Old 02-08-2010, 10:24 AM   #1
burke117
speedometer lubrication????
I am replacing my speedo cable as was wondering, should I put some graphite lube into the back of the speedo???? I am trying to fix a bouncing needle. Thanks for your input
burke117 is offline   Reply With Quote
Old 02-08-2010, 10:40 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: speedometer lubrication????
I've done that before. I've also had it not work and had to remove both ends, yank the cable out it's sheath, clean it thoroughly with solvent and relube with lithium. I've also had to replace the buggers.
On my GMC I was able to grab the end with a pair of plairs and slide the cable out -not sure if you can do that on all of them.
68gmsee is offline   Reply With Quote
Old 02-08-2010, 10:48 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
No, I would not put lube into the speedometer itself. The bouncing needle is most likely a cable problem, not a gauge problem.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-08-2010, 10:49 AM   #4
burke117
i bought a new speedo cable. I was wondering about putting some type of lube in the back of the speedo itself(where the cable connects)?
Old 02-08-2010, 10:50 AM   #5
burke117
Ok thanks. That's why I asked. I didn't want to mess up my gauge.
Old 02-08-2010, 04:46 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Sorry for screwup. When you said in the back of the speedo, I thought you were just shortening the word "speedometer cable" and wanted to lube it to be on the safe side. Thanks for straighening it out, Stocker...
I was going to add to the post that I got the small cable lube tube at the Napa auto parts store some years back.
