Old 02-16-2010, 12:08 PM   #1
NevadaDVX
Automatic steering column problem
I am doing body work on a 71 for a lady and yesterday, when I moved the truck out of the shop, the shift selector would not pull back and go back into park. All other gears work fine. So, I popped the pin out of the shift lever and saw a ball on the end of the lever that goes into a piece of flat metal with a hole in it inside the column.
Is that piece of metal supposed to slide down when the lever is pulled back? Should I spray some lube in there? I don't really want to make a big project out of this if I don't have to. Any help/advice is much appreciated.
NevadaDVX is offline   Reply With Quote
Old 02-16-2010, 12:39 PM   #2
OhOneWS6
OhOneWS6's Avatar
Re: Automatic steering column problem
Spray a little WD-40 in there and work the lever back and forth. It will loosen up.
OhOneWS6 is offline   Reply With Quote
Old 02-16-2010, 03:31 PM   #3
NevadaDVX
Thanks, it worked perfectly. I guess I should have tried that before I posted.
