01-13-2010, 10:50 PM | #1351 |
Junior Member
Re: Daverods project 66
I vote silver or not at all
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
01-14-2010, 12:50 AM | #1352 |
Sunburst C10!!!
i wouldnt paint it
Gage 1967 C10 Shortbed Stepside |
01-17-2010, 12:54 AM | #1353 |
SSN 706
Got alittle done today. Work on it tomorrow too. Not to sure how to hook up the throttle linkage or the water to the manifold. Maybe hook it up inline with the hoses going to the heater?
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-17-2010 at 12:58 AM. |
01-17-2010, 01:47 AM | #1354 |
60-66 Nut
For the throttle linkage, you could fabricate a kind of bellcrank setup that would bolt onto the rear carb studs. Either that or convert to a cable throttle.
01-17-2010, 01:54 AM | #1355 |
HOW long until spring??
Dave-- I read something on stovebolt (or somewhere??) about the carb positioning on a Six. I think It said to turn the 4 barrel carb sideways so the primary's fed evenly to front and rear as the six intake is a long rascal and the primary's are closer to the front in your picture. Recall some controversy on whether you get equal fuel to the front and rear cylinders. Maybe others can enlighten us both on this matter.
OR just keep the throttle down and the secondaries working and you should be fine!!!
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
01-17-2010, 10:31 AM | #1356 | |
SSN 706
Thanks Capt I might just go with a cable |
01-17-2010, 10:46 AM | #1357 |
SSN 706
ideas. I was thinking about turning the carb. It seems no matter what the center cylinders would get more gas then the end ones. I do see how it would be more even. Looks like 1/2 turned 1/2 not turned.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-17-2010 at 11:08 AM. |
01-17-2010, 12:10 PM | #1358 |
Sunburst C10!!!
hey dave do you have a link to that last pic that engine looks awesome
01-17-2010, 12:43 PM | #1359 |
Junior Member
I turned mine 90 degrees and it didn't make any difference in performance. Most die hard inliners say it does...perhaps if you racing......
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! Last edited by ol Curt; 01-17-2010 at 12:43 PM. |
01-17-2010, 02:35 PM | #1360 | |
SSN 706
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-17-2010 at 02:36 PM. |
01-17-2010, 03:01 PM | #1361 |
Sunburst C10!!!
i wish i knew more about it that looks like a pretty big carb for a 292
01-17-2010, 08:24 PM | #1362 |
Dave I wonder if anybody has ever done a dyno test on a 4 barrel VS.two or three deuces for flow and horsepower? It makes sense that three carbs would flow fuel better to the end cylinders.
01-17-2010, 09:42 PM | #1363 |
Junior Member
Bubba
I'm sure they have...reference Leo Santucci's Chevrolet Inline Six Power Manual. Lots of good info in there.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! Last edited by ol Curt; 01-17-2010 at 09:42 PM. |
01-17-2010, 09:52 PM | #1364 |
Junior Member
Dave,
I can't find a pic her at home, but i know I saw one at work the other day of mine with a Holley 390 on it and turned sideways. I got the carb at either Jegs or Summitt and I'm sure the bellcrank came with it. They probably sell them seperate. I'll look dor the pic when I go back on Tuesday.
01-17-2010, 11:05 PM | #1365 | |
SSN 706
01-17-2010, 11:08 PM | #1366 |
SSN 706
I wanted to do the 3 carb thing but this seemed a lot easier. The main reason I got this was because of the heated bottom. I think the 4 barrel would get better gas mileage. Anything has to be better than what I started with.
01-30-2010, 01:13 AM | #1367 |
SSN 706
Getting better at the ebay thing. Did'nt fall asleep this time. Did'nt drink to much rockstar and hit the wrong buttons. Got a rear roll pan for my 64,new still in the box. Waited till three minutes left. Won the bid by .50. Too funny. Got my carb linkage done. Hooked up the water to the manifold. Need to hook up the clutch linkage.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-30-2010 at 01:16 AM. |
01-30-2010, 01:36 AM | #1368 |
Sunburst C10!!!
awesome
so how much did you get the roll pan for
01-30-2010, 10:21 AM | #1369 |
SSN 706
75.50 Not a steal but I was going to buy one anyway. Every little bit helps. Just sold the seat off my sled for 100 so that covered it.
01-30-2010, 07:01 PM | #1370 |
SSN 706
Getting closer. Almost fire in the hole.
01-30-2010, 07:07 PM | #1371 |
SSN 706
Pulled my spark wires off when I painted the engine. Should have taken a picture. Thought I was being smart and just looked at the last engine picture in my thread. The black engine looks good but his wires are off one hole counterclockwise. Once I moved all the wires one hole she fired right up. Got a oil leak brhind my dash to fix, if I even hooked it up. Water leak in the thermohousing guess I should have used a gasket and sealer?
01-30-2010, 07:07 PM | #1372 |
Junior Member
I like it!! Fire that thing up!
01-30-2010, 07:11 PM | #1373 |
Registerd User
I just got caught up on your build and it's looking good spud.
01-30-2010, 07:41 PM | #1374 |
SSN 706
Fire in the hole. Nothing like the sound of open headers. I think I'm going for a drive. Turn the sound on your computer all the way up to get the true sound.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-30-2010 at 07:48 PM. |
01-30-2010, 07:45 PM | #1375 |
SSN 706
Any ideas on where the distrubator vac line hooks onto the carb? Also where does the hose from the valve covers go? Into the carb or into the manifold?
