Old 02-04-2010, 09:10 PM   #1
dooce
Dually Questions... Can I make a dually??
I will be looking for another project soon, a 73-80 reg cab dually. They seem kinda hard to find, so can I take a regular run of the mill long bed and slap some dually fenders and rear end and on it have a dually? I need to know if the wheelbases are the same from the factory and what problems I may encounter.
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 02-04-2010, 09:54 PM   #2
Stitch
Location: Where I come from, it's cornbread and chicken...
Re: Dually Questions... Can I make a dually??
all that will work, you'll also have to change the hubs up front...you could also change the hubs on a srw axle with drw axle hubs as long as it's a 1 ton axle like a D70 or 14 bolt
Stitch is offline   Reply With Quote
Old 02-04-2010, 10:29 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I don't think the inner bud wheels would work if you use a standard srw housing. The drw housings are wider to allow the 2 tires per side.
Ryan
1969 Chevy milk truck
Old 02-04-2010, 10:56 PM   #4
Stitch
if you change the rear hubs they will work
Old 02-04-2010, 11:05 PM   #5
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Just to affirm what you want to do. There were many companies offering dually conversions on trucks in the 80s & 90s. They are still out there, just not as popular for new trucks now. What those conversions did was basically add tires and fenders.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 02-05-2010, 12:57 AM   #6
USSkoval
No they won't, that would shove them into the inner tubs even more. The dually d70 axle is much wider, and installing srw hubs will make the track width even wider in that case (just an example to prove my point). Installing dually hubs on a srw 14bolt basically gets you a cab&chassis rear axle, which is narrow because they did not have factory type beds mounted on them to cause a clearance issue.
Also, it would be best to convert a 1ton truck. A drw D70 would bolt right in without having to change spring hangers and shock mounts.
USSkoval is offline   Reply With Quote
Old 02-05-2010, 01:06 AM   #7
Stitch
didn't know that for 100%...thanks for the clarification...I've done a little research on the topic, because I've been thinking of converting my ccsb 3/4 ton
so you have to have a drw axle...
Old 02-05-2010, 01:09 AM   #8
Driveway Dreams
I have car A.D.D.
See KIT #300 as an example. And AF-275 Fenders.
http://www.arrowcraft.com/products.php#kits
-Gerald
Old 02-05-2010, 01:16 AM   #9
USSkoval
I'm not sure, but a 3/4 crew cab may have the 1ton frame and rear spring perch spacing. Can you confirm?
Old 02-05-2010, 01:23 AM   #10
Stitch
I'm 99% sure the crew cab has the same frame as the 1 ton ...there was a thread about frame dimensions a while ago...it was in there...
if I took the stock srw axle and put drw hubs on it, would I be able to mount 19.5" semi wheels on my truck stock height with no modification besides adapters...I'm wondering, because that's the look I want to go for if I do the dually...I don't want it lowered and I don't want it jacked to the moon...just stock height with some semi steel wheels...
Old 02-05-2010, 01:30 AM   #11
Dieselwrencher
I think the problem with using the srw axle housing will be with the inner tire to spring clearance. The cab chassis trucks have narrower leaf springs to make extra room for clearance. I think the drw D70HD is atleast 3" wider than a D70 srw. The wider axle places the hubs farther out allowing the drw offset wheels to get both wheels in the wheel well.
Ryan
Old 02-05-2010, 01:34 AM   #12
USSkoval
You may want to try it with your stock hubs first, the 19.5 adapters I've seen aren't that thick. Also if you switch hubs, then you have to deal with brake mounting points on the axle tubes.
Old 02-05-2010, 01:36 AM   #13
Stitch
I think the offset on the 19.5 is different than the stock 16s also
Old 02-05-2010, 01:37 AM   #14
USSkoval
All the 1ton trucks have the same narrow spring perch spacing, regardless if they are cab&chassis. I have never seen a srw d70.
Old 02-05-2010, 01:39 AM   #15
Dieselwrencher
All the ones I have worked on have had 2" leaf springs and not 2 1/2" like a non cab and chassis is where I am getting at.
Ryan
Old 02-05-2010, 01:40 AM   #16
USSkoval
Didn't think of that. Still might work with the stock hubs though, can't hurt to try I suppose.
Old 02-05-2010, 01:44 AM   #17
USSkoval
I've never heard or seen that, but honestly I haven't payed any attention to them. It would only provide a 1/4 inch more tire clearance, unless they had offset bushings and center pins.
I have seen the 2 1/4 springs used in the vans.
Old 02-05-2010, 01:47 AM   #18
Dieselwrencher
Chuck, if it didn't work you could always use a billet spacer to get the clearance you need. I've ran them on my dually before and haven't had any problems with them.
Ryan
Old 02-05-2010, 01:48 AM   #19
Stitch
strange that they would put narrower springs on something with a higher GVWR
I would try it, but if it doesn't work, then I'm out the money for the hubs...and like you said I'd have to figure a way to mount the calipers...
how much do you think a drw axle should run...are there other drw axles besides a d70?
Old 02-05-2010, 01:49 AM   #20
Stitch
oh ok gotcha...I've never really messed with axles before so it's kinda new ground for me...
where could I get the drw front hubs, rotors and calipers from and also the drw hubs and calipers for the rear...
Old 02-05-2010, 02:01 AM   #21
USSkoval
If you try it with the stock srw hubs (still narrower track than dually) and it doesn't work, you haven't lost any money... just time.
14bolt and d70 hubs are supposed to be interchangeable.
Old 02-05-2010, 02:04 AM   #22
Stitch
also, can I use the srw hubs up front also? I think somewhere they said you could it just tucks the wheels in more...
Old 02-05-2010, 02:05 AM   #23
Dieselwrencher
The leaf spring pack has more overall springs than a standard chassis truck.
You should be able to buy a complete D70HD for around $250 I would think. Other dually axles in a dodge are a Dana 80 in 1994-02. Fords also used Dana80's from 99 up and they are expensive in the ford and dodge parts world. Pre 94 they are D70HD's. Fords used sterling 10.25's from 1987-1997. Pre 87 they as well had D70HD's. If I remember correctly the 14bff drw cab and chassis housings were narrower than a stock srw housing. A lot of truck pulling guys use that housing to get their track width on the rear as far inside as they can.
Ryan
Old 02-05-2010, 02:07 AM   #24
Dieselwrencher
I don't think you would be able to turn very far if you do. The drw front hubs stick past the rotor atleast 3" to get those offset dually wheels in the center of the wheel well. The front hubs should be easy to come up with for a 2wd truck though. Again, you might be able to run spacers there as well.
Ryan
Old 02-05-2010, 02:11 AM   #25
Stitch
I really don't want to run extra spacers, the adapters are already spacers really...I will be pulling a 30 ft travel trailer, so it needs to be right...not that running spacers wouldn't be right...don't get me wrong...I just don't want something to complicate the process
