02-13-2010, 08:50 AM | #1 |
Any fabricators want to make me something
I don't really have anyone local who can make these. Someone want to make a pair of these for me. Let me know how much, I need these.
The outside dimensions are 5 inches high (just under actually) by about 6 1/4 inches. The 4 corner holes are actually 7/16ths not 9/16ths like the picture says.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 Last edited by Thealien; 02-13-2010 at 10:10 PM. |
02-13-2010, 11:32 AM | #2 |
Re: Any fabricators want to make me something
i can build them for you. it would be the first of the week before i could get it done. if nobody can do it sooner let me know.
02-13-2010, 12:12 PM | #3 |
Thealien, you about to get your LS engine in? I'm test fitting mine today. Good luck with the plates. I found after having mine cut out at one shop and having the one hole countersunk(different design from yours) at a machine shop I could have bought them cheaper off the internet from one of the shops. What engine perches you using with yours? I'm trying the 6 cyl. perches with mine and my homemade/shop adapter plates, stock motor mounts for 327. Good luck. Jim
02-13-2010, 01:12 PM | #4 |
That would be fine
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
02-13-2010, 01:36 PM | #5 | |
02-13-2010, 01:53 PM | #6 |
Lets see if this helps:
I wanted to keep my t.c. in the stock location, also. I connected my LQ9/4l60e with the adapter from AA, also. I also used a spacer between the tranny and the t.c. adapter. It is the one we have discussed for the 700r4 conversion. I took a AA LS mount adapter and flipped them to the opposite side. i.e. the left on the right and the right on the left. I cut off the extra portion of the plate so it would fit. That then moved my engine about 1.75" or 2" forward, from what I remember. I used a custom '73+ style crossmember and clamshell motor mounts. The crossmember was a couple inches above and rearward from the D44 pumpkin. I then put on 4" lift springs. I'm not sure if the mount would clear the stock lift if it were flexed...but it might have. I wanted 4" lift, regardless.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 Last edited by OldCreek; 02-13-2010 at 01:58 PM. Reason: more info |
02-13-2010, 02:07 PM | #7 |
a few pics:
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
02-13-2010, 02:11 PM | #8 |
Hope these help. These are with original stock 2 spring pack.
02-13-2010, 02:20 PM | #9 |
Thanks for the pics but I do have a couple of reasons to not go that way. I want to use the stock flex fan in the stock shroud so I want to be able to have a little leway up or down with my engine, using most of the DIY4X4 frame brackets will allow me that flexibility. Without a lift there is no way to have enough clearance without some kind of custom crossmember. I do have a plan though (third time is a charm.). I had originally planned on doing just as you were doing with the adapter plate (cutting and using on oposing sides) but I have already made swiss cheese out of mine trying a few options. I figure this way I can start from scratch on the plate. Plus all the adapter plates out there are 3/8ths and I want mine 1/4 which I feel is plenty strong enough and it will help with Kerts crossmember being a little too narrow on the bolt holes (even though I am probably just going to make a new one using his motor mouts, bushings, frame mounts and the plates that bolt to them).
02-13-2010, 05:05 PM | #10 |
Sometimes figuring out all these little things is sooo frustrating! All the little things add up to so much time "wasted".
Good luck.
02-13-2010, 10:08 PM | #11 |
Ain't that the truth! Hopefully by the time I am done I will be able to help others from making my mistakes. I'm in a borrowed garage too and don't want to wear out my welcome! Should have a lot of progress in the next 4-6 weeks. Until the next snag rears its self!
2WD would be sooo much easier!!
