Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-01-2010, 08:39 PM   #1
tomtuna1978
stock gas tank sumped ?
has anyone sumped the stock gas tank behind the seat ? im thinking about doing this to save a few $, and was wondering if anyone has done this and might have photos? thanks guys !
tomtuna1978 is offline   Reply With Quote
Old 02-01-2010, 09:14 PM   #2
djracer
djracer's Avatar
Re: stock gas tank sumped ?
Don't do it. Find a used cell to move to the rear.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-01-2010, 09:29 PM   #3
tomtuna1978
why ? djracer
Old 02-01-2010, 09:36 PM   #4
djracer
djracer's Avatar
If you shop around you can get a deal on a used cell. I have bought two 16 gallon cells used for less than 75.00ea. I would not want the fuel smell in the cab. Moving the weight to the rear helps with weight transfer. I take my hot rods to the track.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-01-2010, 09:38 PM   #5
Wild83C10
Wild83C10's Avatar
I don't think it can be done without modifying cutting a big hole in the back of the cab. Besides money what advanatage do you see?
Buying a cell and mounting in the bed is safer, easier and it moves weight to the rear where you need it.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-01-2010, 09:44 PM   #6
tomtuna1978
the bed on my truck is perfect and freshly done. and i dont wanna cut it up. so i figured that it would be easier and cheeper to do the stock tank. i would do hard lines out the cab and id try to aim it out the stock hole and use the stock 3/8 line as the return. im also planning on converting it to e85. because ive alredy got the fuel system.
Old 02-01-2010, 10:09 PM   #7
djracer
djracer's Avatar
They can be done under the bed floor.
does your truck have a wood floor or steel?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-01-2010, 10:26 PM   #8
tomtuna1978
http://67-72chevytrucks.com/vboard/s...d.php?t=377135
just found this thread ... this might be a good option
Old 02-01-2010, 11:09 PM   #9
iceman3085
iceman3085's Avatar
buy a , or find a tank to mount under the bed and sump it, ive done it a few times on late model mustangs
iceman3085 is offline   Reply With Quote
Old 02-01-2010, 11:13 PM   #10
1971gmcshortbed
1971gmcshortbed's Avatar
Hi Bud, Get the fuel out of the cab and get some speakers behind the seat, If you think gasoline smells wait till you smell E85...
1971gmcshortbed is offline   Reply With Quote
