Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-12-2010, 07:38 PM   #26
djracer
djracer's Avatar
Re: big Hp thats turn key??
Sweet
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-12-2010, 08:48 PM   #27
69trk
69trk's Avatar
I paid 3800 for mine carb to pan shipped from awsome engines in delaware. Somebody was paying but never finished paying. All it had was dyno time on it. If you shop around there is some very good deals out there. Especially with a down economy..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 02-12-2010, 11:02 PM   #28
Super73
Super73's Avatar
What's interesting is when I wanted to sell my forged 347ci LS1, I wasn't getting any traction at $4,250.. I was offering it as a complete long block with the ported heads and cam, ready to run minus covers and an intake. I was going to throw in the tune as well. At the time the motor made 428rwhp NA with an LS6 intake through a 4L80E with a 12 bolt.
My point to this, the economy flat out sucks for people selling, but if you look for something used, you could find a killer deal.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-12-2010, 11:04 PM   #29
djracer
djracer's Avatar
Everybody is broke..............................................Well at least I am.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-12-2010, 11:52 PM   #30
ripdog28
ripdog28's Avatar
I have been seeing a lot of Dart/Merlin BBC blocks for $15-2000. Making me think of grabbing one for a 520-580ci build to swap out.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 02-13-2010, 12:09 AM   #31
djracer
djracer's Avatar
dart is better of the two and you can get one machined and ready to put together in the low 2's
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-13-2010, 02:26 AM   #32
ripdog28
ripdog28's Avatar
I would prefer Dart but if Merlin III are $1500 and under ill take one. I have seen Merlin's cheaper then Darts. RaceJunk.com has a few Merlins for under $1600 new. Figure a Scat 9000 for under $400 with some H beams and forged will handle 700+hp. then use my Dart cylinder heads and get a roller. Man im dreaming, maby in a year or so. I would like to build a 4in stroke at about 520CI or just get a 555+ with 4.25in. I am liking the idea of a big bore small stroke. High rpms
69 c-10 BBC
Old 02-13-2010, 11:32 AM   #33
djracer
djracer's Avatar
I bought my Bowtie block for about 600 but I have a ton in machine work. If I had it to do over I would call Sunset Racecraft and order a Dart ready to go.
On the bore and stroke thing I would rather have a 496 than a 502. You can do the 496 in a stock block.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-13-2010, 12:04 PM   #34
cableguy0
Its cheaper to spend more on the dart block. Your machinist will thank you. The world blocks always require a good bit more work to get them right
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-13-2010, 12:33 PM   #35
nomrlz
nomrlz's Avatar
you can buy a used 815" pro-stock headed BBC now for $20K or less. a motor that cost $60K+ new and drops 2/3 to 3/4 its value like that.
i've seen street 540' BBC with conventional heads selling for under $5000 turn key. it is unreal the deals out there right now
nomrlz is offline   Reply With Quote
Old 02-15-2010, 12:14 PM   #36
Burb
Coordinator of Synchronicity
Burb's Avatar
Well this mighty mouse was planned on a budget but as a torque tempered daily driver running 9.5 to 1 on pump gas that is going to be recieving some secret boost. Upped the tranny's ablilty and put together a budget modified a 14 bolt FF rearend w/ Posi and custom 8 lug rear disc brake system.
So the mouse will be growing some bigger teeth soon ...
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 02-15-2010, 02:20 PM   #37
shawnt
shawnt's Avatar
If you want good customer service, a ton of knowledge, and reasonable prices I would talk to Mike Lewis (Mike@Lewisracingengines.com). He can build you anything you need. Or Mark Jones (VortecPro@Gmail.com), who is also very good. Either one of them can get you high HP for a very good cost.
Shawn
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 02-17-2010, 03:48 PM   #38
Burb
Burb's Avatar
I did see a cut away of the newer DART block ... showing the improved oil pathways to the main bearings and "siamesed cylinder walls" Very Impressive.
Rick
Old 04-06-2010, 03:07 AM   #39
454Headache
You can get a rebuilt longblock 454 for under $2,000. Swap out the heads (anything closed chambered less you want to swap out pistons or milled patriot performance, NOT PRO-COMP!), and cam, and you can get an easy 450 hp for as cheap as you can get. $1,800 for motor, $1,400 heads, $200 cam.
1990 454SS with '97 454 Roller Vortec
Mercury Marine Takeout Cam
Dual 600 Edelbrocks
Edelbrock Street Tunnel Ram
No A/C, Heater, or Power Steering
TH400, 2,800 Anti-Balloon Stall
Hurst Shifter
3.73 POSI rear
Taurus E-fan
Schuck's Radio and 15's
454Headache is offline   Reply With Quote
