New from Alberta
Hi from Alberta, Canada. I've got a 2002 GMC Yukon and just bought a 1980 GMC Step Side 4x4.
I've had the Yukon for a couple of years, and have put in 3" Skyjacker lift and a custom stereo. The wheels and tires are all Pro Comp; alloy 16" wheels and 33" M/Ts. I put an SLP cold air intake on, and tune the engine with an Edge programmer.When I bought it, it already had a Jardine cat back system, projector headlights, and aftermarket guage cover. It's my daily driver and is regularly used on construction sites. ![]() The 1980 GMC Step Side 4x4 looks like it has a 4" Rancho lift; likely to be replaced, a worn 350 engine, 350 trans, and the full time 4WD t-case (203?), and sits on 35" Dunlop M/Ts. I plan to replace the seals and bearing in the axles (14 & 10 bolts), and installing an SM465 with a 203/205 doubler. The 350 will have a 383 rebuilt to replace it. ![]() This looks to be a great place to find info and get ideas.
And now, a word from my lawyers... This post is the intellectual property of the person commenting under the pseudonym "GMC Trucker". These posts are for entertainment only. Copying or quoting in whole, or in part, is given free license for use by any member of this board for use on this board. Any use, in whole or in part, for reference outside this forum requires the express written consent of its author. Last edited by GMC Trucker; 02-12-2010 at 10:36 PM. |
The One And Only !!!
Re: New from Alberta
Welcome from the Sunshine State !!! Don't think you can find a better place or bunch of people than right here.... Those ![]() ![]() Your Yukon looks super sweeet ! ![]()
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
www.infantimachine.com
Welcome from Delta,BC
Gerry |
Welcome from the west coast.
