Old 02-16-2010, 10:23 PM   #1
lnwlfbsktbll
lnwlfbsktbll's Avatar
Project 6.0 (my '87)
Ok I've been using this site for a while now, figure its about time I start my build thread. To start off I've got an '87 GMC swb that I've had about 5 years now and it used to be my daily. Long story short it had motor problems, and i got a new car so this is now my project. My general plan is to get the 6.0 I have in the truck and back it by a 6L80. Pictures are next.
'87 SWB GMC LY6/6L90E
'70 JEEP CJ5... My new toy
'06 Hyundai Accent... DD
Build thread located at http://67-72chevytrucks.com/vboard/s...5708&posted=1#
lnwlfbsktbll is offline   Reply With Quote
Old 02-16-2010, 10:29 PM   #2
lnwlfbsktbll
Re: Project 6.0 (my '87)
Here are some pics of it before I started a few months ago.
Old 02-16-2010, 10:35 PM   #3
lnwlfbsktbll
Here are some as i took the front end apart. I wound up finding a crack in the passenger side of the block under the center 2 exhaust ports.
Old 02-16-2010, 10:38 PM   #4
lnwlfbsktbll
My Vortec 6.0 LY6... now all I need is a 6L80 I can afford and to tie up a whole lot of ends.
Old 02-16-2010, 10:39 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks great. Any pics of the 6.0? Great looking project.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 02-16-2010, 10:42 PM   #6
lnwlfbsktbll
Old 02-16-2010, 10:45 PM   #7
lnwlfbsktbll
There ya go! Accidentally left them off the first time.
Old 02-17-2010, 08:29 AM   #8
menace121978
menace121978's Avatar
right on man! going to be sweet. looks like the motor was taken out clean. no hacked wires or hoses i can see.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 02-17-2010, 12:35 PM   #9
JohnC
JohnC's Avatar
Hey glad to see you're getting started on it. Looking forward to updates.
JohnC is offline   Reply With Quote
Old 02-17-2010, 11:01 PM   #10
STOCKISH
STOCKISH's Avatar
You know, if the turbo 400 that was in there is good you can just use a crank spacer and run the turbo 400 since you dont have a trans yet. Just an option.
--Josh
Old 02-17-2010, 11:53 PM   #11
mcbassin
Still Learning
mcbassin's Avatar
Great looking project! I can totally relate to the cracked block. All you need is a little JB weld....it will fix you right up. Sweet looking new engine too! subscribed.
Old 02-18-2010, 03:06 PM   #12
builtchevystrong
Originally Posted by lnwlfbsktbll View Post
hey how much did it cost for that motor and where did u get it?
builtchevystrong is offline   Reply With Quote
Old 02-19-2010, 11:26 PM   #13
lnwlfbsktbll
That was my original plan but what I've read about the ly6 says there isn't a manual tune version of it because of the vvt. Please correct me if thats wrong.
Old 02-19-2010, 11:35 PM   #14
lnwlfbsktbll
I bought it locally after seeing it on ebay, ebay listing was for 2k but I paid 1850 and tax for it because I was local. None of the vacuum line or wires appear to be cut only thing I see that were are the radiator hoses and ac lines.
Old 02-22-2010, 11:52 AM   #15
fpjr0
fpjr0's Avatar
nice.. good luck with build
fpjr0 is offline   Reply With Quote
Old 03-11-2010, 10:54 PM   #16
lnwlfbsktbll
So I've been trying to get undo the cab mounts so that I can clean up the frame and install new body mounts but I can't get the bolts out.
An impact wasn't cutting it so I put a couple small holes on the inside of the cab to get some wd40 on the nuts. That didn't work. Anybody have a similar situation? If so how did you go about getting them out? I considered cutting the head of the bolt off so i can just start on the frame, but that still leaves me with a bolt stuck in the cab. Any suggestions?
Old 03-11-2010, 11:14 PM   #17
mcbassin
Still Learning
mcbassin's Avatar
Any chance you can try to use a torch or heat gun on it? Sometimes heat can go a long way, just a thought.
Old 03-11-2010, 11:21 PM   #18
bigdnew
Never Satisfied
bigdnew's Avatar
Doing the same swap, subscribed.
1973 4x4 Blazer- Parting Out
1986 LWB Silverado Undergoing LQ4/4L80E Swap
'86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566
bigdnew is offline   Reply With Quote
Old 03-12-2010, 01:36 AM   #19
lnwlfbsktbll
That's what I was thinking next and I can get to the nuts pretty easy now that I cut a couple holes. Just don't have a torch right now so i guess I'll have to get one.
Old 03-12-2010, 11:44 AM   #20
Chevyman350
instead of wd40 you should try some pb blaster or better yet Kryoil.
They are some of the best penitrating oils i have found. With kryoil beinghte best but less commonly avaiable. You may want to soak it and let it work for a day.
Chevyman350 is offline   Reply With Quote
Old 03-13-2010, 12:13 AM   #21
lnwlfbsktbll
Thanks I'll look into them
Old 03-13-2010, 12:17 AM   #22
flamingbig10
6.0 powered square
flamingbig10's Avatar
1/2" or 3/4 brake over bar with a cheater pipe should do it that how I got mine off
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-14-2010, 06:08 PM   #23
fpjr0
fpjr0's Avatar
I 2nd the cheater pipe... do it do it do it
ONCE YOU GO LS, YOU NEVER WANT LESS!!
Old 03-14-2010, 08:25 PM   #24
HotRod73
HotRod73's Avatar
nice build thread man that swap is exactly what i have been wanting to do.. this is the guy who sold you the plastic trim pieces.. ill let you know on back window..
1973 Chevrolet C20 (Under Construction)
HotRod73 is offline   Reply With Quote
Old 03-14-2010, 10:38 PM   #25
lnwlfbsktbll
Cool, thanks for those btw. I was about to search and send a friend request, looks like you did the work 4 me.
