Old 02-11-2010, 11:04 PM   #1
datguysaL
anybody running a x-pipe on a 355? whats the pros/cons?
so i got my truck back from the shop finally, had a bad rear main seal.
its a 85 chevy silverado c10 swb. put in a carburated 1995' 350 bored to 355 with a melling mtc-1 cam, and stock heads and stock rear end gears 3.73 or something like that, also got a edelbrock performer intake and edelbrock 1411 performer 750 carb. i know its a big carb, but i got it brand new for dirt cheap.
so my question is, anybody know how or what benefits i would get with a x-pipe. i need to redo my exhaust, i ran over a basketball and it broke one of my longtube headers, so ima pull that one off and if i cant weld it back together, then ima have to buy me a new set. whats the best exhaust size to go with this set-up? any info to make it better i appreciate. or should i rip out the cam and get something different? like what? thanx!!
datguysaL is offline   Reply With Quote
Old 02-12-2010, 12:38 AM   #2
wfomkivdrvr
HORSEPOWER JUNKIE
wfomkivdrvr's Avatar
Re: anybody running a x-pipe on a 355? whats the pros/cons?
2.5 or 3 inch should work great the x pipe built correctly helps to empty the cylinders your 750 is fine i used to run a 780 on my 350 with and extreme energy hyd comp cams full length headers and 3 inch with flows in a heavy 70 monte carlo it ran very strong!
67 C20 fleetside custom camper
69 El Camino
72 Camaro
52 Dodge b3b 108 pickup
wfomkivdrvr is offline   Reply With Quote
Old 02-12-2010, 02:18 PM   #3
datguysaL
thanx, ima pull it off this weeknd, depending on the weather. thanx bro, appreciate it.
Old 02-13-2010, 02:30 AM   #4
wfomkivdrvr
HORSEPOWER JUNKIE
good luck post up how it turns out!
69 El Camino
72 Camaro
