Old 02-04-2010, 05:08 PM   #1
blazer2007
gas gauge needle broke,where to set the new one
broke my gas gauge needle while putting in new lights,anyway I pulled it off to see what type I need not thinking where it was pointing,how do I know where to put the new one?
blazer2007 is offline   Reply With Quote
Old 02-04-2010, 05:09 PM   #2
blazer2007
Re: gas gauge needle broke,where to set the new one
sorry is a 1980 type
Old 02-04-2010, 06:36 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Well, I would take the truck down and fill it up (this can be done with the cluster partially apart) then set the new needle on the full mark. I know most read a little past full but if you set it on full there's less chance of running out before it reads empty.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-04-2010, 10:15 PM   #4
blazer2007
fill it up,the price of gas ha ha,just went up today
Old 02-05-2010, 06:41 AM   #5
Restrorob
Restrorob's Avatar
I feel your pain !!!
If you can't afford to fill it up, Suck it dry then set the needle a little past empty. Add gas when it hits the "E" mark......
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-05-2010, 07:34 AM   #6
Keith Seymore
Keith Seymore's Avatar
Yep - the only thing I would add is that the key will need to be in the "on" (or engine running) position.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-05-2010, 05:13 PM   #7
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: gas gauge needle broke,where to set the new one
Actually thats exactlly oppisit of how you want to do it
You want to drain the tank and then with the key on you want to set your pointer.
When it's full you know it and it dosent matter there and it never stays there very long anyways lol! but when its gettin near empty you really want to know it and doing it the other way may not be accurate when it gets to the other end of the scale.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-05-2010, 07:19 PM   #8
78-5.3
78-5.3's Avatar
disconnect the wire going to the sending unit (at the dash ) turn the key on, it will go to the E then put the needle on then put the wire back on !! it will center it self to the correct fuel level !!!!
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 02-05-2010, 07:54 PM   #9
USSkoval
This way sounds easiest and cheapest of all
USSkoval is offline   Reply With Quote
