Old 02-11-2010, 06:19 PM   #1
chevelle518
1964 C-10 Engine
A couple of question's! 1964 C-10 6cyl 3 speed
When changing out 3 speed manual to automatic 400 what do you have to do for cross member mount's?
Will I have to do anything for the cooling system, really do not want to use electric fan's, want to keep it stock look.
Thank's in advance
chevelle518 is offline   Reply With Quote
Old 02-11-2010, 06:57 PM   #2
panelrodder81
Doin' it live!
panelrodder81's Avatar
Re: 1964 C-10 Engine
You need a new automatic cross member out of something up to 1974. You will need to add a transcooler but the cooling system for the engine should go unchanged. Just did a th350 auto in my 64. Again, just get the xmember and you should be good.
-Panelrodder
1953 GMC Panel truck - 'Curly'
1961 Chevy Suburban - 'Larry' - Sold
2005 Harley Sportster - 'Shemp'
panelrodder81 is offline   Reply With Quote
Old 02-11-2010, 08:23 PM   #3
chevelle518
Thank you for the info, I am using a Bcool radiator with tran's line's.
You stated anything 74 back , is that truck only or car as well?
Randy
Old 02-11-2010, 08:32 PM   #4
panelrodder81
Doin' it live!
Truck only. Though you should prolly shoot for 67-74. After 74 they changed the design to an 'L' shaped xmember to accommodate the cats put on the newer trucks. They still work, in fact that is what I have, but they aren't quite as nice as the "double hump" xmembers. You can also get an aftermarket one from a couple different manufactures. But with shipping and the purchase price it was way more than the 25 bucks I paid for mine.
-Panelrodder
Old 02-11-2010, 08:34 PM   #5
chevelle518
Thank you again for your info, we have plenty of junk yard's around here!
Again
Thank's
Old 02-11-2010, 10:10 PM   #6
panelrodder81
Doin' it live!
For sure. I've gotten a ton of info from the forum. Figure I'll throw a little back into the pool!
Good luck
-Panelrodder
Old 02-11-2010, 10:17 PM   #7
TwoFiftyShifter
With an inline, you should look for a Turbo 350.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 02-12-2010, 11:23 AM   #8
Chevy Fleetside
Chevy Fleetside's Avatar
Or you could just buy a new one. http://www.truckandcarshop.com/trucks60_72/t60_097.html $69... Try the bone yard first. I got one out of a 65 or 67 I think and it was rivited in. Good thing for battery powered drills. I think I paid $20 for it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-13-2010, 02:24 AM   #9
Captainfab
60-66 Nut
I agree......there's no reason to run a TH400 behing a stock 6 cyl. The TH400 takes more hp to turn, plus it has a higher 1st gear ratio than a TH350.
Old 02-13-2010, 06:53 AM   #10
chevelle518
I am installing a 350 engine.
Thank you for your info.
