Closed Thread
Old 02-18-2010, 10:43 PM   #1
qu1cks1lver56
qu1cks1lver56's Avatar
Lowering shackles?
I want to lower my truck some. And flipping the rear end would be way too much for me. So I think shackles is the way to go for me. Anyone want to point me in the direction of some good ones that won't break the bank?
For the front I'm probably going to either cut a coil or 2 off the springs or get some drop spindles. Or both.
qu1cks1lver56 is offline
Old 02-18-2010, 10:48 PM   #2
chrismoore701
chrismoore701's Avatar
Re: Lowering shackles?
Bell tech is the way I went, no problems.
Chris
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline
Old 02-18-2010, 11:03 PM   #3
54Caddy
GM Addicted
54Caddy's Avatar
i just put some in my truck recently, i ordered them through summit. They are the summit brand ones, but there just repackaged ground force drop shackles, they were 50 bucks if i remember correctly. The shackles are good for the price and if you didn't know you have to notch out the under side of the bed so they clear it comes with all the measurements on where to make you cuts not hard at all.And cutting the coils i believe for every coil you cut its a 2 inch drop and dont cut half a coil either.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline
Old 02-18-2010, 11:05 PM   #4
qu1cks1lver56
Thanks for the info guys.
Old 02-18-2010, 11:14 PM   #5
diponyou
diponyou's Avatar
also if your not wanting to order the shackles,i just picked some up at an o'reillys
there belltech shackles for our trucks and they were only 40 bucks
diponyou is offline
Old 02-19-2010, 01:57 AM   #6
qu1cks1lver56
Wow, definitely gonna ride by there and check 'em out.
Old 02-19-2010, 02:07 AM   #7
54Caddy
GM Addicted
54Caddy's Avatar
be carefull though i kno autozone sells some cheap brand ones, id order the summit ones
..Mac’s Garage..
IG:MacsGarage
54Caddy is offline
Old 02-19-2010, 02:24 AM   #8
qu1cks1lver56
If someone local has belltech's then I'll buy them since I've heard good things about them. But I won't buy any cheapos.
Old 02-19-2010, 08:13 PM   #9
flamingbig10
6.0 powered square
flamingbig10's Avatar
oreilly auto parts sells beltec shackles, also you cold remove a leaf or two lower it more
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline
Old 02-19-2010, 09:19 PM   #10
68Timber
I know the pieces fit
68Timber's Avatar
I haven't heard that before. Why can't you cut half a coil?
Just curious, I'd planned on doing half a coil at a time (on my daughter's truck) until it looks right.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
68Timber is offline
Old 02-19-2010, 09:25 PM   #11
54Caddy
GM Addicted
54Caddy's Avatar
My grandpa and dad have always said that ill tell him to fill in on this question, if i remember right it sags or something like that will tell him to answer this question for you..
..Mac’s Garage..
IG:MacsGarage
54Caddy is offline
Old 02-19-2010, 10:22 PM   #12
3r!c84
Badass
3r!c84's Avatar
you can cut 1/4 ,1/2 or 3/4 a coil it dont matter
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline
Old 02-19-2010, 10:33 PM   #13
joe231
joe231's Avatar
if you have 52" springs you will have to notch, but if you have 56" springs you won't....
CHEVY ONLY
joe231 is offline
Old 02-19-2010, 10:47 PM   #14
68Timber
68Timber's Avatar
Cool. I thought I'd stumbled on some voodoo I hadn't met before. And the belltech/oreilley's tip is excellent - my daughter is ready to tear into her truck.
John
74 Honda Z50 build
68Timber is offline
Old 02-19-2010, 11:09 PM   #15
54Caddy
GM Addicted
54Caddy's Avatar
i heard that if you cut 1/2 it doesnt sit in the arm bucket right idk just what ive heard
..Mac’s Garage..
IG:MacsGarage
54Caddy is offline
Old 02-19-2010, 11:10 PM   #16
3r!c84
Badass
3r!c84's Avatar
you can spin the coil to fit in the grove
-00 Saturn 5spd
1/4:13:90
3r!c84 is offline
Old 02-19-2010, 11:20 PM   #17
54Caddy
GM Addicted
54Caddy's Avatar
yea true just saying what ive heard
..Mac’s Garage..
IG:MacsGarage
54Caddy is offline
Old 02-19-2010, 11:22 PM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
You can cut a 1/2 coil on the springs with no problem. Just make sure the coil is seated properly in the spring pocket. The most important thing about cuttings coils is to avoid excessive heat. This will lead to sagging springs.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
N2TRUX is offline
Old 02-20-2010, 12:34 AM   #19
68Timber
68Timber's Avatar
I'd planned to use my angle grinder, no torch. I think we'll be good, I just wanted to be sure since I'm somewhat new to lowering and this is my daughters truck. Thanks.
John
74 Honda Z50 build
68Timber is offline
Old 02-20-2010, 01:31 AM   #20
qu1cks1lver56
I thought about it, but I want my payload since I'm still gonna pull the boat to the river.
Same here, I don't have a torch so angle grinder or possibly my chop saw.
Old 02-20-2010, 01:33 AM   #21
3r!c84
Badass
3r!c84's Avatar
use a 3in cut off wheel
-00 Saturn 5spd
1/4:13:90
3r!c84 is offline
Old 02-20-2010, 10:17 AM   #22
68Timber
68Timber's Avatar
That's what I was thinking.
John
74 Honda Z50 build
68Timber is offline
Old 02-20-2010, 10:44 AM   #23
bigblock73
yeller
bigblock73's Avatar
Glad someone cleared that up, because I was about to vent...LoL.
Misinformation gets under my skin. I too listened to advice on a message board AND the instructions when I put on my drop shackles back in the 90's...notched my bed supports to clear the drop shackles, turned out I didn't have to because I have the longer 56" springs.
That still bugs me...now I have a notched supports for no reason at all.
bigblock73 is offline
Old 02-20-2010, 11:46 AM   #24
JohnC
JohnC's Avatar
It's there for a reason. To remind you of the progress and information you have learned over the years.
JohnC is offline
Old 02-20-2010, 12:09 PM   #25
joe231
joe231's Avatar
The forum seems to be over-run lately with mis-information and "I have heard" posts....it is to a point where I'm plain tired of correcting all the bad info.
I dunno what can be done about it though.......
CHEVY ONLY
joe231 is offline
Closed Thread
