Old 02-01-2010, 12:07 PM   #426
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project NOT4SLE
Originally Posted by vegaschevy View Post
All the arms as far as I know are identical. The difference in the drop comes with a spacer provided for on top of the coil for the 2" drop and 3" drop you just use the arms no spacer for the coil.
I currently have 3 extra" of drop along with a 5" drop spring. I need to be around 7"
With my tire combo it is perfectly centered in the wheel well however it will still touch both sides of the tub under load.
im going to cut just over 1/2 coil off today on the front to get it where I want it I hope and then ill raise the rear to get clearence
I have a set of Nates trailing arms that are only 2" drop.
Maybe he's making only 3" drop arms now. (And using a spacer as an option).
3" is too much for scrub line issues with 15" wheels. That why I order just the 2" drop.
Old 02-01-2010, 01:32 PM   #427
highperf4x4
Re: Project NOT4SLE
That's what I was afraid of.
highperf4x4 is offline   Reply With Quote
Old 02-01-2010, 01:49 PM   #428
vegaschevy
Re: Project NOT4SLE
Ya I dont know. Maybe he sold me the wrong ones and has a fix, or maybe hes just making one size and spacing for the extra, which either way works. I PMd him a few days ago and still have not heard back.
I need to get the rear up at least an inch though. And I need ot get the front down I think about an inch as well.
vegaschevy is offline   Reply With Quote
Old 02-01-2010, 02:49 PM   #429
SCOTI
SCOTI's Avatar
Re: Project NOT4SLE
I believe this is correct.
I installed mine on my chassis & realized they were the 3" units & not the 2" I thought I was getting. I checked the scrub-line concern & it was flush w/the lip of a 15" wheel as measured from the lowest portion of the truck arm. The 3" shock brackets were definitely below scrub for a 15" wheel. After conversing w/Nate, he might just be offering the one arm, spacing the spring for the drop difference, & using the shorter 2" shock bracket.
Check w/him to be 100% accurate though .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-01-2010, 02:58 PM   #430
vegaschevy
Re: Project NOT4SLE
crap, i wonder what rear shock brackets I have then... Hmmm
Ill have to call him shortly. My rear is just a tad to low.
I left the front springs for now awaiting raising the rear and it may not make the front seem to tall.
Switched all my steering around and the alignment shop is ready to align it tomorrow morning at 9am
Old 02-01-2010, 03:48 PM   #431
big_al_71
big_al_71's Avatar
Re: Project NOT4SLE
I am really loving the rear that low, if you lower the front to match the rear watch out!!!!
I have a six inch lowering spring from ECE and a 295/40/20 on a 20x10 Coy wheel just like you and mine definetly is not even close to what yours looks like...
Great progress.....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-01-2010, 04:00 PM   #432
lolife99
lolife99's Avatar
Re: Project NOT4SLE
Now you've got me second guessing.
I need to look at mine again.
I know that I did order just the 2" drop.
Old 02-01-2010, 05:08 PM   #433
vegaschevy
Re: Project NOT4SLE
Great progress.....
the front is 4.5" dropped. I think it will look fine once I raise the back up another inch. I think it will balance out really nice.
Old 02-01-2010, 06:13 PM   #434
vegaschevy
Re: Project NOT4SLE
Went and put 20 miles on the truck today before heading to work at midnight with it. Front seemed very nice the rear is harsh and bottoming out on something.... Cannot wait to get it smoothed out!!
So far everything seemed to be dialed
Old 02-01-2010, 07:52 PM   #435
Smallz72project
Smallz72project's Avatar
Re: Project NOT4SLE
Truck is looking amazing! Glad you were able to get the steering figured out. I did notice in your post regarding the spindle nut that you were concerned about hte castle nut being too far down from the cotter pin hole. I havent taken mine apart in some time, but I wanted to ask...do you have the spindle nut tightened right against the bearing? If my memory serves me, you should have a slotted washer that goes between the bearing and the nut. I have seen too many times bearing just completely descintegrate from this if not caught early on.
