Old 02-15-2010, 01:17 PM   #1
marina blue bob
marina blue bob's Avatar
Install new cab mounts - 67 K-20 fleetside
any advice from those who've installed new cab mounts ? Is is just a matter of putting 4x4's under the reinforced floor channels and jacking up the cab carefully ?
also, after putting in new cab mounts, can I expect the lower belt line of the bed to no longer line up with the cab ?
Thanks for any advice out there.
marina blue bob is offline   Reply With Quote
Old 02-15-2010, 03:32 PM   #2
ole red
Re: Install new cab mounts - 67 K-20 fleetside
On mine i used a floor jack and some 2X4's, they went in real easy. Getting the old bolts out in the cab was the hardest. I would soak with WD 40 for about a week before attacking.
69 stepside, 1/2ton, 4X4, 350/350/205
ole red is offline   Reply With Quote
Old 02-15-2010, 04:11 PM   #3
marina blue bob
thanks alot Ole Red -- appreciate the advice.
did your cab sit higher than the bed afterward ?
Old 02-15-2010, 08:36 PM   #4
ole red
Yes it did and it made it ride smoother too.
Old 02-15-2010, 08:39 PM   #5
msgross
msgross's Avatar
the rubber mounts?
I used the OEM style from LMC... you should get your cab back to stock height since the bed is firmly mounted... Most guys don't recommend poly mounts due to the stiffness.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-15-2010, 10:42 PM   #6
marina blue bob
thanks mike - I did get the rubber ones from LMC --- I'd read alot of posts saying the polys gave a stiff ride.
Old 02-16-2010, 07:03 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
moving this to the truck forum instead of the burb forum.
Old 02-16-2010, 07:12 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Use PB Blaster or Liquid Wrench on the bolts instead of WD-40. It works a whole lot better.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
