Old 02-14-2010, 06:59 PM   #1
grs
Brake line in frame
I want to replace the rear brake line on my 69. It is connected inside the frame. I have been trying to soak it with penetrating fluid. If I can't get it loose I will have to replace the brake line from front to rear. My brakes work very well. I just need to replace the hose. Any ideas on how to get it freed up?
grs is offline   Reply With Quote
Old 02-14-2010, 07:13 PM   #2
rsavage
rsavage's Avatar
Re: Brake line in frame
Use a tubing wrench after soaking it again and again for several days with a quality penetrating oil like "Deep Creep". Then carefully try it attempting to both loosen and tighten. If it doesn't go, more penetrating oil applications and time.The longer you are patient the better chance you will have of breaking it loose without twisting and ruining the line. When I've been patient, I've been successful. When I was not, I replaced more than I had hoped.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-14-2010, 07:19 PM   #3
grs
Thanks. I have a little rag wrapped around it now. It is soaked with penetrating fluid.
Old 02-14-2010, 07:57 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
You might try a little heat also.
Sometime a small propane torch is enough to break loose the rust.
When you reassemble the new hose,... use a little anti-seize on the threads,... and it will never happen again.
Old 02-14-2010, 08:28 PM   #5
Thealien
Thealien's Avatar
What has worked for me. A little anti sieze on the tube where the nut turns also helps a little. Just be carefull with that never sieze, you'll find little dabs of silver on everything
Old 02-14-2010, 08:41 PM   #6
mbgmike
I do that all the time It gets every where. They do make clear never sieze but i can never seem to find it
mbgmike is offline   Reply With Quote
Old 02-14-2010, 09:34 PM   #7
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
X2.
I've done that many, many times-- turn the nut yellow, then they come right loose with no fuss.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 02-14-2010, 10:00 PM   #8
cparman
sharp as a marble
I suppose this line connects to the flex hose coming from the front of the truck? If I am correct, I would have a new flex line, and new metal lines to both rear wheels available. What I have experienced is that the metal line seizes to the metal nut. This keeps you from turning the nut on the line. SO, if you cut the line, remove the clip holding the line to the frame mounted clip. and unscrew the flex line from the metal line, you should be able to unscrew them from one another. Then you will need to replace both with new lines. HTH
Chip
cparman is offline   Reply With Quote
Old 02-14-2010, 10:32 PM   #9
glider_6969
You can get that anti-seize in a roll on stick, beats using the brush in a can, and alot neater.
glider_6969 is offline   Reply With Quote
