02-04-2010, 09:36 AM | #1 |
Suspension Issues Need help
Ok so I have a 1968 GMC 2500 with a Big Block 402 it has the Original Front Suspension on it and I mean Original all the way down to the Shocks which I would say is a great bit overdue for changing, but surprisingly they don't leak nor show signs of ever leaking, besides the point I need to rebuild the suspension I just did an alignment and found out my Idler arm is really worn out along with my Tie Rod ends. I was figuring if I am gonna replace them i might as well rebuild the whole darn thing,now I also want to Drop it 4-5" in the front and maybe 4-6" in the rear without having to notch the frame. I was wondering if there is anyone that knows of a 3/4 ton kit available I want to keep it an actual 3/4 ton I also looked through cpp but there's no lowering kits for the 3/4 ton on there. any ideas??? also I like having a rake id like to offset it a little more than now which is barely noticeable what would be the best measurements for that also?
also I am looking for a complete front end rebuild kit that includes the center link both upper and lower ball joints both inner and outer tie rod ends with new adjusting sleeves a new idler arm and possibly a new pitman arm a arm bushings the whole 9 yards, go big or go home right, Thanks a Bunch BBGMC
02-05-2010, 09:36 AM | #2 |
Happy to be here
Re: Suspension Issues Need help
Anyone?
02-05-2010, 10:03 AM | #3 |
Redefining LowBudget
I'm doing my 70 C10 right now and have had great luck at my local parts store the parts will vary in price from one store to the other ..mostly with the pitman arm and if your going to do the link probably that too??..all say it will take a couple days to get them in but theres no shipping and from what I have found if something is wrong its an easy drive to town....besides on things like that I like to spend my $$ localy if I can...
as far as your drop be sure to check your rear axle clearance before you order anything...with out a notch you maybe looking to end up with a axle to frame issue 4" will probably be ok but 6" ???? ever consider putting bags in it they ride great are an easy install and weight isnt an issue
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
02-05-2010, 10:12 AM | #4 |
Without upgrading to discs up front, you're limited to drop springs, stepped a-arms, or dropped a-arms for 'basic' lowering. If upgrading to discs, they make a 3/4 ton drop spindle.
Leaf or coil rear suspension?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-05-2010 at 10:13 AM. |
02-05-2010, 10:26 AM | #5 |
PROJECT 7DEUCE
You may give wes at classic heartbeat a call he is pretty close to you and id bet he could get you all the parts ya need....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-05-2010, 10:34 AM | #6 |
67-72 parts collector,…
Look here at PerformanceOnLine, for c20 drop spindles:
http://www.performanceonline.com/sto...at=1075&page=1 Here's a quote from that page: 1971-87 CHEVY/GMC/C10/C20, 2.5" DROP SPINDLE SET #18992 These hot items lower the front of your vehicle without affecting ride quality or suspension geometry and bolt directly to the original ball joints. Requires disc brake application. Please specify year and model. Use OEM ball joints. Note: 1973-80 trucks use 1.25" wide rotors. 1981-87 C10 trucks had the option of 1.25" rotor or 1" rotor, please measure. Details Weight 55.00 lbs Price: $ 228.99 Last edited by lolife99; 02-05-2010 at 10:35 AM. |
02-05-2010, 07:08 PM | #7 | |
BBGMC
02-05-2010, 07:21 PM | #8 |
Just remember that if you upgrade to disks it will require the appropriate year ball joints. Don't ask me how i learned this, but if you need some 67 balljoints i happen to have a new set for a 3/4 ton.
02-05-2010, 10:13 PM | #9 | |
Tags |
1968, 2500, chevy, gmc, suspension |
