Old 02-17-2010, 11:35 AM   #1
Malibob
Malibob's Avatar
1/2 ton or 1 ton crossmember
Is there any difference between the 1/2 ton, 3/4 ton or 1 ton crossmembers? I am buying a 1 ton crossmember (hopefully) to chop for my 1/2 ton C-10. Anyone know if I should watch out for anything?
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 02-17-2010, 01:15 PM   #2
62gmc910
62gmc910's Avatar
Re: 1/2 ton or 1 ton crossmember
I believe that the lower A arm cross shafts mount Differently so if you are using 1/2 ton A arms you might want to check that out , and they may be heavier ??
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 02-17-2010, 01:18 PM   #3
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
The cross shafts on the 3/4 and on ton lower control arms are bigger, therefore the mounts on the crossmember are also bigger. the crossmember dimensions i believe are the same though, but don't quote me on it!
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
Old 02-18-2010, 01:13 AM   #4
Captainfab
60-66 Nut
What vintage crossmember are we talkin?
Old 02-18-2010, 08:17 AM   #5
Malibob
Malibob's Avatar
Thanks for the help so far guys.
Captainfab- I have a '65 and the donor crossmember I found was from a 1 ton dually. Real good price, $35 less than anyone else. So I wanted to use it, but if it required more work, then I will invest the money.
Flickr
Old 02-19-2010, 02:06 AM   #6
Captainfab
60-66 Nut
Is the Dually crossmember a '63-'66, '67-'72 or a '73-'87?
Old 02-19-2010, 08:08 AM   #7
Malibob
Malibob's Avatar
'85
Flickr
Old 02-20-2010, 02:31 AM   #8
Captainfab
60-66 Nut
That will use the round LCA shafts. I'm pretty sure that the LCA shafts are the same size between C10,C20 and C30 within the '73-'87 years. What lower control arms are you going to use?
1/2 ton, c-10, crossmember
