Old 02-11-2010, 01:31 PM   #26
Chavyluv79
Re: My 75 4x4 stepside
would the 700 R 4 bolt up in my truck
Chavyluv79 is offline   Reply With Quote
Old 02-12-2010, 12:08 AM   #27
Zoerb
Zoerb's Avatar
Yes and no.
It will bolt up to the engine, but not the transfer case. You would need to get either the np208 or the np241 transfer case, and new drive lines.
The spline count on the transmission on the th350 is different then the 700r4.
2017 Tahoe Premier - Daily
'99 Silverado 2500
Wife's whip- 2020 Equinox Premier
Zoerb is offline   Reply With Quote
Old 02-13-2010, 12:32 PM   #28
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Ryan, welcome to the board, nice truck!
Just a thoguht but if I was in your shoes id just get a set of 1 ton axles for it instead of regearing your half tons. I have done a lot of wheeling and it seems like you like to. The Dana 44 and 12 bolt you have in that truck are a pair of ticking time bombs with big tires hooked to em.
Also you do have a 203, so you are half way on your way to a 203/205 doubler. That means you could run 3.73 gears and get deacent mileage on the highway with your taller tires, and then be able to double down your four wheel drive so you have plenty of torque on the trails.
you can check out off road design, they have kits for the doubler. Well and lots of other goodies like high steer kits for your dana 60.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 02-13-2010, 01:18 PM   #29
Chavyluv79
I just got tires for it so ir i get 3/4 axles i gota get new tires and rim which i dont want to
I dont go rock crawing with it and i going to be running 4.11
Old 02-13-2010, 01:34 PM   #30
MrBeast
high-Tech Red Neck
MrBeast's Avatar
You should be able to sell those tires and rims for close to what you have in the tires.
I am speaking from experince, I had a 70 short bed 4x4 when I was in highschool, and running 33" tires I broke the dana 44 trying to climb up a hill, not rock crawling, they really arent very strong in a truck, they do well in a jeep because jeeps are way lighter than a pickup. You would probably be able to sell the 44 pretty easy for that reason.
With 35's and 4.11's you will be turning 2960 RPM to do 75 MPH, that is going to suck a lot of fuel. If you stuff an over drive in it like a NV4500 you could bring that down to 2161 RPM.
Just something for you to consider because right now with your 3.07's you are only pulling 1614 RPM @ 75 MPH, so as you gear your truck down your fuel consumption is going to go up exponentially.
Old 02-13-2010, 01:42 PM   #31
Chavyluv79
Never had a problem with the danna 44 befor
and with the 3.07 dose not help with my gas cuz there to high geared and i run 2500 rpm at 70 mph
With high gears there is no gear reduction to help turn the tires
And 3/4 axles are not cheep its more money to swap axles then to get them re geared
And its not like there is a lack of power i got plenty of that
Old 03-18-2010, 02:43 AM   #32
Chavyluv79
washed it when i got it back
Old 03-18-2010, 09:29 AM   #33
bigdnew
Never Satisfied
bigdnew's Avatar
Chavyluv, I have a friend who has one identical to yours. It runs, drives and is mean. He parked it two years ago and hasn't touched it since. No paticular reason just parked it and he won't sell it I've tried. It was his graduation gift and he's had for about 20 years.
1973 4x4 Blazer- Parting Out
1986 LWB Silverado Undergoing LQ4/4L80E Swap
'86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566
bigdnew is offline   Reply With Quote
Old 03-18-2010, 11:07 AM   #34
355bullet
355bullet's Avatar
Nice stepside Ryan!
here is mine. parts on the way for the bed
step side getting paint
http://www.southwestdrags.com/forum/...ad.php?t=10034
355bullet is offline   Reply With Quote
Old 03-18-2010, 12:23 PM   #35
slipkorn34
slipkorn34's Avatar
i wish my stepper was as nice as most of the trucks even in this thread...i can wait tho just gotta keep workin
1969 mercury cougar XR-7 - sold
1978 Chevy C-10 Scottsdale - sold
1996 chevy k1500 - sold
1970 mercury monterey - sold
1971 chevy c10 4 speed 4x4 - dd
slipkorn34 is offline   Reply With Quote
Old 03-18-2010, 12:45 PM   #36
Chavyluv79
so I took my truck threw a pond the other day
Old 03-18-2010, 10:44 PM   #37
slider
Alot of nice steppers on here, thought I might add mine, just picked it up about a month ago, it's a 75, should be a nice addition.
slider is offline   Reply With Quote
Old 03-19-2010, 12:33 PM   #38
355bullet
355bullet's Avatar
nice! i dig the prerunner bumper.
any of u guys know where to get a bed cover for these step sides?
Old 03-20-2010, 09:58 PM   #39
bkcbuilder
Mine is a hard cover by Gaylord....google them. It's nice, totally flat, has 2 locks and nice lift arms. Pretty easy to get on and off, but you need help.
bkcbuilder is offline   Reply With Quote
