Old 02-08-2010, 05:37 PM   #1
tmarkjr
69 GMC parking brake issue.
I just purchased a 1969 GMC K2500 4wd longbed pickup. Truck runs great but needs parking brake working for inspection. Here's the issue, the old cables are cut and tied to the frame. The rear brake backing plates have no holes to accept new cables. The rear is a Dana 60 10 bolt which is for that truck. It has 2" wide brake shoes and the inside of the drum measures 12". I have searched the internet all weekend but can't seem to find any info. Can anyone guide me to possibly changing the back plates or drilling holes for the cables. I don't know the history on the truck. It hasn't been modified and has stayed stock. Looking at the springs and "U" bolts I would have to say the rear is original. Thanks
tmarkjr is offline   Reply With Quote
Old 02-08-2010, 09:30 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: 69 GMC parking brake issue.
All I can tell you is that someone made some changes to that rear end. The backing plate should have the holes for the cables. Your best bet is to scour the junkyards, ebay, craigs list or check with vendors to see if you can come up with the correct backing plates. Personally, I've never seen any without access to parking brake cable.
68gmsee is offline   Reply With Quote
Old 02-08-2010, 09:34 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I have a 68 gmc with the d60 rear, if you would like I could take some pics to show you what it should look like. I am not sure if it makes a difference in cable routing, but I have a hand lever. Is yours a hand lever or foot pedal?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 02-08-2010, 09:41 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Backing plates should be the same. The parking brake was changed to the foot operated one in '69.
Old 02-08-2010, 09:42 PM   #5
tmarkjr
I have a foot pedal. Pics may help. Thanks
Old 02-08-2010, 09:54 PM   #6
tmarkjr
My brake shoes are 12" X 2" which is what LMC truck said the size is. When I call an auto parts store they come up with 12" X 2.5". What is your 68?
Old 02-08-2010, 09:56 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Here a pic I found on the net on this site http://www.boyandjeep.com/tech-artic...-60-rear-drums
If you go to the site scroll way down and check the pics out. You can enlarge them for a better view.
Old 02-08-2010, 10:11 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Forgot to add. Maybe a moderator can move this for you to the off-road section. Lots of Dana info over there.
Click on forums and scroll down to view.
Old 02-08-2010, 10:12 PM   #9
tmarkjr
My 60 has 8 bolts that hold the backing plate to the axle housing.
Old 02-09-2010, 06:48 PM   #10
Jacfourteen
I'm not sure, I never measured them. When I bought new ones they asked if I had 12" brakes and they were the right ones. Maybe have them get them off the shelf and measure them, might just be wrong in the computer.
