Old 02-05-2010, 06:19 PM   #1
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Identify this rollbar!
I am wondering what this is from or who makes it. It is three pieces and bolts together. when bolted together the floor pads at the back don't really seam to fit flat on the floor. So I was thinking about welding it together. Then I thought even in a roll over it won't do anything since it isn't tied in and even if it is tied in to the frame and welded together. Ss the tube strong enough? or is this thing really just for looks.
this is the only picture I have of it.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 02-05-2010, 07:05 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Identify this rollbar!
It looks like a SmittyBilt from that picture.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-05-2010, 08:50 PM   #3
litebulblsc
litebulblsc's Avatar
Does the back bolt to the inner fender and the floor?
litebulblsc is offline   Reply With Quote
Old 02-05-2010, 10:51 PM   #4
RED72blazer
urban fourwheelin
[QUOTE=litebulblsc;3782527]Does the back bolt to the inner fender and the floor?
yes, it does.
Old 02-05-2010, 11:51 PM   #5
litebulblsc
I believe we have the same roll bar. Mine was purchased new sometime after 99, and never installed. No idea who makes it though.
Old 02-06-2010, 07:21 AM   #6
vtblazer
vtblazer's Avatar
[quote=RED72blazer;3782816]
yes, it does.
...okay but 'where' on the wheel well does it land?
On top - Not a Smitty Built or period correct
In the front of the wheel well - could be what some call a 'factory' roll bar
Here's an example of one:
vtblazer is offline   Reply With Quote
Old 02-06-2010, 02:26 PM   #7
RED72blazer
urban fourwheelin
it's on the back of the wheel well. four bolts on the floor then it angles and has two bolts that go through the wheel well.
Old 02-06-2010, 10:22 PM   #8
orangek5
orangek5's Avatar
Its a smittybuilt and they don't & won't make them any more I have begged them.
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline   Reply With Quote
Old 02-06-2010, 10:55 PM   #9
SeventyOne
I bet any fab shop could make you a "factory" or smitty style bar pretty inexpesively - hoop, some down bars and metal plate. Hell, tell them you'll weld it yourself.
SeventyOne is offline   Reply With Quote
Old 02-06-2010, 10:58 PM   #10
litebulblsc
Mine is mostly still in the plastic with the hardware in a box. Doubt I will ever install it.
Old 02-07-2010, 01:05 PM   #11
Firebirdjones
[quote=vtblazer;3783435]
Yes that example is what is in our blazer. Been there since it was new, I would assume dealer installed. And that style is made by Hickey Enterprises by the way. Mine still had the stamp on it.
Firebirdjones is offline   Reply With Quote
Old 02-07-2010, 01:14 PM   #12
Firebirdjones
Here is how (what is considered a stock bar) connects to the tub
Here is the Hickey part number
Here is the complete 1-piece bar.
I've seen a few of those in other blazers as the original poster has described,,,that actually go back farther in the tub.
Whether any of them would be effective in a roll over is hard to say. In NHRA rules (drag racing) which is what I'm familiar with, the rules vary a bit. On a full frame car, the roll bar has to run through the floor and attach to the frame itself.
On a subframe car, the rollbar has to be attached (welded) to a 6'x6" piece of flat steel, that is welded to the floor pan,,,not bolted.
As far as I'm concerned with my Blazer, any roll bar is better than nothing. Although I never plan to roll it and find out how effective it is
