Old 02-16-2010, 01:44 AM   #1
bman1985
mileage
I'm planning to fix up an 82-87 c10 2wd as a daily driver. Right now I'm thinking 350 (decent build for some power) with a 700r4 and maybe 3.73 gears. What kind of mileage do you guys get?
bman1985 is offline   Reply With Quote
Old 02-16-2010, 02:27 AM   #2
GMC Guy
GMC Guy's Avatar
Re: mileage
kinda depends on what set-up you're running on that 350. but i'd say 12-18 depending on how you drive.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 02-16-2010, 02:39 AM   #3
spinem
haha, ford guys...
Re: mileage
haha i wish i got 12.... if u hit alot of greens, u can get a good 12-18... maybe 20 highway.
spinem is offline   Reply With Quote
Old 02-16-2010, 02:48 AM   #4
ocbaud
Garage Queen Material
Re: mileage
10mpg or so combined with my engine and th350 and 3.73's
ocbaud is offline   Reply With Quote
Old 02-16-2010, 10:55 AM   #5
C10_86
C10_86's Avatar
Re: mileage
My '86 long bed has a fresh stock 350, rebuilt Q-Jet with performer intake and a 700R4 with 3.42 rear end and I get 19-20mpg highway and 15-16 combined average.
I have gotten 21.5mpg on a 300 mile trip before. Nothing beats a properly rebuilt Q-Jet for mileage.
C10_86 is offline   Reply With Quote
Old 02-16-2010, 11:45 AM   #6
C10Silverado79
Re: mileage
I rebuilt a 2 bbl carb on a 250 6-cyl once but that was a lot of years ago. Can these carbs be rebuild by a rusty DIY'r or do they need to be rebuilt by a shop? Are rebuild kits available? I have never had a 4-bbl carb before.
1979 C10 Silverado
1998 Camry 5spd
2005 Harley ElectraGlide
C10Silverado79 is offline   Reply With Quote
Old 02-16-2010, 11:55 AM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
Re: mileage
Running an 84 GMC SWB, with a 385 stroker, through a 700R4, to 3.73 gears--getting 14.5 to 15 MPG on the highway. I run 28" tires on the rear and 27" on the front. My RPMs are at 2500 at about 72 MPH. I consider this a good combination, since I have a lot of hilly areas to deal with and this allows the cruise to work without a lot of hard revving to make it over the hills.
My Son's truck has a 350, 700R4, with 3.73 gears and he gets around 13.5 to 14 MPG.
Both of the 700 R4 trannys do NOT have the Lock up converters-----They were built this way.
Frank
Old 02-16-2010, 12:29 PM   #8
bman1985
Re: mileage
Yeah, I haven't decided what I want to do with the motor exactly yet. I'm still in the looking for a truck/dreaming phase. I'm sure it won't be a stock 350, I really like the HP numbers of those edelbrock performer RPM motors but that might be a little over budget. I've also considered a 5.3 from a newer truck (which would get better mileage I assume) but I've got a 4 bolt 350 block in the garage already.
Piecesandparts-I like the black c10s in your picture there thats about what I'm looking to do, maybe some yellow stripes
Old 02-16-2010, 01:49 PM   #9
GMC Guy
GMC Guy's Avatar
Re: mileage
you can pick up a rebuild kit from your local auto parts store for around $25.
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 02-16-2010, 01:50 PM   #10
GMC Guy
GMC Guy's Avatar
Re: mileage
how do you like the 700r4 and 3.42 combo? seems to do pretty well on the highway, but how's the performance around town?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 02-16-2010, 02:12 PM   #11
C10_86
C10_86's Avatar
Re: mileage
It's a little annoying in town since it shifts so early. You can be in 3rd gear by 20-25mph and fully locked up in O/D by 35-38mph if your very light on the pedal but I got used to it. As for highway driving I like it. It climbs hills very well and rarely shifts out of O/D with the cruise on.