- 1967 Chevy C10 shortbox
- 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project
- 1986 Chevy K10 LWB 350/350 Daily Driver/project
Last edited by Smallz72project; 02-01-2010 at 08:20 PM. Reason: added illustration
Smallz72project is offline   Reply With Quote
Old 02-01-2010, 08:13 PM   #436
lolife99
lolife99's Avatar
Re: Project NOT4SLE
I have a correction to make,...
Mine are 3" drop.
(which really surprises me).
I measured from the top of the plate, where the rear axle housing rests,... to the top of the 2" tube itself.
I know I asked for 2" drop.
Hmmm,...
Old 02-01-2010, 08:44 PM   #437
vegaschevy
Re: Project NOT4SLE
yes, washer is in there as well. Ill check it in a couple thousand miles and see if it will be a problem.
Old 02-01-2010, 08:54 PM   #438
PBFAB.COM
PBFAB.COM's Avatar
Re: Project NOT4SLE
Let's clear up all the confusion on the arms... The trailing arms themselves ALL have 3" of drop built into them. The differences between the 2" drop and 3" drop arms are:
-The shock brackets are different
-The 2" drop arms come with a cup that goes between the top of the spring and the frame.
Devin-
Your cups will be in the mail tomorrow.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-01-2010, 09:00 PM   #439
vegaschevy
Re: Project NOT4SLE
Devin-
cool, have pics of both styles of shock brackets?
Old 02-02-2010, 06:57 PM   #440
vegaschevy
Re: Project NOT4SLE
Trucks all aligned but on the way to work last night it started making a funky noise. Like the carrier bearing has the dust cover spinning loosely and sometimes make a crazy viberation high pitch squealing sound
Old 02-02-2010, 07:05 PM   #441
fencepost
fencepost's Avatar
Re: Project NOT4SLE
Just drive faster it'll stop.
fencepost is offline   Reply With Quote
Old 02-02-2010, 07:20 PM   #442
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Project NOT4SLE
So what's next?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-02-2010, 07:43 PM   #443
lolife99
lolife99's Avatar
Re: Project NOT4SLE
Is this the original drive shaft,... or did you build a new one.
Could it be too long, now that your truck is lowered?
Old 02-02-2010, 11:11 PM   #444
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Project NOT4SLE
have had a similar sound from my trucks r/e before....spun bearing race?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-02-2010, 11:31 PM   #445
highperf4x4
Re: Project NOT4SLE
Yeah, you're probably bottoming out the slip shaft behind the carrier bearing.
Old 02-02-2010, 11:47 PM   #446
lolife99
lolife99's Avatar
Re: Project NOT4SLE
If this is the original 2-piece drive shaft there is no slip yoke behind the carrier bearing.
Just one at the transmission, and a u-joint in the middle.
I lowered a lwb truck 20 years ago,... and I had to shorten the rear shaft, of the 2-piece drive shaft.
A slip yoke style setup like the later model trucks would be an improvement
Old 02-03-2010, 02:12 AM   #447
vegaschevy
Re: Project NOT4SLE
Originally Posted by 72BlckButy View Post
So what's next?
67 front fenders, grill, core support and cowl hood. Get the front end looking well GOOD!!! LOL I will do all new cab mount bushings, core support stuff and everything pretty much new down to the little details on the front sheet metal.
It is possible, It was COMPLETELY fine until the front was lowered as well.
I still had play at the transmission or at least enough. I was thinking about pulling the bolts out of the carrier bearing and eggin out the holes a hair as if it is bottoming out it is VERY VERY minute. could be fixed with moving the carrier bearing forward a thousands of an inch.
It does not do it at all when cold. only when hot.
With the truck lowered not so easy, in fact impossible to climb underneath to figure it out... HAHAHAHA
Old 02-03-2010, 06:41 AM   #448
lolife99
lolife99's Avatar
Re: Project NOT4SLE
Hmmm,... I didn't know it was fine before the front was done.
Got any pics of the driveshaft installed?
Old 02-03-2010, 04:02 PM   #449
vegastwinturbo
vegastwinturbo's Avatar
Re: Project NOT4SLE
Hey vegaschevy trucks lookin good i think you should bring it by on your day off so we can throw it up in the air and look at it
vegastwinturbo is offline   Reply With Quote
Old 02-03-2010, 10:29 PM   #450
highperf4x4
Re: Project NOT4SLE
Thanks for the info.
