn't get any vibrations at all luckly!! both drums still in good shape and no lip but different type! one has rivet holes and the other without, both were bought at the same time here at Chicano Zone!! going to get rid of these and switching to front and rear disk later in my build
01-31-2010, 07:39 PM | #18 |
they also don't have the holes for adjusting the shoes up, or the lip for the spring.
01-31-2010, 10:13 PM | #19 |
Hollister Road Co.
This is the reason for drilling the rivets almost all the way through. When you drive them out the colapse inward and come out very easy.
