Old 02-04-2010, 04:21 PM   #1
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Creeping Death
1972 GMC 1500 Super Custom... yarded out of a field in Snohomish WA. Here is the way it looked when I brought it home...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-04-2010, 04:23 PM   #2
GASoline71
GASoline71's Avatar
Re: Creeping Death
Then I shoved it into the tiny garage in the dump I was living in at the time...
Old 02-04-2010, 04:25 PM   #3
GASoline71
GASoline71's Avatar
Re: Creeping Death
Then commenced to tear it apart from the firewall forward...
Old 02-04-2010, 04:27 PM   #4
GASoline71
GASoline71's Avatar
Re: Creeping Death
My old man gave me some cool ET 5-window slots to put on the truck... they cleaned up nice!
Old 02-04-2010, 04:29 PM   #5
GASoline71
GASoline71's Avatar
Re: Creeping Death
More... in the tny garage...
Old 02-04-2010, 04:31 PM   #6
GASoline71
GASoline71's Avatar
Re: Creeping Death
Engine and tranny out... tore engine down...
Old 02-04-2010, 04:33 PM   #7
GASoline71
GASoline71's Avatar
Re: Creeping Death
Transmission... before and after rebuild...
Old 02-04-2010, 04:35 PM   #8
GASoline71
GASoline71's Avatar
Re: Creeping Death
Engine goes back together...
Old 02-04-2010, 04:35 PM   #9
GASoline71
GASoline71's Avatar
Re: Creeping Death
More...
Old 02-04-2010, 04:36 PM   #10
GASoline71
GASoline71's Avatar
Re: Creeping Death
Engine all purty...
Old 02-04-2010, 04:39 PM   #11
GASoline71
GASoline71's Avatar
Re: Creeping Death
Removed heater box, and cleaned it up and reinstalled it with new gaskets and new heater core...
Old 02-04-2010, 04:40 PM   #12
GASoline71
GASoline71's Avatar
Re: Creeping Death
Cleaned up firewall, degreased and repainted front clip. I purposely left the firewall with the overspray from the undercaoting and such...
Old 02-04-2010, 04:43 PM   #13
GASoline71
GASoline71's Avatar
Re: Creeping Death
Engine and tranny go back in...
Old 02-04-2010, 04:45 PM   #14
GASoline71
GASoline71's Avatar
Re: Creeping Death
Some painting and a new aluminum radiator... also cleaned up and painted the original power brake booster... new master cylinder.
Old 02-04-2010, 04:49 PM   #15
GASoline71
GASoline71's Avatar
Re: Creeping Death
Carb, plug wires, and distributor go in... I now have an MSD Pro Billet HEI in it... but this got me by for awhile...
Old 02-04-2010, 04:51 PM   #16
GASoline71
GASoline71's Avatar
Re: Creeping Death
New hoses, belts, new engine wire harness, and new front end wire harness. Headers installed. Also installed new plastic harness channels... inner and outer fenders (replaced pass side inner with aftermarket), and new battery tray and battery
Old 02-04-2010, 04:54 PM   #17
GASoline71
GASoline71's Avatar
Re: Creeping Death
BFG Radial T/A's on old school ET 5-window slots...
Old 02-04-2010, 04:55 PM   #18
GASoline71
GASoline71's Avatar
Re: Creeping Death
Old school lookin' Sunpro Tach...
Old 02-04-2010, 04:58 PM   #19
GASoline71
GASoline71's Avatar
Re: Creeping Death
Here is how it looked the day I drove it out of the garage... just goes to show, you can clean up an old farm truck, and make it turn heads... even with limited space in a super tiny garage, and on a tight budget...
I've done more to it now... still need to lower it, and put a decent exhaust on it... but this thing hauls... and has been a fun project over the last 4 years...
My shop buddy... my 12 year old Chocolate Lab... Yukon. He worked hard on this project too!
Gary
Old 02-04-2010, 10:21 PM   #20
mjensen
mjensen's Avatar
Re: Creeping Death
That has to be the quickest build I've every seen
Looks great!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 02-04-2010, 11:00 PM   #21
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Creeping Death
Looks like dangit in the 1st pic comepared to after shot..
That engine bay looks KILLER wat paint did ya use?
Any specs on the motor?
That looks GREAT!!!!!!! Good job!
John
1999 Toyota Tacoma 4x4
Old 02-05-2010, 12:16 AM   #22
GASoline71
GASoline71's Avatar
Re: Creeping Death
Looks great!
Thanks! It actually took about 4 years...
Everything black in the engine bay and on the frame is satin black chassis paint made by Duplicolor.
Engine is the original 1972 4-bolt main 350 (.030 over), stock crank and rods with Speed-pro 10:1 Hyper flattop pistons, Stock 2.02 heads (with some mild porting), Lunati 292 Bracketmaster cam and Lunati lifters, Roller rockers, Cloyes double roller timing chain, Heddman Headers, Edelbrock RPM air-gap, Holley 3310 (750cfm) blueprinted and benchflowed by Lyle Winters racing in Tacoma, WA. There is a stock HEI ignition in it in the pictures... but there is an MSD Pro-billet HEI with rev limiter in it now...Roughly makes 400 hp around 5,600 RPM's.
I rebuilt the TH350 myself, and installed a B&M shift kit in it. 2,800 RPM stall converter.
Goes pretty quick for a truck. The best part about it is when people hear it they want to see the engine. When I open the hood... people aren't prepared to see an engine that clean in an old work truck... Which is exacxtly the look I was going for.
It's one of those projects that will be forever ongoing... always tinkering with it. One of my buddies gave it the nickname "Creeping Death"... after a Metallica song.
Thanks for the comments guys...
Gary
Old 02-05-2010, 12:41 AM   #23
nuke1
nuke1's Avatar
Re: Creeping Death
That is a gorgeous truck, great looking, original, but powerful, i like how you did it.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-05-2010, 04:48 AM   #24
chevy88
chevy88's Avatar
Re: Creeping Death
Your rims look great, what did you clean them up with?
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 02-05-2010, 01:39 PM   #25
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Creeping Death
Nice work, turned out really nice!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
