02-13-2010, 04:06 PM | #1 |
NP205 Trans Case Mount
I have a 68 K10 that the previous owner has installed a NP205 and SM465 into. The transfer case had no poly or rubber mounts between it and the frame when I bought it, it was just bolted to the frame. I am putting in a new transfer case mount and am wondering exactly how it should be placed. Anybody have pictures of how their's is mounted? The assembly manual is no help on this one.
The mount has 4 poly pieces (2 bigger ones and 2 smaller ones) and a metal piece which has 2 big holes in it that the poly pieces fit into. Any ideas? Thanks in advance. Last edited by kyoung; 02-13-2010 at 04:07 PM. |
02-13-2010, 04:40 PM | #2 |
Re: NP205 Trans Case Mount
are you talking about the bottom mounts or the side?
Bottom: big one's on top, little one on bottom, metal sleeve inside... Side: borrowed pic
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-13-2010, 07:55 PM | #3 |
Mike.
The side mount is what I am asking about. My set-up does not look like what you have...Maybe I'm missing something. I do not have the top piece that you are showing. I have the bottom piece which is bolted to the transfer case. But it was directly bolted to the frame...I tried to put the flat part of the mount under the frame but it caused the transmission to be tilted in a bad angle. |
02-13-2010, 08:54 PM | #4 |
Yes, you are missing the piece that bolts between the verticle side of the chassis and the top of the bracket on the transfer case.
1972 K2500 Long Box 400/350 |
02-13-2010, 09:06 PM | #5 |
Redneck Customs Bumpers, IA
ok I have a dumb question then, I'v had 3 square body chevy's (83, 79, 76) with the NP205 , SM465 combo and not a one of them had that mount, was it a option or had all 3 of my trucks had that pulled off for some reason?
02-13-2010, 09:11 PM | #6 |
02-13-2010, 09:14 PM | #7 |
naw they have the mount between the trans and t-case and another crossmember immeaditally behind the t-case with no mounts on it, they don't have the mount your picturing at all
02-14-2010, 12:21 PM | #8 |
Is that mount available in after market?
02-18-2010, 01:28 PM | #9 |
Sb 400 club
my 77 crossmember mounts right to the frame. The 205 to th350 adapater sits on two poly mounts.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
02-18-2010, 09:19 PM | #10 |
that is the exact mount on my sm420 and t221. weird.
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
02-19-2010, 10:08 PM | #11 |
My 73 K20 has the side mount for the 205 case. It was a 465 trans now its a th350. But my 78 with the 465/205 did not have one and it never gave me a problem.
06-05-2020, 12:25 AM | #12 |
Chevy stopped using that mount as it was cracking the transmission bell housing on the automatics.
They came up with a rod that bolted into the holes on the side of the 205 and the other end bolted to the back of the block where the bell housing bolts too, to create a triangle to keep the 205 square to the back of the engine when under heavy load. You need to hold the engine in two locations and the transmission and transfer case in a third position. A 3 legged chair always sits flat having the same pressure on each leg. Adding a mount to the side creates stresses that breaks stuff. |
06-05-2020, 01:57 AM | #13 |
Good information for people to have. But, do you know that the last post to this thread was over 10 years ago?
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
06-05-2020, 04:28 PM | #14 | |
06-05-2020, 07:22 PM | #15 |
goes in a bellhousing bolt hole . there is a bolt / stud in that place and the bar goes on the stud part and a flange nut secures the bar to the bolt/stud unit .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
06-07-2020, 08:03 AM | #16 |
Thanks for the reply, that makes sense
