Old 02-09-2010, 12:19 PM   #1
Evan92
68 K20 Axles
What axles would be in my friend's 68 K20? We think that it has a Dana 60 in the rear, but we aren't sure what the front is. He also needs to know what the spline count is. Thank you.
Evan92 is offline   Reply With Quote
Old 02-09-2010, 11:23 PM   #2
Yukon Jack
Yukon Jack's Avatar
Re: 68 K20 Axles
Should be a Dana 44 heavy duty front axle and either a Dana 60 or Eaton HO52 rear axle. I'm not sure of the spline count but someone will know. The front axle should be a closed knuckle axle which gives you a poor turning radius and drums. Either rear axle is strong.
Here's what the Eaton axle looks like
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-14-2010, 01:19 PM   #3
west9378
west9378's Avatar
Re: 68 K20 Axles
that looks like my 69, I agree with Yukon Jack that is a eaton HO52 you are limited with that rear end it can only be a single rear wheel or update with a locker. Good news is that rear end is bullet proof.
west9378 is offline   Reply With Quote
Old 02-14-2010, 06:47 PM   #4
Yukon Jack
Yukon Jack's Avatar
Re: 68 K20 Axles
West, I'm not sure by what you mean you are limited with that rear. Mine has a factory No-Spin locker, which is a detroit locker, and a 14 bolt detroit locker can be used with, I believe, a change axle shafts.
Old 02-14-2010, 10:06 PM   #5
west9378
west9378's Avatar
Re: 68 K20 Axles
I had a HO52 and wanted a limited slip diff, I was told that I could do single wheel or a locker no in between. The in between for me was the LSP andthat is why I said you are limited in that you only had the two choices single wheel or full locker. I wish I had the locker but I was told that it is really not good for a truck driven mostly on the road as a daily driver. Best of luck with your friends build.
Old 02-14-2010, 11:55 PM   #6
Yukon Jack
Yukon Jack's Avatar
Re: 68 K20 Axles
I wouldn't be too worried about a locker in the rear, both my 69 and 70 have them and they get driven mostly on the road. The one in the 69 is pretty much unnoticeable but I must admit you know the 70 has it back there.
Old 02-15-2010, 09:00 PM   #7
msgross
msgross's Avatar
Re: 68 K20 Axles
spline count of the front or rear, inside axle shaft or outside (front)?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
