02-08-2010, 02:29 PM | #401 |
Re: 1967 C10 Custom Big Window
I can taste it, how close it is getting to DONE!!!!! keep it up, dig the ol'school rims!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
02-08-2010, 03:34 PM | #402 | |
Sofa King Crazy!!
Oh yeah! The motor is still being promised, and nothing is happening, makes me mad. Always wanted those rallys, can't wait to put some new shoes on em!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
02-10-2010, 08:34 AM | #403 |
Hey, so what is really going on with this engine of yours, if it was me I would have gone elsewhere. Have you thought about this? Because you have to be getting frustrated by now. Sorry if it is causing trouble for you.
02-10-2010, 12:17 PM | #404 |
Sofa King Crazy!!
I really have not needed the motor until now, so it didn't matter. Now I am getting to the point where it would help me to have it for wiring and clearance issues. I still have not installed my steering column so it isn't a necessity. I gave him my 283 on March 4th and we could not find the correct pistons for it, so he gave me a 327, so I really can't complain. He will have it for me soon and that's fine, but it is still frustrating to have waited almost a year. But he gaurantees his work and will come to the shop and help get it tuned all for around $1600.....so that isn't bad.
02-11-2010, 02:28 PM | #405 |
your truck is sweet man coming along real nice. what do you have to the bottom of your gas tank? i got mine cheap and got 8" to the bottom of the tank at the back but im just afraid of hitting it coming down a sloped drive.
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now..... Needed: paint and lots of it. and i'm sure lots more misc. parts. Project 67 short step Build Thread 01 Sierra Crew 6.0 2015 Ford F150 Work gave me truck i really wouldn't buy a ford. |
02-11-2010, 03:45 PM | #406 |
I'm by no means a suspension expert but if you consider your plans to shim the UCA out on the rear stud you do in fact push the wheel forward in the fender but you also create an issue in that now the top ball joint is ahead of the lower and that I believe could cause steering issues. Not only is there caster,camber, and toe in there is another factor called ackerman I cannot explain that but I have had it explained to me and Im thinking by creating two different axis on the UCA and LCR pivot points you may have issues. In looking at mods to center the wheel in the opening I cant help but think moving the complete suspension forward is the best way to accomplish this. I have seen cut and modified CA's but aint no way I'd do it. So Im considering the crossmember relocation as the best way to accomplish the goal. I know that Nate,(Porterbilt) is a busy guy but I would value his input to this situation anyone that can design and build the dropmember with the expertise he has I would think he definitely understands steering geometry. Anyway not to throw cold water on your plans I would sure do some diligent research into this, you have built one of the cleanest rigs on this forum and it would be a shame to create a situation that could possibly prove disastrous you can always build another truck if it gets damaged but you cant restore or replace your body!
02-11-2010, 04:17 PM | #407 | ||
Sofa King Crazy!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 02-11-2010 at 04:23 PM. |
02-11-2010, 05:39 PM | #408 |
low n' slo
if you move the cab back, wouldnt you have to move all the mounts? including the front core support mounts, which holds the grille which bolts to the fenders?
i didnt get a chance to run outside and check my truck to make sure because its ugly ass hell outside and wont stop raining (been off all week and no progress lol)..but i think if you move the cab back, everything has to move. maybe someone can verify that..
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
02-11-2010, 06:04 PM | #409 | |
Sofa King Crazy!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 02-11-2010 at 06:05 PM. |
02-11-2010, 07:51 PM | #410 |
Looking good man. but you slackin on the pics..
02-12-2010, 12:20 AM | #411 |
Sofa King Crazy!!
I'm on it! Should have some for all you picture wh*res tomorrow or Saturday! Of what I dunno, but something!!!
02-16-2010, 03:55 PM | #412 |
Sofa King Crazy!!
Update: I took my engine cradle to the machine shop today, you know that means it is almost time to get the elusive engine back. It has only been 11 months and 12 days, should have it back Saturday!!! Now for the pics, this will have to suffice until I post this weekend.
02-16-2010, 05:11 PM | #413 |
Under Construction
What a tease
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
02-17-2010, 03:33 AM | #414 |
Eat My Rust
02-18-2010, 04:06 PM | #415 |
Sofa King Crazy!!
I traded out the Blazer seats for a set of 88 to 91 buckets, they actually are in great shape just a little dirty. The Blazer seats had a little more rust on them than I wanted to contend with. Also have the bodyman coming this weekend to finish up my rockers and breather cover and a couple of odds and ends. I am getting more excited about the engine too!
02-21-2010, 08:36 PM | #416 |
Sofa King Crazy!!
A little bit accomplished this weekend, wish it was more, here goes.
Test fitted the seats....they are perfect for these trucks! Got my gas filler neck in and got it ready to install when the bed goes on for the last time. Some of you guys will know what these are. Sorry the pic is a little blurry. Camelhump heads.....and they are going on the 327. They look rough now but they won't for long. Couple more hottanks and a sandblasting and they'll look like new. What's this??? My 327! It is not quite finished but getting those heads was worth the wait. He has paint on it so that was a good indication that it will be done soon. My bodyman talked me into painting it the color of the truck.
02-21-2010, 08:45 PM | #417 |
VA72C10
Looking good. I'm painting mine to match the truck too.
Looking for a 67-72 swb or blazer project in or around VA. |
02-21-2010, 08:45 PM | #418 |
Sofa King Crazy!!
Had a couple more pics to share. We started fixing the paint on both rockers and cab corner (no comment). Almost ready for paint.
Got the valve covers and the breather cover prepped and primed so hope to have a little color on those before the end of next week.
02-21-2010, 08:49 PM | #419 |
Sofa King Crazy!!
Thanks bro! Last minute decisions.......they can make you or break you. I think I made the right choice!
02-21-2010, 09:18 PM | #420 |
VA72C10
It's really coming together....engine cover is going to look great and it's going to really flow well with the engine and valve covers all painted the same!
02-21-2010, 09:51 PM | #421 |
low n' slo
good idea on the color matched engine. thats gonna look good.
hey whats seats did you drop in there?
02-21-2010, 10:06 PM | #422 |
"My bodyman talked me into painting it the color of the truck."
Bet he didnt have to talk to hard.... Good choice! Carries out your whole theme. |
02-21-2010, 10:17 PM | #423 | ||
Sofa King Crazy!!
Not too hard
02-21-2010, 10:34 PM | #424 |
Under Construction
Looking. Good David!
02-22-2010, 09:42 AM | #425 |
Now what??
Good choice with the color matched engine! Whole thing is looking good
69 Long Fleet - Project 06 Ram 1ton Cummins 4x4-DD 01 Tahoe- wifes "The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi "A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell my, um, build USMC OIF Veteran SEMPER FI!
Tags |
1967, custom, lwb |
