gas gauge needle broke,where to set the new one
broke my gas gauge needle while putting in new lights,anyway I pulled it off to see what type I need not thinking where it was pointing,how do I know where to put the new one?
Re: gas gauge needle broke,where to set the new one
sorry is a 1980 type
The One And Only !!!
Well, I would take the truck down and fill it up (this can be done with the cluster partially apart) then set the new needle on the full mark. I know most read a little past full but if you set it on full there's less chance of running out before it reads empty.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
fill it up,the price of gas ha ha,just went up today
I feel your pain !!!
If you can't afford to fill it up, Suck it dry then set the needle a little past empty. Add gas when it hits the "E" mark......
#6 | |
Yep - the only thing I would add is that the key will need to be in the "on" (or engine running) position. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
STILL PLAYS WITH TRUX
Actually thats exactlly oppisit of how you want to do it
You want to drain the tank and then with the key on you want to set your pointer. When it's full you know it and it dosent matter there and it never stays there very long anyways lol! but when its gettin near empty you really want to know it and doing it the other way may not be accurate when it gets to the other end of the scale. |
#8 | |
78 C-10 5.3 LSX -4L60E Last edited by 78-5.3; 02-05-2010 at 07:19 PM. |