Old 02-16-2010, 02:27 PM   #12
C10_86
C10_86's Avatar
Re: mileage
You can do it yourself but you have to be sure the bowl is not warped. It is a common issue with Q-Jets and will cause problems if not corrected. Also if you do it yourself make sure you epoxy the well plugs in the bowl as they are prone to leaking fuel. I did not not do mine myself. I would recommend a company called Carburetor Exchange www.carb-x.com in California that most likely has the carb you need already rebuilt and ready to ship. You just send them your old one for a core exchange. Mine cost me $185.95 + shipping. It's completely rebuilt, dewarped set up to factory specs and run on a live engine before shipping. I just bolted mine on and haven't touched it since.
Old 02-16-2010, 03:23 PM   #13
C10Silverado79
Re: mileage
Thanks for the info. I'm not so sure I want to do it myself so I will keep this company in mind.
1979 C10 Silverado
1998 Camry 5spd
Old 02-16-2010, 11:56 PM   #14
bman1985
Re: mileage
what about TBI does it have any significant benefits over a carb mileage/power wise for a daily driver?
Old 02-17-2010, 12:20 AM   #15
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: mileage
ZZ4 will get 13-15 in the city. Drops really quick with a lead foot. 18+ MPG on the highway at 70 MPH.
Fuel injection is the way to go for a daily driver!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-17-2010, 12:38 AM   #16
bman1985
Re: mileage
Yeah I was starting to think that after I looked into it more. Sounds like its all benefits except for the initial install which take some more work. Is TBI any good (it seems more simple and cheaper) or do more people go with TPI systems?
Old 02-17-2010, 03:10 AM   #17
gchemist
gchemist's Avatar
Re: mileage
LS conversions are becoming popular. I saw an ad for a 5.3 for only $800 locally. It had 108K miles on it. Read this:http://www.hotrodlane.cc/77chevytruck/77chevy.htm
A TBI conversion is the simplest and least expensive. Stock parts are available from donor trucks or over the shelf. Read this for a TBI conversion.
http://users.sfo.com/~eagle/howell.html
For lower power grunt, TPI is good. TPI however has limitations on the top end.
Old 02-17-2010, 07:26 AM   #18
D13
D13's Avatar
Re: mileage
TBI is good for 1-2mpg and way better cold driveability. Unless you get all the parts cheap or put 200K miles on it you'll never recover the cost of the parts. Sure is nice on cold starts though.
If you rebuilt a staged 2bbl off the integral head 250 the Qjet should be easy. Nowhere near as finicky. Buy the gallon can of cab soak (the main body probably won't fit in it by the way), 3-4 cans spray carb cleaner, and a pack of toothbrushes. IIRC needlenose, channel locks, and screwdrivers.
And don't forget to epoxy the well plugs with a gasoline and alcahol resistant epoxy.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-17-2010, 08:40 AM   #19
Keith Seymore
Keith Seymore's Avatar
Re: mileage
I get 22 mpg; 4.3L V6 TBI, MY6 3 speed manual where 4th gear is a .73 overdrive, 3.73 posi axle with P235/75R15 tires.
Drive it every day, rain (or snow) or shine!
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-17-2010, 09:52 AM   #20
Dooley Dude
Dooley Dude's Avatar
Re: mileage
My truck is a little different, but I recently got some great gas mileage and I wanted to brag about it. My truck is an '85 C-30 Dooley, 350 with a TH-400, 4.10 gears and stock Q-jet. I drove it down the interstate (empty) and back with a full load of furniture in it. Speeds averaged around 60 mph. I got between 10 and 11 mpg, and I was tickled!
Your mileage may vary. I'm pretty happy with mine. My neighbor has a little F-150 with a V-6 and he gets 17. Years ago a friend of mine had a little Ford Ranger with a manual tranny and tiny 2.0 4-banger, and he consistently got only 20 mpg.
Dooley Dude is offline   Reply With Quote
Old 02-17-2010, 10:24 AM   #21
TwoFiftyShifter
Re: mileage
Also, dont build your motor too nasty if mileage is important.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 02-17-2010, 10:44 AM   #22
bman1985
Re: mileage
I'm thinkin the TBI system since its cheaper and simpler. I haven't really found much showing huge benefits of TPI over TBI.
My cousin is actually working on an 83 monte carlo that he plans to drop and LS into I guess he'd be a good source of info on that swap since hes ahead of me on his project!
--thats pretty solid mileage for a loaded up dooley!
