Old 02-01-2010, 06:51 PM   #1
cleszkie
cleszkie's Avatar
Blazer Pics
Just washed my Blazer and it was lookin good so I took some pics. Also included one of Mini Me (F**d Bronco) since it was around.
cleszkie is offline   Reply With Quote
Old 02-01-2010, 06:52 PM   #2
cleszkie
cleszkie's Avatar
Re: Blazer Pics
Couple more...
Old 02-01-2010, 08:05 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Blazer Pics
I really like it. Has that vintage late 70's early 80's vibe with the accessories and white steelies. Do you have a pic of all the accessories under your dash? I am curious what all that is. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-01-2010, 08:17 PM   #4
swyfor5
swyfor5's Avatar
Re: Blazer Pics
Very nice!
swyfor5 is offline   Reply With Quote
Old 02-01-2010, 08:22 PM   #5
cleszkie
cleszkie's Avatar
Re: Blazer Pics
Trevor -
Under the dash I have the radio/CD player head unit with a CB unit below it. Next to that I have a gauge cluster with temp, volt, and oil pressure (the stock gauges work, but I like to have a second opinion!). Next to the gauge cluster is my Gear Vendors overdrive toggle switch.
Next to be added is A/C, and a vintage Hickey Sidewinder winch I picked up a couple years ago.
Old 02-01-2010, 08:32 PM   #6
1949gmc
Re: Blazer Pics
I love looking at pics of this truck! I have the post from last May saved in my bookmarks and I must've gone back and looked at that thread a thousand times. Damn this makes me wanna get my tub-o-rust done. Great looking truck! I'm jealous.
1949gmc is offline   Reply With Quote
Old 02-01-2010, 10:01 PM   #7
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: Blazer Pics
Thats a cool Blazer. Looks great. I too dig the white rims.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 02-02-2010, 12:48 AM   #8
BLUE THUNDER
BLUE THUNDER's Avatar
Re: Blazer Pics
Looks awesome. Seeing yours on all the road trips really got me goin to get mine on the road. I have been driving it as my daily for the last 5 months. The Bronco looks good too.
BLUE THUNDER is offline   Reply With Quote
Old 02-02-2010, 10:51 AM   #9
Yukon Jack
Yukon Jack's Avatar
Re: Blazer Pics
That's one sweet K5! The rims and tires are perfect for it.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-02-2010, 12:21 PM   #10
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Blazer Pics
Very, very nice looking. I'm diggin' the meaty tires on the steel wheels! That Bronco is sweet too!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-03-2010, 09:25 PM   #11
rads42
Re: Blazer Pics
Great looking truck. Can you provide some details on the wheel/tire/lift sizes?
rads42 is offline   Reply With Quote
Old 02-03-2010, 09:40 PM   #12
cleszkie
cleszkie's Avatar
Re: Blazer Pics
Rads42 -
It has a 6 inch lift with Superlift springs on all corners. I removed one leaf from each of the front packs (second from the bottom) to level it off and soften the ride. Rims are 16.5 x 9.75 with 5.5 inches of backspacing. These came off the rear of two early seventies 3/4ton Custom Campers. The tires are 35 x 12.50 x 16.5 Parnelli Jones Dirt Gripz that measured a true 35 inches when new. I did some very minor trimming on the front fender "fangs" to allow for no rubbing during full steering lock and suspension compression.
Old 02-03-2010, 09:51 PM   #13
yellow70GMC
yellow70GMC's Avatar
Re: Blazer Pics
That's a gorgeous blazer. Nice bronco too. How do you like the gearvendors unit? Was it hard to install?
1970 GMC 4x4 swb fleetside
custom 4 inch lift with rear shackle flip, mild sbc, tci trans, rebuilt np205 w/twin shifters
yellow70GMC is offline   Reply With Quote
Old 02-04-2010, 02:55 PM   #14
cleszkie
cleszkie's Avatar
Re: Blazer Pics
YellowGMC -
The Gear Vendors unit was very easy to install. When I found it, it was bolted behind a TH400, so I had to locate the NP205 adapter (found it on ebay). After that it just bolts onto the back of the NP205 case. I did have to cut off my spring perches and re-weld them to rotate the pinion up so it pointed at the Gear Vendor output shaft. Due to the angle at the output shaft end (11 degrees), I had to use a CV joint with a 400 series (32-spline) slip yoke. Found that mid 80's Cadillacs used these (1310 Series), so I pulled one from a bone yard, took it to my driveline shop and had them make me a rear driveshaft. Everything works great. Having the overdrive is the best improvement I think I have ever made to the truck.
