01-18-2010, 08:33 PM | #501 |
Re: project INCREDIBLE HULK 6.2L with 6L80E
x2
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
01-18-2010, 09:03 PM | #502 |
PROJECT 7DEUCE
Is the rear cab piece cuStom order///??
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-18-2010, 09:21 PM | #503 |
the ls6 has the cathedrail shaped ports, and the l76 intake has the big retangular shape ports...you can not inter-mix the two...the l76 flows more do to the bigger runners....no it did not come with the MAP sensor...no problems at all with useing the TB, everything clears nicely..
01-18-2010, 09:22 PM | #504 |
01-18-2010, 11:49 PM | #505 |
Phone's ringin Dude.
Problems with the PB arms?
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
01-19-2010, 12:18 AM | #506 |
gets board easy.......
I like those PB arms, not a Bad idea
01-19-2010, 12:33 PM | #507 |
02-03-2010, 07:35 PM | #508 |
getting some work done on the hulk... moved into a bigger shop, and finally got back to 'working' on the projects again....i got the rear seam filler piece fitted, and tacked on...it was a great fit, only did some minor trimming on the rear (where the rear back glass channel is...it was a bit long....but thats probley because it can fit on a small back glass truck too)
the process wasnt to bad, i trimmed out the sharp edge where the roof meets the back of the cab... and cleckoed it in place, traced around the filler piece, and cut the excess off..then i cut the tabs i used for the cleckos off, and primed the back side off the panels....and tacked the pieces together, still need to tack the back side (along the rear glass channel), final weld, and smooth.... |
02-03-2010, 07:36 PM | #509 |
02-03-2010, 08:08 PM | #510 |
VA72C10
Looking good!!!
Looking for a 67-72 swb or blazer project in or around VA. |
02-03-2010, 08:59 PM | #511 |
PROJECT 7DEUCE
That new shop looks comfortable..
02-03-2010, 09:09 PM | #512 |
my my how we are movin on up...
1) where's the flat screen? I see the shelf up on top but no tv! 2) you know how i like a clean area so what's with the leaves and scrap metal on the floor? seriously though; those working conditions look ten times better!
R.I.P. Killer 71 10/26/07 |
02-03-2010, 09:19 PM | #513 |
Still Learning
Don, Nice work on the filler piece. Man that shop looks great! Looks to be plenty of room too. There goes the shop rate through the roof
02-03-2010, 11:33 PM | #514 |
Under Construction
looking good Don!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
02-04-2010, 07:41 PM | #515 |
thanks everyone, shop is alot better... i keep it at a nice 69*....it has A/C too, which im excited about that too come summer time...but with it snowing outside and freezeing cold, the shop makes it nice to work....
02-06-2010, 03:16 AM | #516 |
Hey 68,
Can you tell me where to get that bulkhead connector you used for wiring? I read earlier you got it from work, but do you know a supplier? I'd love to use one on my 63 project I have coming up soon. Also, what pins does it use? Thanks |
02-06-2010, 11:35 AM | #517 |
ill go thru my receipts and find who the manufacture is, and let you know...
02-06-2010, 11:39 AM | #518 |
got the filler all welded on...an a coulpe of shots of how it use to look, for compairison
02-06-2010, 12:28 PM | #519 |
wow, that does look a lot better... goes with the shaved drip rail now...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-06-2010, 05:49 PM | #520 |
02-07-2010, 10:00 AM | #521 | |
the plugs PN is 206151-1 and 206150-1 the pins are PN 66099-1 (males) the female pins PN isnt legible... but there should only be one pin style fot that plug. Last edited by 68 short step; 02-07-2010 at 11:46 AM. |
02-07-2010, 10:10 AM | #522 |
got a little bit done yesterday, removed and re-installed the center x-member.. installed the raised one in its place, cause we want to run a 1 piece driveshaft...so in doing that the cab floor was cut, and the cab was placed back on the frame (to check how good of measureing i did for the DS loop).... it went on as planned.....i also had to trim more of the fender for it to fit on, i knew tthis would need to be done, since we switch to drop spindles with the new brakes..and or coarse pics of the progress/stance with 22/20 combo
02-07-2010, 12:05 PM | #523 |
So Many Ideas, So Little Money
can't believe I never caught this thread til now. guess I've been slackin' on my board reading.
nevertheless AMAZING job! if all of us could have 1/4 of your talent there'd be a lot more perfect or near perfect restores and customs running around out there. Keep the pics coming!
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
02-07-2010, 01:06 PM | #524 |
What a cool build...I love all the outta the box thinkin....keep it up.
63 C10 65 Chevy Custom Cab w/ Big Back Window 66 C30 72 skylark w/ 454 65 K10 May the bridges I burn light the way.... |
02-07-2010, 01:21 PM | #525 |
Think you have the "tuckin" issue covered! Sweet work Big Daddy! I'm diggin the two tone green for sum reason!
