Old 02-20-2010, 10:32 AM   #1
jbgroby
jbgroby's Avatar
Dyna-mat under Rubber Floor Mat
I'm going for the OEM stock look ans will be installing a rubber floor mat. However, because I have hearing aids I tend to like to keep the ambient sound down as much as possible. I understand that you can put it down in pieces I'll hide some behind the gas tank and front firewall, I'll try getting some on the door cavities, but was unsure of the floor area?
The dyna-mat that a lot of guts talk about and I've seen in the pictures, would it cause any fit problems for the rubber floor mat?
Jake
jbgroby is offline   Reply With Quote
Old 02-21-2010, 04:34 AM   #2
blackedoutharley
Re: Dyna-mat under Rubber Floor Mat
Dyna-Mat is somewhat thick so it may cause fit problems.
When I did my stereo install years ago I used what is basically bubble wrap that is coated in "aluminum" on both sides before installing a carpet kit. I slid the in cab tank forward and put it on the back of the cab and in the cab corners after spraying foam along the seams. Covered the tank as well. On the doors I put it on the outer skin as well as the back side of the door panel.
Did not do anything to the firewall as the factory pad was in place and in good condition. I used 3M spray carpet adhesive to make it stick.
This stuff was very inexpensive compared to Dyna-Mat and while probably not as good it has served the purpose for over 12 years just fine.
This is a fancy brand of what I used.
http://www.reflectixinc.com/basepage...&PageIndex=622
This along with re-routing the mufflers to under the bed made a HUGE improvement in reducing the ambient noise inside the cab. While before it was nearly impossible to have a conversation inside the truck while driving now you could do so with no issues and it helped to tone down the "tinny" sound inside which made the stereo sound much better.
blackedoutharley is offline   Reply With Quote
Old 02-21-2010, 08:41 PM   #3
ol Curt
Junior Member
ol Curt's Avatar
I think a few of the guys have used some material from Lowes that is for roofing and is much cheaper. A search will probably turn it up. I can't remember the name...but then again, I can't remember mine half the time.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 02-21-2010, 09:34 PM   #4
rendus
rendus's Avatar
Peel and Seal. I used it on my Galaxie. Good Stuff.
rendus is offline   Reply With Quote
Old 02-21-2010, 10:38 PM   #5
LILRED66
LILRED66's Avatar
We have put Peel-N-Seal in several 4-5-6 Chevy trucks with very good results and no odor issues. I have used Dyna Mat & Hush Mat and they are substantially more expensive, come in pieces that are too big to apply to the small areas and many compound curves in the cab of these trucks. My vote is for Peel-N-Seal for the money and the ease of application, and most importantly the end results.
P.S. - these trucks came from the factory with a thin white foam mat & asphalt-impregnated mat, below the factory floor mat to help with sound and temperature tranmittance. The factory material was thicker than the Peel-N-Seal, so fitment is not an issue.
LILRED66 is offline   Reply With Quote
Old 03-01-2010, 04:21 PM   #6
Greg63
Enjoy your truck
Greg63's Avatar
Is there a product number available for the Peel and Seal? I would like to take a look at it up here in Canada but I don't know who carries it.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 03-01-2010, 08:24 PM   #7
ljackson
ljackson's Avatar
Try this. It is from a home improvement chain.
http://www.lowes.com/pd_154017-81326...18733&Ntt=peel and seal&Ntk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=peel and seal$y=8$x=33
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 03-01-2010, 10:27 PM   #8
K-TEN
I'd like to comment that, although the consensus is for cheap in this economy, let's not forget about safety. Some are so concerned about fuel tanks being relocated out of cabs etc. All the while, there is no concern for cutting corners on the "Peel and Seal". If there is a fire in the cab, you probably won't die from the flames because you'll be dead from the toxic fumes given off by peel and seal in under a minute. This stuff is not meant for an interior automotive application, so know that going in. Rant over. On the flip side, there are some less expensive alternatives to Dynamat and the high end stuff. Raammat is one of them. It's cheaper, it comes in a LOOONG roll and it works. Take a look.
http://www.raamaudio.com/index.php?o...page&Itemid=59
I don't work for them. I bought some of their product.
K-TEN is offline   Reply With Quote
Old 03-01-2010, 11:09 PM   #9
Greg63
Enjoy your truck
Greg63's Avatar
Thanks for your "rant". I saw a similar concern on a car audio forum while I was searching for the Peel & Seal.
To that end, I went to my local Lowes and Home Depot this afternoon and they don't have anything like the Peel & Seal up here in stock.
I will be looking around for comparable, safe products that I can put inside my cab.
Greg.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 03-01-2010, 11:56 PM   #10
robzilla
robzilla's Avatar
Greg.
when you find something in canada, let me know. it's hard to find stuff north of the border at times
robzilla is offline   Reply With Quote
Old 03-02-2010, 07:57 AM   #11
K-TEN
Did you email Raammat for Canadian delivery? BTW, they have rolls of floor only stuff for 69 bucks. See above link.
Old 03-02-2010, 12:44 PM   #12
magooster
'65 GMC Project
magooster's Avatar
I've heard good things about this stuff. Used to be called Brown Bread now it's called B-Quiet.
http://www.b-quiet.com/brownbread.html
Beauty is in the eye of the beer holder
1965 GMC project
1999 GMC Safari (daily driver)
2005 Scion XB (Wifey's car)
magooster is offline   Reply With Quote
Old 03-02-2010, 04:25 PM   #13
Greg63
Enjoy your truck
Greg63's Avatar
Thanks for the link.
I just sent them an email asking for Ontario distributors.
Greg
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 03-02-2010, 06:11 PM   #14
Greg63
Enjoy your truck
Greg63's Avatar
They are an internet only company that sells from Alberta. I can get 50 sq/ft for $139 Cdn shipped.
Not sure if that is too high or not.
Greg
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 03-02-2010, 11:48 PM   #15
austex66
austex66's Avatar
I had good luck with the "raamat" and installed the factory rubber mat and jute with no problems. This certainly helped with noise and heat!
Not the best angle....
66' Chevy SWB:350ci-th350,frt. disc brakes, pwr steering, 5-lug
waltshow.com/Chevy
austex66 is offline   Reply With Quote
