#76 |
Re: Project: Recycle
nice work!
#77 |
dvcawefg
GB |
#78 |
![]() Join Date: Mar 2004
Subscribed!
#79 |
Nice work
#80 |
Not much progress as I'm trying to source parts which ultimately effect planning direction....
I picked up the aluminum material that will be used for re-positioning the rear axles center-line back approx 1.5". My plan was to utilize a solid piece of alum but the limited size & amount I needed rendered a significant jump in price. I decided to go w/what was readily available & used some 'drop' material from my local steel yard. One local metal supplier wanted $70+ for what I needed (which I had a few choice words for), so my steel yard let me scour through their alum scrap stack & these 2pcs (.500" x 3" x 21" total) cost me < $7. I'll have to stack them but it really won't impact their function....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-09-2010 at 12:44 AM. |
#81 |
While @ the steel yard, I also picked up some 4.5" OD steel pipe needed to complete some new rear bag mounting 'hats'.
The rear suspension was originally set up w/OE truck arms & shop built 2" lowering blocks which put the bag @ the exact installed height needed. I've since swapped some Porterbuilt 3" drop TA's which altered my height requirements. My c-notch is the limiting factor on ride height so even w/the 3" dropped TA's vs. the OE TA's w/2" block, I don't get any more drop. The PB TA's do allow me to use the 'hats' for mounting the bag which means no drilling a bunch of holes in the frame. I can also adjust the exact height of the hat so the bag travel & compression is optimal (which I did ![]() Instead of the upper stud being centered in the mounting plate/hat, it will be off-set which allows me to use the existing OE coil-spring mounting holes even though the rear is not @ the OE dimensions. In the last pic, the OE upper hole location is just inside of the leading edge of the round tube....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-09-2010 at 01:02 AM. |
#82 |
I've still been searching for a smooth, flat, square fuel-fill 'door' but haven't been able to hit the local wrecking yards. I've been walking through my local parking lots documenting vehicle types that might be possible donors.
If I can't find what I want, I went ahead & sourced the part needed for 'Plan-B'. It's stainless steel, 1.5" OD fill tube (1.25" ID), & relatively small. I've seen them used & like their simplicity but I'll need to do something to eliminate the 'shiny' appearance. The last pic is an example of a similar set-up installed....
#83 | |
Village Idiot....
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
#84 |
Under Construction
Nice progress Scoti.....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#85 |
I'm thinking more along the Darth Vader look & make it disappear w/the bed liner. You still in town?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-09-2010 at 09:54 AM. |
#86 | |
I'm just glad to be here!
Scoti - I thought that the Porterbuilt TA's moved the center line of the rear axle back that 1.5"? or am I missing something?? What about just moving the cross member back the required 1.5"? On another note, can you get a measurement for me? I no longer have a stock rear end houseing. I need to know how far part the mounting pads on the axle are? A measurement from the center of the rear hole (for the u-bolt) to the center of the other rear hole and the same for the front holes would be helpful. Thanks in advance.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 02-09-2010 at 10:47 AM. |
#87 | |
As for moving the c.member back, that's one method among several options. I figured by using the alum spacers, I can fine tune the exact dimension I want vs. drilling more holes & limiting the placement options (what if I need more/less that I thought??). I'll try & get you those housing pad dimensions tonight.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-09-2010 at 11:41 AM. |
#88 |
Thanks Scoti!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#89 |
The recent weather plus my work schedule kept me from the shop from Wednesday on. I should get back out there tonight or tomorrow.
#90 |
283 Drama Queen
![]() Join Date: Dec 2004
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
#91 |
I fully understand. No worries, whenever you get it, I am still a ways from that part of my build. Thanks again.
#92 |
I worked late but managed to source the necessary hardware for completing the truck-arm spacers. Maybe tomorrow I'll get some 'quality time' @ the shop & finish welding the rear bag hats (and take a couple measurements
#93 |
Chip . . .... chip.... chip. A little here, a little there; progress is progress.
I finished up the rear bag 'hats' (well.... almost). I still need to add a stud that will align w/the top OE frame hole for the spring (it will be offset to accomodate the set-back on the rear end). I didn't have long enough bolts so I'll source them & get these wrapped up by this weekend. The set-back worked out just right as the 'hat' just nudges the rear OE rivets that retain the reinforcement plate for the springs. Installed (ride) height for the bags is 6-6.5". When dumped, they should hit the internal bump-stop @ the same time the axle tube bottoms out on the frame c-notch....
#94 |
Under Construction
Nice work Scoti!
#95 |
Looks good, another scratch on the list.
#96 |
VA72C10
![]() Join Date: Mar 2008
nicely done!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#97 |
Thanks guys!
#98 |
chevy only
![]() Join Date: Sep 2006
HOLY SH-T WHAT A NICE JOB!!! this is going to be a badd a$$ , i love the fact how clean you work and how precise you fab stuff is, the quality of your work is killer nice job kat!!
CHEVY ONLY... Nothin Else ! |
#99 |
![]() Join Date: Aug 2005
Just found this and subscribed. Love the upper shock mounts and exhaust route path Scoti. I went with 1" longer PB arms and figure the adjustable del spheres will give me enough room to play with fore/aft. Might have to use the spacers on my 64 though. BTW, I'm in Austin next week. Might have no choice but to check this baddog out
#100 |
Good job it is really looking good.
65' C10 (working on cab currently) 06' Silverado ![]() |
