Old 02-04-2010, 11:05 PM   #1
spinem
haha, ford guys...
Question Junk yard fuel injection
out with the quadrasuck in with the electrobogg.....
whose done it?
do's?... dont's? i never hear much about this idea.....
say i found an older camero 350 and wanted to put the fuel induction setup in my truck... possible?
spinem is offline   Reply With Quote
Old 02-04-2010, 11:11 PM   #2
fencepost
fencepost's Avatar
Re: Junk yard fuel injection
Try this
http://www.popularhotrodding.com/tec...ls1/index.html
fencepost is offline   Reply With Quote
Old 02-05-2010, 11:43 AM   #3
rfmaster
rfmaster's Avatar
whose done it?
We have done it and it is very doable. A better choice for a donor is 87 to 92 truck - there are a lot more of them Camaros.
http://67-72chevytrucks.com/vboard/s...d.php?t=317519
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-05-2010, 05:02 PM   #4
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: Junk yard fuel injection
Hold on there it all depends if hes talking about TBI OR TPI.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-05-2010, 07:55 PM   #5
rfmaster
rfmaster's Avatar
TBI or TPI from a swap project scope and actually doing the swap are not much different. Naturally, there are parts differences, fuel injection points are different, but from a swap perspective both systems share a lot in common. For a novice swapper TBI is easier, low cost and readily available. TPI system can be pricier and depending who you talk to can offer HP performance. TBI does the job in dd truck, and easier to work with and can do adapted to a carburetor intake. Still, a solid engine is required - if you're low on compression or burning oil FI will not fix these problems. Also, to gain full advantage of TBI or TPI you must have leak free exhaust system and trany must be equipped with VSS.
//RF
"The Beast"
Old 02-05-2010, 10:01 PM   #6
spinem
haha, ford guys...
thanks guys, this is all very interesting to me...VSS? whats that?
also, im worried that off the loaner truck, i will come across too many wiring ghosts...???
Old 02-05-2010, 11:22 PM   #7
joe231
joe231's Avatar
VSS=Vehicle Speed Sensor
If you can get the entire harness from a 88-91 square body truck, blazer, or 'burb you could swap the whole thing. The 88-89's have a non electronic speedo that have an optical sensor that works as a VSS (and should work with your current transmission), and the 90-91's have electronic speedo. so get the cluster too if you can.
//RF
Not to 'jack the thread....
But, what are your thoughts about running an aluminum 4 barrel intake with TBI? You would loose the EGR, correct? Will it adversly effect the fuel mileage?
The reason I ask is I have the complete TBI set up from a '89 'burb (including the wiring harness and speedo with the optics attached to it) and would like to put it on my '82 CCSB (GM Goodwrench crate 350 with 2 piece rear main) for reliability and fuel mileage. It currently has an Edelbrock intake (not sure which one) and Holley 4160 600cfm carb, so just buying an adapter plate would be super easy, but is it worth it to swap over the TBI intake?
Thanks for all your input RF!!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-06-2010, 12:36 AM   #8
spinem
haha, ford guys...
would the speed sensor be necessary? wouldnt without it just create a rich condition at high rpm's?? im fine with rich!! haha
Old 02-06-2010, 01:18 AM   #9
fencepost
fencepost's Avatar
JMO I have TBI on my 92 Z71 and I hate it, no power. I have thought more than once about swapping to Vortec heads and 600 Holley. For around $1800.00 you can go with an aftermarket TBI that looks like a Holley double pumper doesnt have to have a return line, can handle up to 4 or 500 hp and is self learning, heard lots of folks brag on them. The factory TBI is not performance friendly. Thats just me they are reliable, but that about the only nice thing I can think of.
Old 02-06-2010, 01:23 AM   #10
joe231
joe231's Avatar
there is lots of un-tapped potential in the TBI system
http://www.tbichips.com/truckmods.htm
CHEVY ONLY
Old 02-06-2010, 01:36 AM   #11
fencepost
fencepost's Avatar
I've studied up on it and have a 454 TBI I could use but the reward is not worth the effort to me. You can get the same result for less. JMO
Old 02-06-2010, 02:24 AM   #12
rfmaster
rfmaster's Avatar
It is doable with an adapter plate. If you dive through the TBI swap thread (more like cross country highway) you'll see couple of guys have used TBI to carb intake adapter plates. A word of caution - thin adapter plates tend to develop leaks! My preference is for 1/2" or thicker 6061 Aluminum plate with blind holes with studs for TB mounting. This way intake manifold vacuum stays put.
To those who say that TBI has no power - it is true for engines equipped with OE camshafts and factory ECM calibrations. Back in the day GM put peanut cams into LO3 and LO5 engines which by 3500RPM were done for all practical purposes. Over the years I have seen how well TBI responds to a mild RV camshaft and minor head work. Add a good flowing exhaust and you have an engine that will easily deliver low end torque and decent high RPM HP performance. The trick is to have ECM delivering enough fuel and timing both which can be accomplished. Stock SBC TB flows 490 CFM which is more than adequate for 98% of all driving that a typical street (dd) engine will see. The problem is usually inadequate fuel pressure. Factory calls for 9-13 psi range which is a very wide range - I like to see 14 to 16 PSI (and updated VE tables) as this makes for better performing engine.
If your 4-bbl intake does not have EGR provisions you'll have to program EPROM to disable EGR function - or other wise SES will be set - this will adversely affect driveability. Depending who you talk to EGR improves highway mileage by about .5 to 1.5 MPG.
