Old 02-07-2010, 10:07 PM   #1
mchauler
mchauler's Avatar
2 speed column, with 3 spd
Hey guys, im sure alot of you guys have had this problem. My 64 has a powerglide column, and i installed a th400. id like to keep it on the tree. is there a kit out there to remedy it or do I have to change the column OR should i just get a lokar floor mount. And! are those any good? any help would be app!!
mchauler is offline   Reply With Quote
Old 02-07-2010, 10:48 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 2 speed column, with 3 spd
There shouldn't be anymore lockout detents besides the P to R, so the column shifter travel for the 3rd gear should not be an issue.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-08-2010, 12:42 AM   #3
Captainfab
60-66 Nut
I've done the same swap you did.....TH400 with a PG column. I didn't do any modifying to it at all and it works just fine. It just doesn't show as having L2 and L1. These trucks did come with Th400's but I don't know if those shift indicators are available. I've not looked since mine doesn't bother me as it is.
Old 02-08-2010, 12:59 AM   #4
mchauler
mchauler's Avatar
Thanks for the info guys. Itll save me some bucks which will go elsewhere on the truck
