Old 02-16-2010, 11:19 AM   #26
pumpkin
pumpkin's Avatar
Re: how much is this worth
Originally Posted by memphismade.l.a.w View Post
ok did some research its an olds motor
your research is wrong. That is a buick engine. Cant tell what size from the front as all buick engines look very similar from that angle. Chev, olds, and pontiac have the distributor in the back. Buick, cadilac and fords have the distributor in the front. As far as the value of the truck, I would put it at whatever the box is worth. Anyone that would drop a buick engine between the framerails, and walk away from the project, has probably hacked the rest of the truck as well.
pumpkin is offline   Reply With Quote
Old 02-16-2010, 11:46 AM   #27
OhOneWS6
OhOneWS6's Avatar
I agree about the Buick engine. I noticed that at first but I didn't think that cap was on the distributor. It looked like it is just sitting there.
OhOneWS6 is offline   Reply With Quote
Old 02-16-2010, 01:26 PM   #28
memphismade.l.a.w
memphismade.l.a.w's Avatar
Ill have to tell the guy this
memphismade.l.a.w is offline   Reply With Quote
Old 02-16-2010, 03:26 PM   #29
83Silverado
83Silverado's Avatar
I couldn't tell you what it was
83Silverado is offline   Reply With Quote
Old 02-16-2010, 03:36 PM   #30
Blue71LWB
Blue71LWB's Avatar
well im 16 so idk how much i can afford to do
If this is the case, run away from this one as fast as you can. If you can hold out, you should be able to find one around $1,000 that you could at least drive around while you fix it up. If you sunk $1,000 into this jewel it still wouldn't be able to see the road. It's worth $400 , but it sounds like you need some wheels ,and if this is the case, I do not think its a good deal. This one is not worth the gas to go look at it. JMO
Working on my first 1,000 post.
I'm sure I'll get there before this project is over .
Blue71LWB is offline   Reply With Quote
Old 02-16-2010, 04:52 PM   #31
memphismade.l.a.w
i see what yall are sayn its just hard to find them close to tn or in tn for my price range being a swb
Old 02-16-2010, 07:34 PM   #32
83Silverado
hey memphis, check it out
http://memphis.craigslist.org/cto/1604039235.html
-Keith
