#201 |
Resistance is Futile
Re: 1964 Suburban Pics
I picked it up new from a guy who bought the wrong one. It was supposed to be for a 3/4 ton Blazer.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#202 |
nice burb. Whats the plan for the bbc
#203 |
Clean it, paint it, hook it up, attach all the accessories, and burn some gas
#204 |
Here's a little progress. A clean and painted engine for the swap. A nice shot of some brackets getting the degreaser treatment.....and for anyone considering a BBC swap, here is the measure you need. With the clam shell mounts on the block you will need your mounts approx 16.75'' apart. This is the centerline of the holes in the clams.
Lastly, the engine is just about in one piece again with a bunch of Felpro gaskets.
#205 |
Member of the longbed union.
What brand of paint did you use? and did you primmer it first?
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#206 |
I used Duplicolor Chevy Orange Engine Paint #1620; rattlecans. They do make a primer, but it doesnt specifically say to use it. I cleaned the crap out of the block and then wiped it down with wax and grease remover before finally spraying. It was on the cold side, so I did about 3 med/thin coats.
#207 |
I was just wondering, I sandblasted mine and used wax and grease remover. I used VHT orange. I did it in July and it's been sitting since. I was just worried about it rusting for some reason. Are you gonna put anykind of clear on it to protect the paint?
#208 |
No, no clear....I thought that the oil leaks were supposed to protect it
#209 |
60-66 Nut
Coming along nicely. Did you have any luck finding some 3/4 ton frame brackets for the motor mounts?
#210 |
Registerd User
Looking good Jeff.
#211 |
283 Drama Queen
![]() Join Date: Dec 2004
Okay, Jeff - what's with the fancy all-thread rods to measure off of? What, twisted together coat hangers too ghetto for you?
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
#212 |
1962 C-10
NICE!!!
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
#213 | |
#214 |
Thanks guys.........good to see ya cruisin' the board!!! ![]()
#215 | |
60-66 Nut
The '73-'87 C20's frames are closer in height to our trucks frames than the '73-'87 C10 frames. I have yet to install a set, but I have measured the frames and compared them. There was another member that originally brought this to my attention.
#216 | |
OK, everybody wave.................... ![]()
#217 |
Registerd User
#218 |
I guess only Jason wanted to wave goodbye
![]() For those who mentioned putting material under the top of the mount; this is only neccessary if you use the factory lower holes.....at least as far as I can tell. ........here's the pics. ![]()
#219 |
chevy only
![]() Join Date: Sep 2006
sh-t to late to wave..... will looking good ,that sub is going to be fun with that motor
CHEVY ONLY... Nothin Else ! Last edited by Dinos63; 02-08-2010 at 02:40 AM. |
#220 | |
![]() ![]() A mid-day update as I know many are on the edge of their seat!! ![]() I notched the frame back roughly .5'' to fit the mount in place. I also redrilled the 2 lower holes which are directly below the factory holes. This puts my mount holes at exactly 16.75 inches to center. I will put a thick washer(1/16th) under the front lower hole to act as a spacer as there is a little rocking of the mount. Now I just need to blast 40+ years of grease and dirt and move a brake line and my trans lines. Also getting a coat of black rattle to pretty things up.
#221 |
Registerd User
Good job Jeff. Can't wait to see that shiny new motor tucked in there.
#222 |
60-66 Nut
Once you get that engine set in there, you might want to check the carb flange on the intake for level and also check to be sure that your trans output is in the same plane as the pinion in the rear end.
I did a little measuring regarding my previous post on the C20 motor mount brackets. In the area of the motor mounts, the '63-'66 frames measure about 5 3/8" tall. The '73-'87 C20 frames measure about 5 1/2" tall. The '73-'87 C10 frames measure about 6" tall. Just a little FYI.
#223 | |
I'll confirm that measurement on my frame; I'm sure it's the same, but what the hay!! ![]() It looks as though the engine will sit down in the bay nicely. Long tube headers are definitely a no go, at least if one is lowered or bagged. I think my choice of headers will work well, too. I'm gonna find out anyway, as I have my new brake line made and I still need to do the trans lines.
#224 |
60-66 Nut
Any progress Jeff?
#225 |
Well, my frame is 5 3/8th's inches high. But no, not much. I have just been cleaning up parts and tracking down a couple things I need. I need to clean up my inner fenders and figure out how to hook up my TV cable to the carb correctly. I am also putting my serpentine system together and need one part.
My parents are visiting so I am not doing much work on it for a couple days. I do have the mounts in and my brake line relocated. The fire wall also has a fresh coat of black. I'll get a pic.