//RF
"The Beast"
Old 02-06-2010, 02:27 AM   #13
JRBailey
check out painless wiring they have a vss that goes inline with speedo cable. The extra long harness alowed me to mount everything under the seat very neatly. I used GMs vortec tbi intake from summit with vortec heads. Good power, economy,very reliable
JRBailey is offline   Reply With Quote
Old 02-06-2010, 12:10 PM   #14
joe231
joe231's Avatar
RF beat me to it
//RF
Thanks for the info!
I believe the link I posted earlier burns custom chips, guess I'll have to look further....
CHEVY ONLY
Old 02-06-2010, 01:02 PM   #15
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
After having TBI on the 92 Firebird, I must say I am not impressed by it at all. I'd much rather have carb like my 86 Firebird or TPI injection.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 02-06-2010, 01:37 PM   #16
scotts62
One day...
scotts62's Avatar
Yeah i dont think TBI in a car would be fun at all...
Scott
93 crew cab build
Project 62
Old 02-06-2010, 03:20 PM   #17
joe231
joe231's Avatar
does anyone read anymore
CHEVY ONLY
Old 02-06-2010, 03:54 PM   #18
rfmaster
rfmaster's Avatar
In 92 305 TBI in Firebird was rated 170HP@4000 RPM and 255 ft-lb/2500 RPM and typically came with very tall 2.73:1 rear end ratio. That combo was the moronic attempt by GM to achieve Corporate Average Fuel Economy (CAFE) to meet fed mandates. Thank you EPA!
The weakest link in a TBI equipped engines is not fuel injection part but a puny camshaft, some what restrictive heads and chocking exhaust system. Stock TBI cam at .050" lift is 179/194 deg (I/E) and maximum lift with 1.5:1 rocker ratio is 0.350/0.384 (I/E). It is outright pathetic, If you stick carb or even TPI on top of a TBI short block (with that cam) you will loose both torque and HP and end up with a bigger dog! I have seen several of these attempts at TBI to carb conversion fail miserably (half had other problems, but this is a family forum so I will keep it clean!)
The key to performance (we are talking solid dd, not a fire breathing monster) TBI is take advantage of what is readily available to any Joe:
mild camshaft (keep it middle of the page: LSA 112deg, lift at about 0.425 to 0.475, duration 195-205deg @ 0.050)
reworked heads (springs, mild port cleanup)
exhaust system (headers, cat after exhaust)
low restriction intake
ECM tuning and optimization.
The key advantage of TBI over TPI is that it is relatively low cost and readily available just about anywhere. I have to admit that I am regular JY visitor and many month go by when before I see a wrecked TPI camaro. Whereas TBI cars or trucks are there all the time.
//RF
"The Beast"
Old 02-06-2010, 08:57 PM   #19
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
A LS1 conversion is hard to beat.
http://www.hotrodlane.cc/77chevytruck/77chevy.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-07-2010, 09:56 AM   #20
78-5.3
78-5.3's Avatar
or 5.3 6.0 LSX better fuel economy , more HP ,lghter install
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 02-07-2010, 12:24 PM   #21
68 TT
Still plays with trucks
68 TT's Avatar
The biggest problem with the stock TBI motor is that the cam is absolutely tiny. The heads don't flow too well either but can handle much more cam than the stock TBI motor came with. The TBI unit flows under 600 cfm so that will limit your power a little too but it can be bored out to flow much better.
I retrofit my 90 Z71 TBI 350 with a vortec truck roller cam setup I got at the wrecking yard and it made a huge difference in power. Cost me less than $200 to do including the complete gasket set for the engine and a hydraulic roller style timing set and the cam, lifters and spider retainer setup & pushrods.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-07-2010, 08:24 PM   #22
Justins76
Justins76's Avatar
//RF
Thats true but the LG4 cam was pretty much the same as the TBI cam except that was a roller. From my driving experience I did not get any better mileage with the 1992 TBI over the 1986 carb firebird. If anything the TBI was worse in the city. Both at the time had 2.73 with a 700r4 and both were bought new.
True there is less maintenance and its low cost (not counting my fuel pump in the tank that goes out every 6 years and you have to drop the whole back end to get to the tank lol)
My cardomain page
Old 02-08-2010, 11:16 PM   #23
fpjr0
fpjr0's Avatar
do the 5.3 6.0 swap I just finish mine... more power just my .02... did my junk yard special swap and well under 1900 all finish. can beat the just over 300hp with the 22+mpg...a/c and cruise control
fpjr0 is offline   Reply With Quote
Old 02-09-2010, 12:56 AM   #24
SatisTraction
this is my set up too bad you are not closer.
http://jackson.craigslist.org/pts/1589430977.html
WTB 73-87 SWB fleetside bed!!
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
75 bronco injected 351w
SatisTraction is offline   Reply With Quote
Old 02-09-2010, 10:00 AM   #25
68 TT
68 TT's Avatar
A stock TPI system is pretty limited too and falls on its face around 4500 rpm. They just don't flow much air stock.
The parts to make it much better are out there but add up to a mountain of money in a hurry. Most TPI guys end up with a Holley short runner MPFI system that looks like the LT1 intake. If you don't have to meet emissions that is the way to go to keep your old engine but for the same cost you can do an LS engine swap now and get more HP and MPG out of the deal.
