Closed Thread
Old 02-18-2010, 12:47 PM   #26
dv8customs
dv8customs's Avatar
Re: Hey i just got shafted! Take a look the sight of being shafted never looked so go
Originally Posted by CPPJEFF View Post
Basically i can make anyone of these up for you, just give me the spline count on the column and the spline count on the steering box and i can make one up. Thanks
I am swapping my '86 over to a rack and pinion. Can you get me a price on a 1"DD by 3/4DD joint and 3/4-36 spline by 3/4DD with say 22" of DD shaft. Not sure how long of a shaft I need but 22" should do it.
dv8customs is offline
Old 02-18-2010, 12:50 PM   #27
CPPJEFF
No sweat $45.00 a joint and the shaft is $30.00 but its all nickle plated and it would be 36 inches. We only sell shaft in 18" and 36" inch. Thanks let me know.
CPPJEFF is offline
Old 02-18-2010, 01:19 PM   #28
dv8customs
dv8customs's Avatar
Awesome! I will give you a call to oder..
Old 04-07-2010, 09:39 PM   #29
msgross
msgross's Avatar
wow, that has me thinking now... good price too..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline
Old 04-08-2010, 10:14 AM   #30
CPPJEFF
No sweat, let me know if you need one. Thanks
CPPJEFF is offline
Old 04-10-2010, 03:42 AM   #31
ConnDemned
$100.00 like that.
Does this offer still stand for 2 billet u joints and shaft? I need a set but need to measure for spline sizes not sure what box or column in my truck. P.O. did a camero swap and has a tilt column out of a mystry car/truck
ConnDemned is offline
Old 04-12-2010, 04:30 PM   #32
CPPJEFF
Yes this offer is still good. Thanks
CPPJEFF is offline
Old 04-16-2010, 08:18 AM   #33
skeeterbug
skeeterbug's Avatar
not to change the subject jeff but what do you all have to convert my truck from manual to 4 wheel disc brakes, just the master cylinder, prop valve, booster, brackets and hardware? willwood d52 calipers as well if you can work me up some kind of deal? sorry guys for highjacking the tread just need some info directly from a source, by the way the truck is a '71 w/ disc front drum rear as of right now
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline
Old 04-16-2010, 11:16 AM   #34
CPPJEFF
I have some killer deals on 4 wheel disc brake kits, we can put something together. Keep in mind i dont have a matching rear wilwood caliper for that front, i do have the Wilwood Master cylinders also we can put in the package. Call me at 888-522-8303 ext 118 for a price and we can talk details.
CPPJEFF is offline
Old 04-20-2010, 04:21 PM   #35
mclairmo
I have a 68 C10 and will be lifting the body just one inch. Does the shaft you make already have the ability to extend a little, like 1/2" or so? Or would you have to custom build one that is slightly longer? I would think that the guys adding a 3 inch body lift could really use a longer shaft.
mclairmo is offline
Old 07-12-2012, 11:12 AM   #36
greyno3
greyno3's Avatar
Still making these? I bought a '72 tilt from a "truck". Found out that it is the longer shaft from a van..Grrr.
greyno3 is offline
Old 07-13-2012, 11:34 PM   #37
INSIDIOUS '86
INSIDIOUS '86's Avatar
Hey jeff do you think you can make one for an 86? Without the ragjoint? My ragjoint puts too much slop that i feel in my unhooked power steering box.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline
Old 07-14-2012, 12:01 AM   #38
N2TRUX
Happy to be here
N2TRUX's Avatar
CPP is no longer a Forum Vendor. I suggest you contact one of our Forum Vendors that is a CPP dealer for your needs
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
N2TRUX is offline
Closed Thread
